Hertz Group Buy/Sound Deadening/Thermal Teatment Install
Discussion in 'Audio & Video' started by Tundyfundy, Oct 23, 2019.
  1. Oct 23, 2019 at 10:52 PM
    Tundyfundy
    Tundyfundy [OP] Petunia The Tundra, and her sidekick Colbie
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Anytime! :cheers:
  2. Oct 23, 2019 at 10:57 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Got it. Thanks again for the work and posting!
  3. Oct 24, 2019 at 4:40 AM
    coTony
    Tony
    Montrose, CO
    Looks like some work there
    Tundyfundy[OP] likes this.
  4. Oct 30, 2019 at 3:39 AM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    Couple questions before I start my 12 Tech install.
    Did you drill pilot holes into the speaker adapters and or the sub box before installing/securing speakers? Does the sub just lay in the hole and then screw it down?
    There are no crossovers for the Hertz tweeters?
    Do I just tap the tweeters into speaker wires coming from factory HU or is there a way to get a harness for this front and back?
    Thanks.
  5. Oct 30, 2019 at 6:49 AM
    Ericsopa
    Ericsopa Old man and the sea
    Looks really great. Did mine last year, tho' just the doors and back wall on my CM. Don't you just love the way the doors sound now when you close them?
  6. Oct 30, 2019 at 8:36 AM
    Tundyfundy
    Bay Area, CA
    Hey there! Ok so to answer your questions, I had to stick along screw through the adapters to pop out the last little plug of wood stuck in there but all my adapters has pre drill holes in the correct positions. If yours don’t contact James.
    I did drill tiny little pilot holes for the sub but real small ones as the screw will go through the bottom of the wood anyway.
    Yes sub lays in the box and gets screwed down. Imagine how the box will be oriented In the car. I put the logo on the sub so you could read it when the seat was up. So sub logo basically parallel to the front of the box
    There’s no harness for the tweets. What I did was take the harness for the door speakers and splice in your tweeter and then connect to the existing speaker harness. With that method you won’t have to tap the factory wiring and everything will be reversible/ won’t mess with your warranty. I de pinned the new harness to give me freedom to solder my connections without having to try to keep the wires separate the whole time. There’s pictures of this step in my post.
    I don’t think the tweets have crossovers. You will be using the crossovers on your amp.
    The damn little tweeter ring is a bitch. Use some lube and lots of profanity.
  7. Oct 30, 2019 at 8:38 AM
    Tundyfundy
    Bay Area, CA
    Sounds like a muscle car meets Mercedes! Very satisfying sound! Good job. Those doors are a pain to get into!
  8. Oct 30, 2019 at 9:15 AM
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    Nicely done.
    The benefits of doing this type of work go beyond having better sound coming of the speakers.
  9. Oct 30, 2019 at 9:44 AM
    Tundyfundy
    Bay Area, CA
    I was waiting at a light with my windows down and there was a small construction crew right next to me. I rolled the windows up and it was like they disappeared. Not a sound. I’m also very impressed with the thermal damping. I feel like my AC is a beast now compared to before.
    I read somewhere they did a test where sound dampening could reduce driver fatigue by a considerable margin over long distances.
    Ericsopa likes this.
  10. Oct 30, 2019 at 5:23 PM
    1794TRD
    1794TRD It is, what it is!
    Little Rock, AR
    2015 Super White II TUNDRA 1794
    TRD EXHAUST TRD INTAKE Lift 3” front 1.5” rear TRD SKIDPLATE UNIFLEX TRIFOLD BED COVER UNIFLEX SWINGBOX POP & LOCK POWER TAILGATE LOCK TUNDRA BED LIGHTS LED HEADLIGHTS / FOG LIGHTS / PUDDLE LIGHTS / INTERIOR LIGHTS WHITE DOOR HANDLES WHITE MIRROR COVERS TOYTEC BOSS REAR SHOCKS CRUX AVITY-01 VIDEO INTERFACE AJT KEY FOB COVER
    like that you installed deadening on floor. How much did it take?
    based on your picture below, you may need a little carpet with that dog hair...
  11. Oct 30, 2019 at 7:09 PM
    Tundyfundy
    Bay Area, CA
    Haha 3 years of dog under the seat is horrible! I used 1 box for the doors, one box for the ceiling, and 1 box on the floors and back wall. I think each box is 36sq/ft
  12. Oct 30, 2019 at 9:27 PM
    1794TRD
    Little Rock, AR
    Thanks. Great write up.
  13. Oct 30, 2019 at 10:25 PM
    Pbear1454
    Pbear1454 New Member
    NorCal and SoCal
    2010 Tundra TRD
    Bilsteins SPC RCI Steel Bumpers
    How long did it take to disassemble ? I assume the truck is not your daily driver
    Ok I saw your post about it being 40 hours :)
  14. Oct 31, 2019 at 7:31 AM
    Tundyfundy
    Bay Area, CA
    Oh man. I did all 4 doors sound mats and speaker wiring/ grease window track etc.. took me about 12 hours.
    The floors and rear were easy and with removing seats carpets, trim panels, but also wiring amp and running wires took a while, I’d say at least another 10.
    Headliner was the worst. Took me at least 10 hours to pull all parts from trims, remove all parts from headliner, remove and clean headliner, sound mat, heat mat, tape up wires etc...
    I spent about another 8 hours. assembling the interior, and wiring amp to speakers, replacing headliner, seats, trim panels, carpets, dome light etc... which was actually very easy with the methods I described.
    Mind you i went full coverage. Some guys recommend only 60% coverage which would have saved me time but since I was already in there I went all out!!
    Pudge and Pbear1454[QUOTED] like this.
  15. Oct 31, 2019 at 8:07 AM
    Tundyfundy
    Bay Area, CA
    Also truck is DEF not the daily driver. She was down almost 2 weeks while I found time in the afternoons and weekends. I would say do 1 door at a time to completion. 1 door can fully be done in an afternoon. The floor/ ceiling would be one weekend each. Install back only the driver seat so you can still drive it but when you do the ceiling the next weekend you won't have to remove everything again.(if possible)
    Rica25 and Pbear1454[QUOTED] like this.
  16. Oct 31, 2019 at 7:51 PM
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    I have a box of Kilmat still unopened. I'm looking more to reduce drone from the exhaust which is over powering the stereo
  17. Oct 31, 2019 at 8:01 PM
    Tundyfundy
    Bay Area, CA
    Mat your floors ! Cuts out the exhaust and drive train noise. I thought you could also remove that fire mat from the underside of your hood and mat that, then re-install. If I’m not mistaken the Noico products are rated for that.
    Pbear1454[QUOTED] likes this.
  18. Oct 31, 2019 at 10:58 PM
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    I've got some practice removing the door panels to install puddle lights, but removing all the seats and hardware sounds very tedious and then more time in surface prep for the mat and vinyl. I think you may have just created some inspiration to go for it.
    Thanks for the the helpful tips.
  19. Nov 1, 2019 at 3:41 AM
    #49
    Tundyfundy
    Bay Area, CA
    The floors are the easiest part. Just takes a while if you do it by yourself. Each seat has 4 bolts. Everything else just snaps out of place. Very straight forward. I just wiped everything with a dripping wet alcohol rag and waited for it to dry. GO FOR IT!! :oldglory:
  20. Nov 1, 2019 at 4:56 AM
    #50
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    You make it sound so simple :hattip:
  21. Nov 2, 2019 at 8:31 AM
    #51
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    Does the ring for the tweeters go over the speaker or do I add through the bottom?
    I hope this makes sense as I just broke a ring.
    Barely pushing from the bottom.
    Thanks
  22. Nov 2, 2019 at 9:12 AM
    #52
    Tundyfundy
    Bay Area, CA
    Through the back. It’s so hard to do I would contact James for a freereplacement as the directions don’t specify this part. Seems only fair.
  23. Nov 2, 2019 at 9:13 AM
    #53
    Tundyfundy
    Bay Area, CA
    That ring was the hardest part of the install so don’t feel bad. If you stretch it slowly it’ll go in without breaking you have to line up the three notches.
  24. Nov 2, 2019 at 12:01 PM
    #54
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    All finished with the front speakers and the tow mirrors today.
    Rear speakers next weekend.
    James said he would send a replacement.
    Thanks.
  25. Nov 2, 2019 at 1:23 PM
    #55
    Tundyfundy
    Bay Area, CA
    Good to hear! I had no doubt he would.
  26. Nov 2, 2019 at 1:24 PM
    #56
    Tundyfundy
    Bay Area, CA
    Post some pictures!
  27. Nov 14, 2019 at 12:15 PM
    #57
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    Hey folks, do you think this foam at HD will work as a middle layer?
  28. Nov 14, 2019 at 12:49 PM
    #58
    Tundyfundy
    Bay Area, CA
    I’m assuming by middle layer you are using it as soundproofing?
    IMO... absolutely not. It’s all be bunches up in the bottom of your doors before the year is out.
  29. Nov 14, 2019 at 1:11 PM
    #59
    Pbear1454
    NorCal and SoCal
    2010 Tundra TRD
    Ok you have good point for a vertical application, what about if it's laid on the floor ? I haven't seen the specific foam made for sound deadening so I don't know the differences
  30. Nov 14, 2019 at 1:39 PM
    #60
    Tundyfundy
    Bay Area, CA
