Help fitting 295/70r18 tires
Discussion in 'Wheels & Tires' started by mgm16trdpro, Mar 5, 2017.
  1. Mar 7, 2017 at 5:50 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    I'm running this setup without a CMC
    zcarpenter92 and mgm16trdpro[OP] like this.
  2. Mar 7, 2017 at 5:59 PM
    mgm16trdpro
    mgm16trdpro [OP] Certified Modoholic
    Northern NJ
    2016 mgm trd pro crewmax
    Where u been all my life. So then let me ask this. I should be fine then with stock wheel,said tire, and a 1.5 spacer? Where's all the mathematician out there?
  3. Mar 7, 2017 at 6:03 PM
    mgm16trdpro
    Northern NJ
    Joe full lock reverse no rub?
  4. Mar 7, 2017 at 6:03 PM
    joem1cha3l
    Albany, NY
    We exchanged many PMs two days ago
    TheBeast and joonbug like this.
  5. Mar 7, 2017 at 6:04 PM
    joem1cha3l
    Albany, NY
    I rub and had to trim the front fender liner.
  6. Mar 7, 2017 at 6:05 PM
    mgm16trdpro
    Northern NJ
    Lol. I told u my head spinning. I've got so many conflicting reports. I don't know up from down.
  7. Mar 7, 2017 at 6:10 PM
    mgm16trdpro
    Northern NJ
    My bad now I recall, black lugs. Yeah I'm sorry buddy, trust me, a lot of guys could say the same. My head is literally spinning. I just got called a faggot by my fiance for as much time I spent lately on my phone typing away trying to figure all this shit out. Lol
    TheBeast likes this.
  8. Mar 7, 2017 at 6:18 PM
    mgm16trdpro
    Northern NJ
    Remember the pics I showed u, how is it that the 1 guy responded and said his was a +20 and gets little rub at cab mount in full lock reverse, planning a chop soon. That's what gets me confused. U got +12 and say fine, he has +20 with rub. He has a 16 pro just like mine so idk.
  9. Mar 7, 2017 at 6:22 PM
    joem1cha3l
    Albany, NY
    Like I just said, I rub. And I have a larger lift than you.
  10. Mar 7, 2017 at 6:25 PM
    mgm16trdpro
    Northern NJ
    Oh ok then that gotta be difference.
  11. Mar 7, 2017 at 6:29 PM
    mgm16trdpro
    Northern NJ
    So does anyone know for sure with those tires, adding now 2shim,+3 shackle on top stock pro 2inch lift, if I ran stock wheels, am I gonna need chop with 1.5 spacer vs not needing 1.25 verified.
  12. Mar 7, 2017 at 6:32 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The 1.5 spacer will put you at +22. You should clear. Should.
  13. Mar 7, 2017 at 6:33 PM
    mgm16trdpro
    Northern NJ
    Thanks Join, that's what I thought but wasn't positive. I get it neither are u but at +22 I can't see why not.
  14. Mar 7, 2017 at 6:33 PM
    mgm16trdpro
    Northern NJ
  15. Mar 7, 2017 at 6:35 PM
    mgm16trdpro
    Northern NJ
    My vote is 1.5, any other takers
  16. Mar 7, 2017 at 6:37 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Mike, there are more factors you're not considering. MT or AT, wheel brand, UCA, tire brand, alignment, all are factors that make a difference. The difference between rubbing the cab mount and not is usually 1/4-1/2". Any one of these factors can change it by that much easily let alone a combination of all of them. Unless you find someone with the exact same setup, they really can't give you a definitive answer.
    Edit- added UCA
    zcarpenter92, Backslider and PMG like this.
  17. Mar 7, 2017 at 6:55 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    That's my vote too.
  18. Mar 7, 2017 at 6:58 PM
    209TRDPRO
    209TRDPRO New Member
    2016 Tundra TRD PRO
    Just lights for now
    We'll let me share my experience to shed light into your dilemma. I have a 2016' TRD PRO and I am running specifically Nitto G2 Terra Grappler - 35"x12.5 and I remove the front plastic and rear plastic on the front tires area. I just got some nice heavy duty duck tape to cover the fog light wires and I was good. Again non rubbing anywhere forward or reverse. Now off-road hitting big rocks don't know but I'm not that into that so not a problem for me. These G2 ride smooth with minimal noise and I love it. Don't ask me about gas or mpg cause I don't really care7a7074b11045fa3cc09ed2f4c1b3bbf1_7b510810023e0a2e6e57733df2775c6aa52e5074.jpg
    Oh forgot setup. CB +3 in the rear and 2 shim each side for front and CB steering kit for good measure. Nothing else - no CM chop or tire spacers.
    Voyagermike and mgm16trdpro[OP] like this.
  19. Mar 7, 2017 at 6:59 PM
    #49
    mgm16trdpro
    Northern NJ
    I'm leaning 1.5 and if I need cmc bite bullet and do. That's the worst that could happen. I really rather know for sure but I just ordered the shim,shackle steering kit,bushings, and tires, the only thing I'm missing to complete in my eyes is the spacers. Then I'll throw color matched flares along with my linex side steps magnum rt, and my linex diamond back cover hd with ATV . It all on way, just needs me to get time to put on once get. Then I'm gonna try and be done.
  20. Mar 7, 2017 at 7:08 PM
    #50
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Last suggestion. If you're adding shims, measure your height and adjust for the lean while you have it apart.
  21. Mar 7, 2017 at 7:10 PM
    #51
    mgm16trdpro
    Northern NJ
    Measure what ground to center fender?
  22. Mar 7, 2017 at 7:13 PM
    #52
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Center of wheel to fender. If you're taking it all apart to add shims, you might as well fix the lean.
  23. Mar 23, 2017 at 5:37 PM
    #53
    mgm16trdpro
    Northern NJ
  24. Mar 23, 2017 at 5:38 PM
    #54
    mgm16trdpro
    Northern NJ
    Tnx guys. Ur all awesome. I just started a thread saying thanks.
  25. Mar 23, 2017 at 7:18 PM
    #55
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Mike that looks great. So what did you end up doing?
    Nevermind. Saw it on your other thread
