Help needed with bed cover. sorry new to pick up trucks
Discussion in '2.5 Gen Tundras (2014-2021)' started by CanTundra, Dec 5, 2021.
  1. Dec 5, 2021 at 5:49 PM
    CanTundra
    CanTundra [OP] New Member
    2021 Tundra TRD Off Road
    I would like to get something to secure my bed.
    I think the best option is a trifold since they allow you to open it up based on your needs.
    buddy of mine has the undercover flex cover on his gmc and loves it..
    few question for tundra guys
    how do these mount do they all use the bed rail systems?
    lastly i see the option for underside to be carpet etc whats the point of this?
    I dont mind spending on this item i just want a really good quality set up
    https://www.amazon.ca/UnderCover-Folding-Tonneau-UX42008-2007-2019/dp/B01M03LXEN
  2. Dec 5, 2021 at 6:38 PM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    There are a lot of options, all kind of depends what your plans, goals, and adventures will be with your truck.
    I’ve got a Diamondback HD cover, all made in the USA, good quality, awesome customer service, and they have nice accessories as well.
    Secures using c-clamps to the bed rail system, and I would say it’s one of the more secure options, that is if you lock your tailgate.
    I’m biased obviously, but that’s my vote;
    https://www.tundras.com/threads/diamondback-bed-cover.92664/
    Odin43, VTYOTER, macombeyedoc and 4 others like this.
  3. Dec 5, 2021 at 6:41 PM
    LTundra
    LTundra New Member
    I have a fold up BackFlip MX4. It has its own rail that is up above the bed rail system, actually right around the inside of the bed right at the inside, top edge. Mine is a couple of years old and see some drips every now and then, but not too bad.
    TravisH likes this.
  4. Dec 5, 2021 at 6:42 PM
    CanTundra
    those look like good quality but i don't like the the pivot in the middle of the bed. I would want one that opens up to give me full bed use.
    I was set to buy the undercover but then I have no bed rails so annoying they did it that way.
  5. Dec 5, 2021 at 7:53 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I've had an undercover flex for many years.
    Didn't have the bed rails.
    Never did like the clamps, the right ones would come loose almost everytime I shut it.
    They never could grab the edge of the bed frame securely.
    Finally getting tired of that, I bought the bed rails.
    Undercover sent the bed rail clamps for free.
    It is much more secure now.
    I can slam the thing shut with no issues.
    Flex and the Bedrug is like having a 6.5' trunk. :thumbsup:
    The old clamps.
    You can see how they monut at a weird angle and not straight in place.
    C5D55994-A568-440D-86D7-DE791B7E3695_zps_03b3a87a21d31466c3a987a40755782db9b55c56.jpg 47C705D7-0F1A-45AF-8C36-4A8D5C3C9E63_zps_7c5dfc14adf212214540c69ebea9b116e41637b4.jpg
    The bed rail clamps.
    Nice to have more tie downs too, I added them.
    7xupm161_4097a811ab429bf0099536d3b378fb684177b4f7.jpg lkpv9wze_31a36f1c3819e9d06077453dd492c18156b48ddb.jpg
    ujjw3lrn_4da1c197c10fafb888002766784fac3f48c16587.jpg 6i7o312u_7fe4167765c73656caa1ef82c164e5af6b3c281c.jpg
  6. Dec 5, 2021 at 7:59 PM
    CanTundra
    wow so I understand you correctly at first you didn't have the oem rails and mounted the undercover with just clamps but that didnt shut correctly
    then you bought oem rails.
    the undercover now mounts to the oem toyota rails but the oem cast ties downs get in the way due to their shape?
    So to fix this undercover makes a ties down that fits oem rail just low profile?
  7. Dec 5, 2021 at 8:12 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    No, you can't use those big bulky OEM bed rail tie-downs with a low profile bed cover..
    I sold mine that came with the rails.
    Undercover didn't make those tie downs.
    I bought those tie-downs, had to bend them a little.
    Amazon.com: CCR Sport Deck Rail Tie Down Hook for Toyota Tundra/Tacoma (4-Pack) : Automotive
    My install.
    Review - CCR Sport Deck Rail Tie Down Hook for Tundra with a cover and rail system | Toyota Tundra Forum (tundras.com)
    There is a company that makes some nice bed rail tie downs that would work with a cover.
    They are expensive, $130 a pair, but they are nice.
    Rail Tie-Down Anchors for Tundra / Tacoma – Charvonia Design (charvonia-design.myshopify.com)
  8. Dec 5, 2021 at 8:22 PM
    Kentuckytundra
    Kentuckytundra I love spam calls, we talk for hours
    I have the diamondback HD as well, my logic was since the bed cover can have 1600lbs placed on it, anything I'd need to haul in the bed that is large can go directly on top the cover. People put 4 wheelers on it. As far as security, I don't believe there is a more secure option, basically turns your entire bed into a lock box.
    Not the cheapest option, but certainly worth the money.
  9. Dec 5, 2021 at 8:23 PM
    Blueknights75
    Ron
    Clayton, NC
    Love my rugged cover 2 tri fold.
    Tileguy likes this.
  10. Dec 5, 2021 at 9:01 PM
    2021 Semi Pro
    2021 Semi Pro New Member
    Paul
    2021 MGM ,CM, SR5
    Clean slate
    I have owned Diamond back covers which I recommend they are a great cover if you set them up on install properly, if you need the entire bed they don’t remove super easy.
    back flip : I like because they open up the
    Entire bed quick and easy but block the rear window view.
    retractable bed cover is what I am running now and I really like it to open up the bed quick and easy but yet secure the bed contents. Amazon has a good low cost option 800 $ I am happy with it.
    Brand Syneticusa
    good luck on your decision
    CanTundra[OP] and panicman like this.
  11. Dec 5, 2021 at 9:24 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I have the Lomax hard trifold cover, I really like it. However.. if I was to do it again I would get a retractable cover like the RetraxPRO.
    timmyKGB likes this.
  12. Dec 6, 2021 at 2:51 AM
    Crewmax808
    Crewmax808 New Member
    Honolulu, Hawaii
    2016 Sunset Bronze Mica Tundra Crewmax
    TRD Swaybar, 20"Black Rhino Traverse wheels wrapped in Toyo Open Country ATIIs, Bilstein 5100s on all corners, BAKFlip MX4 Bedcover
    I have the BAKFLIP MX4 bedcover on my 2106 Crewmax. It works wonderfully for my purposes. I also installed an autolock so the tailgat locks whenever I lock the truck, and unlocks when I unlock the truck. As for water leaking into the bed, it is extremely rare for me to find water in the bed of my truck, even after a very heavy rain.
    And ah, the bedrails. My truck came with the bedrails and the cleats for it. BAKFLIP provided me with brackets so I could still utilize my bedrails, even with the low-profile bedcover. A few friends of mine had some reservation as to the strength integrity of the rails when using the drop down brackets, but they are as solid as they were in their original mounted position. 20180209_173236.jpg
  13. Dec 6, 2021 at 5:20 AM
    2mchfun
    I went the opposite route and got a simple rollup Gator to use only when needed to keep something out of the elements. Mounted to bed rails and used factory cleats too. Added D rings to the clamp bolts as well simultaneously. Perfect for keeping the truck bed open unless needed. For security, I can move cargo to the backseat area and leave the cover open so some jackass don't cut it while I am inside at some public place.
    NyCSnEaK likes this.
  14. Dec 6, 2021 at 5:22 AM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    I have the bakflip mx4 and the bakbox. This is my second MX4 as the first leaked right in the middle. They replaced free of charge. I’m happy with it….I guess…. It serves the purpose of why I got it. The second one they sent had some quality issues that I fixed rather than fooling with their warranty process. As for the bakbox. I like it too. But had I thought it through better I would have spent equal money on the ESP underseat storage system.
  15. Dec 6, 2021 at 8:35 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Another plug for Diamondback. I have the SE, and pretty regularly haul heavy items on top of it. It turns the bed into a vault. I’d argue that you won’t find a better company making a better product. SE can have 400# strapped to it, and you can walk around it. It’s water tight, and they offer great accessories to help you get rid of money faster.
  16. Dec 6, 2021 at 8:46 AM
    Kentuckytundra
    I'm waiting on my cross bin to be delivered, came with free diamondback ratchet straps because of black Friday, perfect addition to my HD. I honestly don't see a down side to this cover besides initial investment.
    NewImprovedRon and panicman like this.
  17. Dec 6, 2021 at 10:40 AM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I've had the Undercover Amorflex and just removed it since I bought a Leer cap. It was great with no issues, but just needed a cap more for my bed. Doubt you are close to South Carolina, but if so I'd be happy to make a deal with you. I liked it a little better than some others as it folds closer to the cab for more open bed space and the tougher Line-X coating on the exterior is always a plus:
  18. Dec 6, 2021 at 11:25 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I cannot help you because I’m not sure if I will add one. I had one on my Tacoma years ago and did not use it for it’s purpose. Especially now with my tundra crewmax I can fit a lot of stuff in the back seats and I kind of like having the open bed.
  19. Dec 6, 2021 at 12:09 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    51318537-D3EE-44A5-A612-884D732694E0.jpg 963D7BEC-B9F3-4F6A-AB77-813064542BCE.jpg 98FAFBAF-682C-4A9E-9826-C5C0988F0FA5.jpg Just read your post and snapped these pics of the Bak Rollover (MX4-I think) brackets allow original rails. Never had any issues and I like that you can just roll it all the way and keep the window clear. Been on for 3 years and lots of use.
    Bentarm13 and Crewmax808 like this.
  20. Dec 6, 2021 at 12:14 PM
    timmyKGB
    timmyKGB New Member
    21 black tundra trd pro
    Another lomax here. I had a gator retractable on my f150 and i liked it. Self install was easy and can be moved fully if you need full bed for something
    Jayprestonky likes this.
  21. Dec 6, 2021 at 12:47 PM
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
  22. Dec 6, 2021 at 12:47 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Another Diamondback HD
    panicman and NewImprovedRon like this.
  23. Dec 6, 2021 at 4:28 PM
    CanTundra
    thanks guys i am thinking the undercover mounted to oem rail and will just get the fancy low profile tie downs to be able to have some ties down spots like oem intended.
  24. Dec 6, 2021 at 6:06 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    TreeCat likes this.
  25. Dec 6, 2021 at 6:33 PM
    CanTundra
  26. Dec 6, 2021 at 6:35 PM
    CanTundra
    ok got it so with my factory oem rail i can make it fit on them and also with your link i can find tie downs that will work.. thank you very much
    1lowlife[QUOTED] likes this.
  27. Dec 6, 2021 at 6:40 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Correct, you just fold the rear panel forward, then fold the front panel on top of the rear one and latch it, unlatch the safety straps
    and just remove the whole cover. No tools needed, takes about two minutes.
  28. Dec 8, 2021 at 5:10 PM
    LTundra
    LTundra New Member
    This cover opens up, except for maybe 4 - 5 inches from the very front of the bed, so still lots of room. But there are many different styles.
  29. Dec 8, 2021 at 5:18 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    I'm a big fan of the GatorTrax/Retrax system. I've had mine for 5 or 6 years and its shown no signs of fading, no leaks and no problems. The RetraxPro MX runs about 2,000 bucks but the matte finish and low profile look is great. I wouldn't do it again but I've worked off an extension ladder on it, extremely solid. If you need to haul an unexpected load, slide it back and load up. Easy. I've never wished I'd bought a different one and wouldn't own another truck without it.
  30. Dec 8, 2021 at 6:43 PM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    Truck looks great too, I like the downplayed classy but tough look that’s going on there. And of course the 040/easiest colour factor;)
