Help with plumbing
Discussion in 'Off-Topic Discussion' started by aRabidLunatic, Nov 12, 2018.
  1. Nov 13, 2018 at 11:25 AM
    15whtrd
    15whtrd Mr. Blonde
    Yeah sorry man. It was one of the things I told my wife. I promised I would be home more and stop working 14 to 16 hour days. I was missing my daughter growing up. I miss the extra money but I don’t miss the headaches and working out of a pick up truck.
  2. Nov 13, 2018 at 3:43 PM
    Slayer
    Slayer Member
    Slayer
    10 years its definitely time.
    The Same symptoms happened to me in my modest little home shortly after I moved in about 30 years ago.
    In my case.. new drain field was required.
    If a new field is needed.. you can do this work yourself. Just research drain field designs on line.
    Spend a little quality time with your shovel for a few evenings after work. Your pumper will stop by to pump the tank while your working on it.
    Buy some pipe, drain rock but most importantly, put filter fabric on top of the rock.. this is easy & cheap... just a few hundred bucks.
    Some installers may want charge you upwards to 10 grand + for an upgraded system
    If you decide to do yourself.... ‘Do Not’rent any equipment/machines which might attract the attention from those nosey neighbors who you have pissed off, and who might want turn you in.
    If asked just tell them you are doing some maintenance... which you are personally allowed to do.
    You got this!
    .. Slayer
  3. Nov 13, 2018 at 5:52 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Exactly why I stopped, but I still do jobs here and there for friends and family. I actually miss being a plumber but don't miss the unpredictable schedule, or dragging my Spartan 300 onto roof tops in those IE Summers.
    Did have some good times though when I was young and single, could tell some stories of those adventures.
    15whtrd[QUOTED] likes this.
  4. Nov 13, 2018 at 5:54 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Time to go poo diving like Steve O.
  5. Nov 13, 2018 at 6:06 PM
    aRabidLunatic
    aRabidLunatic [OP] Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    o_O
  6. Nov 24, 2018 at 2:29 PM
    MotoTundra
    MotoTundra The Ocho
    Don
  7. Nov 24, 2018 at 4:05 PM
    Professional Hand Model
    Hand Protectors
    When it don’t go down, call Brown.
    Never trust a plumber that bites his nails.
  8. Nov 24, 2018 at 4:08 PM
    aRabidLunatic
    Central Texas
    Ended up having the tanks emptied. Seems to have fixed the issue.
    ZPMAN and NewImprovedRon like this.
  9. Nov 24, 2018 at 4:09 PM
    Hand Protectors
    She musta been filled to the brim.
