Help door handle replacement
Discussion in '2.5 Gen Tundras (2014-2021)' started by jmdwifi, Jun 16, 2018.
  1. May 13, 2020 at 6:06 AM
    Joelmeyer
    Joelmeyer New Member
    Joel
    2008 Toyota Tundra
    None
  2. Aug 12, 2021 at 11:27 AM
    Hooligan(ret)
    Hooligan(ret) New Member
    2009 Tundra
    Work in progress...
    Over 2 hours into this shit and want to kill someone. Situation is a little different in that I installed the passenger side, all went well. Installed the drivers side handle and lock but the handle never connected and now I am not able to remove the lock cylinder again to take it all apart. Guess I'll remove the Allen bolt and check the rubber plate.
  3. Aug 13, 2021 at 11:23 PM
    Hooligan(ret)
    2009 Tundra
    Work in progress...
    Alright so now I am past killing someone, because after a few days to wrestling and walking away and wrestling I eventually took the passenger side apart as previously suggested and compared the two.
    Passenger side I installed first (all went well) then moved to the drivers side.
    Driver side had a hitch and then some ++++++++
    After being super frustrated I removed the interior panel driver side to get a better look inside
    Someone had previously removed the panel and clear plastic so it may be that my truck had previous problems.
    But the important thing is that what occurred could be your situation too.
    And it's different then the other mentions that I have read so far.
    So to summarize:
    Previously someone has been in behind the interior driver side panel.
    When I followed precisely the steps suggested by Youtube videos my drivers side door opening (by pulling on the handle) did not open the door (the door open function did not operate) but the lock system did function.
    The problem in my situiation may have been caused by the truck being older and more worn out. But here's how I fixed it.
    Unlike the videos of just pulling out the handle and sliding in the replacement handles I was able to successfully replace the handle by reaching in from the interior side and pulling down on the long rod that the handle usually pushes down on BEFORE attempting to insert the replacement handle into the slot as they show in the videos.
    This raised the lever that rides inside the door opener and then once the handle was inserted fully I released the tension I was applying to the downward facing rod and it all worked.
    Another way of saying it may be that the lever that the handle rides on was just to low to engage the fulcrum so by starting to open the door mechanism from the inside it allowed enough room for the handle to be inserted.
    May have been just a lot of tired parts. But now we have one more solution
    Happy to get this past me.
  4. Jan 26, 2022 at 7:06 AM
    adamreinhardt
    adamreinhardt Blk 17 Platinum 4x4
    Seattle
    2017 Platinum in Midnight Black Metallic
    Ok guys sorry but whatever fix everyone used isn’t in this post anymore. I see lots of ppl happy, I see lots of ppl talking about this supposed fix, but it’s not in the thread anymore. Another poster has even asked where it went. Plz someone help, I was replacing handles and the driver door screw won’t thread into the part with the locking mechanism. So annoyed. Help!
  5. Mar 5, 2022 at 5:43 AM
    jalfring
    jalfring New Member
    Julie
    2013 Black Tundra Limited Crew
    We had same frustrating issue. When you remove the handle, you can knock the assembly inside the door "back" into the cavity and then the screw cannot reach. Look for the two small black plastic clips that hold the screw housing interior assembly forward to the sheet metal door panel - pointed to with screwdriver in picture. Those need to be on top of the sheet metal, not behind it or it holds you away from clamping down.
  6. Mar 5, 2022 at 6:03 AM
    adamreinhardt
    Seattle
    Thanks. I actually figured it out finally and should’ve updated the post!
  7. Apr 1, 2022 at 10:27 AM
    Rippyro
    Rippyro New Member
    2014 Tundra 1794 - Sunset Mica Bronze
    Thank God for forums. I was about to lose my shit lol
  8. Jul 18, 2024 at 10:43 AM
    Snarflebits
    Snarflebits New Member
    Sorry to revive this but that screw fell into my door and I can’t retrieve it. I called Toyota and they don’t even know what bolt it is. Has anyone had to order one of these?
  9. May 22, 2025 at 8:36 PM
    19NOlimited
    19NOlimited New Member
    2019 Cement Limited TRD Off Road
    Any luck finding the screw part number? Same thing happened to me.. screw fell in the door
  10. May 25, 2025 at 10:50 AM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Had this problem. Lost the f-I g screw in the door too. Had to take the panel off and fish it out with a magnet. I hated life that day. I found the plastic part in the inside popped off and was not clipped right. That prevented it from lining up properly. Poke your finger in the door and look at the plastic part. See if it’s clipped in.
  11. May 25, 2025 at 10:52 AM
    therealjonwick
    JR
    2019 OR
    9008414006
    I think this is it if you look at the schematic, this one has that lip on it where it fits into the plastic part that holds it.
  12. May 25, 2025 at 10:57 AM
    therealjonwick
    JR
    2019 OR
    Maybe this one:
    9008414005
    I can’t find the schematic I had before to take a look.
  13. Jun 3, 2025 at 12:47 PM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    Guys removing the interior door panel is not that tough. Two screws and a bunch of tabs.
    1lowlife likes this.
