Hertz Group Buy/Sound Deadening/Thermal Teatment Install
Discussion in 'Audio & Video' started by Tundyfundy, Oct 23, 2019.
  1. Oct 23, 2019 at 2:41 PM
    Tundyfundy
    Tundyfundy [OP] Petunia The Tundra, and her sidekick Colbie
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Hey everyone! I am finally posting about my install of a sound system as well as sound deadening/thermal treatment for my truck. I got the @tech12volts Hertz Infinity group buy here https://www.tundras.com/threads/tundra-infinity-hertz-complete-package-group-buy.44326/
    Dealing with James was a pleasure. Everything came packed up very well.
    Here are the products I bought:
    3 boxes
    https://www.amazon.com/Noico-deaden...locphy=200807&hvtargid=pla-379817158544&psc=1
    3 boxes
    https://www.amazon.com/gp/product/B07FYLM47D/ref=as_li_tl?ie=UTF8
    https://www.amazon.com/Noico-Instal...PQ9YAGHZMA8&psc=1&refRID=QQP1TF5EYPQ9YAGHZMA8
    4rolls
    https://www.amazon.com/Noico-Finish...5Q3NK1NYP2J&psc=1&refRID=GBKT77TM95Q3NK1NYP2J
    These numbers are for a double cab full coverage over doors, rear, roof, floors with some left for dash.
    Your also going to want to order something like this
    https://www.amazon.com/UTOOL-Automo...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
    I took the opportunity to
    1: Clean my headliner. (Tuff stuff cleaner and clean sponge)
    2. Grease ( White lithium) my door hinges and door latches, hood hinges and hood latch, window motor gears, window track, and lubricate (silicon spray)and clean all window seals, and door handles as well as the handle cable balls.
    3.Replace creaky door check.
    All these things require the door panel to come off so I did full maintanence in there. Between the sound proofing and greasing my windows don't make any noise while operating and they move smooth and steady. Not like before where I was getting a chattering as the window rolls down due to grime in the system.
    Ok a few tips:
    1. Take lots of pictures. I had to reference them many times during re-install of truck components.
    2. Work organized: I would remove a trim piece and wrap the hardware (if any) in masking tape and then tape it to the trim piece. Then I would write on the tape "Left hand b-pillar top" or whatever it was. This made re-install go amazingly fast.
    3. Wear gloves that cover your wrists! The door panel is sharp and I sliced myself good a couple times. Once was right on the front of my wrist by my veins. Not fun.
    4. Take your time. You don't want to be doing any of this again. If your adhesive fails on the sound mats you will have problems. Example, door mats come loose and stick to your window. Good luck cleaning up,that mess. Or roof mat falls and weighs down your headliner. Prep is key!
    5. If your outside you can throw some moving blankets over the cab and windshield to keep the sun from reflecting off the sound sheets and blinding you. It also helps with heat or cold if that applies.
    6. Order a universal fastener kit for your truck because you will break some stuff. I bought one for 15 dollars on Amazon and it had all types. Also I broke one dash speaker grill and one bolt cover on the oh shit handle. No biggy. https://www.amazon.com/SunplusTrade...+fasteners&qid=1571866262&s=automotive&sr=1-6
    7. Wear clean latex gloves for headliner work. That thing gets dirty fast. I would also vacuum and clean the interior and make sure you have the area clean. You don't want it accidentally touching and adhesive which brings me to my next point.
    8. Cover the edges of sound mats with noico tape. That butyl is so sticky and will leak out. You don't want it on the underside of your carpets or headliner.
    9. Don't cover any wires on your ceiling. Pull them all down (pictures!) and then retape them up over the sound mats. This will keep them cool and allow you to repair without removing the sound mats if needed.
    The sound is amazing. It's not obscene but really clear and full. I love the bass! I ordered a Fix 86 to have more control over the sound and I'll update this thread once I get it installed.
    Enjoy!
    Kenreau, bulldog93, Skew12 and 7 others like this.
  2. Oct 23, 2019 at 2:45 PM
    Tundyfundy
    Bay Area, CA
  3. Oct 23, 2019 at 2:57 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    When can I drop off my truck ?
    OhEmmBee, Cthulhu, Ely010606 and 4 others like this.
  4. Oct 23, 2019 at 3:01 PM
    Tundyfundy
    Bay Area, CA
    You're welcome to use my space! I'll walk you through it gently as I observe from my beer drinking chair!
  5. Oct 23, 2019 at 3:02 PM
    sunnysideTRD
    sunnysideTRD New Member
    Sunny
    2019 Tundra TRD Pro Voodoo Blue
    Standard 2019 TRD Pro but will be a project car and add as I go
    wow..that's a lot of work..Congrats!
  6. Oct 23, 2019 at 3:02 PM
    Tundyfundy
    Bay Area, CA
    Let me say the benefits from this are amazing. You can hear the difference and it rocks. Also the heater and AC work so much better!
    Cthulhu and Mountun Goat like this.
  7. Oct 23, 2019 at 3:05 PM
    sunnysideTRD
    Sunny
    Value added..even better.
  8. Oct 23, 2019 at 3:08 PM
    WillieMan
    WillieMan New Member
    Aaron
    2019 Silver Tundra Platinum
    Is the cab a lot quieter? Did it remove all the rattles out of the door? I just bought a new platinum and although the system isn’t that strong it rattles the shit out of the plastic components in the door.
  9. Oct 23, 2019 at 3:12 PM
    Tundyfundy
    Bay Area, CA
    Yes It has no more rattles and sounds tight. The cab is amazingly quieter, when I’m next to loud big rigs on the highway they sound far away. You most likely don’t need to go this far but the door sound matting is fairly easy without having to remove the seats or anything complicated. The door panels come off in about 3 minutes. You can also put the sound deadener on the plastic door panels, door lock mechanisms and window motors to quiet them all down while you’re in there.
  10. Oct 23, 2019 at 3:13 PM
    Tundyfundy
    Bay Area, CA
    I used one box each of sound mats and heat mats for all four doors. Double cab.
    Cthulhu likes this.
  11. Oct 23, 2019 at 3:21 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Darn I thought since you had the experience I would be the one drinking the beers lol. Looks good!
  12. Oct 23, 2019 at 3:24 PM
    Tundyfundy
    Bay Area, CA
    Thanks man! Not a chance. :rofl::thumbsup::anonymous:
  13. Oct 23, 2019 at 5:07 PM
    james@tech12volts
    james@tech12volts tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    very well done my friend!!
    Tundyfundy[OP] likes this.
  14. Oct 23, 2019 at 5:09 PM
    james@tech12volts
    james
    also we have plug n play harnesses for the DSR1 processors for non jbl systems now 2014 to 2020
  15. Oct 23, 2019 at 5:27 PM
    Tundyfundy
    Bay Area, CA
    Is that something I can use to install my fix 86 or is the DSR1 different?
  16. Oct 23, 2019 at 5:35 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Wow you did a great job man. Thanks for the comprehensive post and pics. I did full sound deadening in my truck and a system from James. I love it and don't regret a thing. It was all well worth it. One thing I have yet to do is the dreaded roof sound matting, its been about a year since I did my system and over a year since I started sound deadening. I want to use a little noico 80mil and that noico green foam stuff but am just not wanting to pull the headliner. I know it'll make a huge difference and not doing it is a job half finished which drives me nuts. So how bad was the headliner job? Everyone says its brutal and I can see why, it's a lot of work and effort. You're a better man than I for going full out on this. Maybe talk me into doing my roof, cuz I'm procrastinating like crazy, like I said it's been over a year since I did other sound control.
    Tundyfundy[OP] and Mountun Goat like this.
  17. Oct 23, 2019 at 5:36 PM
    Tundyfundy
    Bay Area, CA
    So much work but I’m hoping to ever have to go into the interior again so I did all I could. Besides researching and buying everything I needed, I believe it took me around 40hours work to do this by myself.
    Mountun Goat likes this.
  18. Oct 23, 2019 at 5:45 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Wow awesome looking install. Looks like tons of work. I have to commend you on your planning and complete scope of work while getting in behind things. I will use this knowledge when I do mine. Thanks for the thread!
  19. Oct 23, 2019 at 5:50 PM
    Tundyfundy
    Bay Area, CA
    Thanks dude! I honestly was scared to do it but it’s not too hard just tedious. There was a little rail in the front that I had to permatex back onto the back of the headliner because the factory adhesive was already getting brittle!
    Other than that use plastic tools and lots of patience. I would never do the job with one person again. I put a tiny hole in it trying to get the passenger grab handle off and had to scrape some fibers from the outside edges and do a tiny touch up but you can’t even notice it right by the handle, which was the worst part to remove.
    Be prepared to buy a piece of you have to because I wish I would have just drilled out that handle and installed a new 30 dollar one for the trouble it cause me.
    With all that being said MAN WHAT A DIFFERENCE!! My install was in summer and I sweat it out! When I removed the headliner I got hit with radiating heat from the roof! Like a slap in the face. It’s steel, what can you expect? It’s probably Baking at over 140degrees all day in the summer. I put moving blankets over the cab to kill some of the heat but I was pouring sweat. After I got the sound deadening on I started the heat sheets and at some point I was like “Oh my gosh I’m semi comfortable in here!” It was like being under an EZ up outside instead of feeling like an oven. It was Drastic! The truck is also a lot quieter in the rain and wind now and I’m confident that it’s the reason my AC pumps so hard now. It used to kinda lag in cooling down the truck, like it would take 10 minutes to kill the summer heat if the truck was in the sun sitting a while. Now it takes a couple minutes and I have to adjust it down. I highly recommend it. I read if you just lay your seats flat you can drop the headliner and leave it in the truck if you want but makes it hard to work around. It’s flexible so just have a place for it (wear clean latex gloves) and get it out of the way. Great time to clean. You got this!!
    Rear of
    Headliner is held on with pressure clips as is the cargo lamp and dome along with some screws. Then just remove the clothes hangars and roof handles, and visors and it should pop out from behind the moldings with some pressure. I think a few trim pieces too.
    Pudge[QUOTED] and Mountun Goat like this.
  20. Oct 23, 2019 at 5:58 PM
    Tundyfundy
    Bay Area, CA
    Thank you! I was able to leave the truck down and drive my work vehicle for a few weeks so I was able to take my time. You got it man. If you have any questions about your install let me know and I’ll try my best to help!
    Mountun Goat[QUOTED] likes this.
  21. Oct 23, 2019 at 6:10 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Very cool, thanks!
  22. Oct 23, 2019 at 6:38 PM
    AZTundra
    Paul
    Phoenix, AZ
    Nice job! I'm sure the 40 hours of work you put in will provide many more hours of enjoyment and satisfaction.
  23. Oct 23, 2019 at 6:40 PM
    Tundyfundy
    Bay Area, CA
    Thanks friend. It already has and I’m proud of doing it with my own hands. You just got to do it yourself if you want it right.
  24. Oct 23, 2019 at 6:51 PM
    Pudge
    CT
    Thanks man I appreciate all the great info. I'm still scared to do it. I need to find a friend to help me too, lol. My 8 year old daughter tries to be a helper but I think I'll be happier in the end if I get a buddy to help. One of these days I will do it, I know its gonna be worth it in the end. Thanks again!
  25. Oct 23, 2019 at 6:55 PM
    Tundyfundy
    Bay Area, CA
    Road trip to Cali! ;):burnrubber:
    Pudge[QUOTED] likes this.
  26. Oct 23, 2019 at 6:55 PM
    Tundyfundy
    Bay Area, CA
    Let me know if you need any info when you get around to it :thumbsup:
  27. Oct 23, 2019 at 7:05 PM
    Pudge
    CT
    I will very likely take you up on this offer. Thank you very much!
  28. Oct 23, 2019 at 8:18 PM
    Cdorman
    Cdorman New Member
    Oklahoma
    2015 - SR5 - CM - MGM
    Color match MGM Bulge/Grille Trim Pro Grille TRD Pro Headlights(black) OEM led fog lights upgrade Headlight Revolution HID upgrade TVD vinyl decals Fog lights Always MOD Bilstein 5100’s 12Volts remote start kit PowerBass plug/play speaker upgrade
    Great info, thanks for sharing!
    :cheers:
  29. Oct 23, 2019 at 8:38 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Awesome job and great write up!!! Thanks for taking the time to put all this together and share!
    This is on my list for this fall/winter...where I can have the truck in the garage and it not be 2000 degrees...
    Did you use any other sound tiles in addition to/ under the Noico?
  30. Oct 23, 2019 at 10:51 PM
    Tundyfundy
    Bay Area, CA
    No I put a layer of the 70 mil butyl noico followed by a layer of the 170 mil thermal barrier Noico. That’s it. It already weighs a bunch so I didn’t want to go too crazy since it’s not even a competition system. I think it’s just perfect for what I was going for. Some guys do a rubber layer after but seems the clearance would be tight. Definitely wait until it cools down but not too much as the heat helps the product bond and helps you manage it while installing. I set my sound tiles in the sun for a half hour before I started cutting and fitting them and it made it easier.
    Sunnier and GAknight[QUOTED] like this.
