Help with fuel injector install
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Mar 19, 2021.
  1. Mar 21, 2021 at 5:15 AM
    #61
    Professional Hand Model
    Hand Protectors
    Stoked! Lets work on Feather Dusting after the VC Gaskets.
  2. Mar 21, 2021 at 5:18 AM
    #62
    Hand Protectors
    I disconnected the fuel injectors clips and taped them nicely with Electrical Tape found on the street corner.
    Voss[OP] likes this.
  3. Mar 21, 2021 at 5:23 AM
    #63
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I didn’t want to be the first person to say it but that engine definitely needs some detailing.
    Voss[OP] and Tundra2 like this.
  4. Mar 21, 2021 at 5:24 AM
    #64
    Hand Protectors
    His looks to be a Full Tequila Bottle Job.
  5. Mar 21, 2021 at 7:55 AM
    #65
    Voss
    Voss [OP] Dust in the wind
    Valod
    2003 AC TRD 4x4
    Seems more like a 2joint Sunday job lol
    FrenchToasty, Darkness and Tundra2 like this.
  6. Mar 21, 2021 at 9:40 AM
    #66
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Theres a YouTube video o
    You ever seen nuetral drop before? I dont think we could break our engines if we tried
  7. Mar 21, 2021 at 1:11 PM
    #67
    Voss
    Valod
    2003 AC TRD 4x4
    Drove around town a bit today and I like the drive. Engine seems to be running smoother and a little more responsive to the pedal. Can’t say anything about adding HP or MPG but I can see how my MPG would improve in city driving since I don’t press the gas pedal down as much on takeoffs.
    Overall really happy with this mod.
  8. Mar 21, 2021 at 2:38 PM
    #68
    Hand Protectors
    Combo effect of clean Injectors and better atomization. My very first observation was better torque feels with less pedal. Hows your shifting feeling? Yeah the engine does sound smoother was another observation like you said.
    Voss[QUOTED][OP] likes this.
  9. Mar 21, 2021 at 5:10 PM
    #69
    Voss
    Valod
    2003 AC TRD 4x4
    Shifting I noticed as well. There’s no lag time now. Overall drive seems better. I can feel she’s happy.
    Any tips for removing these rubber bushing?... they’ve turned into hard plastic and are in there tight!
  10. Mar 21, 2021 at 5:16 PM
    #70
    Hand Protectors
    Cheers. Use a type of lever tool. Pry it. Donut may come out in brittle pieces. There is a metal ring inside and if you can grab that with a steady force it should mostly lever out in one piece.
    Filthyphil and Voss[OP] like this.
  11. Mar 21, 2021 at 5:19 PM
    #71
    Hand Protectors
    Put the new donuts back in the proper way. Not upside down.
    Nice feedback on the 12Ports. Shifting pattern change for the better.
  12. Mar 21, 2021 at 5:19 PM
    #72
    Voss
    Valod
    2003 AC TRD 4x4
    Nice I was about to update. I had to tear the inner portion out to see I could get leverage under it. Popped right out.
  13. Mar 21, 2021 at 5:21 PM
    #73
    Voss
    Valod
    2003 AC TRD 4x4
    Yes definitely. Even after a short drive I feel like this could be one of my more favorite mods.
  14. Mar 21, 2021 at 5:58 PM
    #74
    Voss
    Valod
    2003 AC TRD 4x4
    Little help please. @Professional Hand Model i think you may have told me about changing these a while back. Are these for the driver or passenger side?
    Valve Sub-assembly and Grommet. Working on passenger side and don’t see where these would go. Thanks!
  15. Mar 21, 2021 at 6:07 PM
    #75
    Voss
    Valod
    2003 AC TRD 4x4
  16. Mar 21, 2021 at 7:46 PM
    #76
    Voss
    Valod
    2003 AC TRD 4x4
    Do spark plugs wear down? There’s such a big difference in what was in my truck and the new ones I got from the stealer.
  17. Mar 21, 2021 at 8:14 PM
    #77
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Appears someone had iridium tip plugs instead of copper (or platinum) tipped plugs in your motor.
    Part # of old plug?
  18. Mar 21, 2021 at 8:26 PM
    #78
    Voss
    Valod
    2003 AC TRD 4x4
    Not sure. Mechanic changed my spark plugs last time
  19. Mar 22, 2021 at 3:47 AM
    #79
    Hand Protectors
    Same deal with my old shop. They put in the Iridium Tip. I like the Copper Tip better although they do not last as long.
    Looks like you are going full bore into a nice tune up and fresh over upgrade. Stoked.
  20. Mar 22, 2021 at 5:58 PM
    #80
    Voss
    Valod
    2003 AC TRD 4x4
    Fellas need a little help. Driver side value cover is getting hung up on the oil stick. Am I missing a step?...
  21. Mar 22, 2021 at 6:03 PM
    #81
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Remove the bolt holding the dipstick and you can rotate it out of the way
    MS22 and Tundra2 like this.
  22. Mar 22, 2021 at 6:08 PM
    #82
    Voss
    Valod
    2003 AC TRD 4x4
    I hadn’t removed the ignition coils. Sometimes I need to ask the question out loud to figure it out
  23. Mar 22, 2021 at 6:20 PM
    #83
    Voss
    Valod
    2003 AC TRD 4x4
    Your input here... the other valve cover wasn’t this dark inside. Looks almost like burned oil and it’s stained.. is this normal or is there potentially something wrong?...
  24. Mar 22, 2021 at 6:33 PM
    #84
    empty_lord
    05 rollover special
    Normal varnish. I hot tank my stuff. As long as you don’t see sludge, you’re good
  25. Mar 22, 2021 at 6:45 PM
    #85
    Voss
    Valod
    2003 AC TRD 4x4
    thanks
  26. Mar 22, 2021 at 8:04 PM
    #86
    Voss
    Valod
    2003 AC TRD 4x4
    One day ima have to treat you all to a massive BBQ. I need a little guidance.
    The Valve Sub Assy(which if I’m mistaken is the same as the PVC Valve replacement thread I linked before) but mine is threaded.
    Not sure how/where the grommet would go and this sucker is on tight! Even after a few sprays of penetrating bolt loosener.
    Wondering maybe the grommet isn’t actually for my model?...
  27. Mar 22, 2021 at 8:17 PM
    #87
    NWPirate
    Zach
    WA
    I belive the grommet is for the non threaded version.
    I changed mine out a couple months ago, it was REALLY tight! Going in was the same.
    You might be better off changing it after you bolt the cover back down so you're not chasing your tail around the garage trying to hold it down!
    Get it! :cheers:
  28. Mar 22, 2021 at 8:25 PM
    #88
    Voss
    Valod
    2003 AC TRD 4x4
    Thanks my dude!
  29. Mar 22, 2021 at 10:31 PM
    #89
    Voss
    Valod
    2003 AC TRD 4x4
    Glad I’m changing the tube seals...
  30. Mar 22, 2021 at 11:31 PM
    #90
    Voss
    Valod
    2003 AC TRD 4x4
    for future folk... Don’t tighten these too much
    FrenchToasty likes this.
