Help door handle replacement
Discussion in '2.5 Gen Tundras (2014-2021)' started by jmdwifi, Jun 16, 2018.
  1. Jun 16, 2018 at 10:49 AM
    jmdwifi
    jmdwifi [OP] New Member
    Fredericksburg VA
    2018 Cement 5.7 Limited with offroad
    All chrome gone, pro grill, KC ditch light and bluetooth wireless controller.
    i am stuck on the drivers handle. I have had two FJ cruisers and these handles are pretty much the same. I replaced those and I have the passenger side done in a few minutes. The drivers side will not line up with the bolt. I have tried until enraged over two days. I’m trying to avoid the walk of shame into the dealer but this is the key side. It can be unlocked with a screwdriver at this point. I even tried to put the ugly chrome one back on thinking maybe the black one was molded wrong. The bolt will not start threading. It seems to be just to the right of the hole or something. Anyone run into this during replacement?
  2. Jun 16, 2018 at 11:14 AM
    jmdwifi
    Fredericksburg VA
    I’ll check that as son I get home. Thank you so much. I hope that’s it.
    Joe Jabudy and SouthBoundSteve like this.
  3. Jun 16, 2018 at 3:07 PM
    jmdwifi
    Fredericksburg VA
    Here is what it looks like. I wiggled it and seems like that is where it should be. How does it look to y’all?
  4. Jun 16, 2018 at 3:16 PM
    jmdwifi
    Fredericksburg VA
    That’s exactly what I just did. Thank you so much. It’s all good now. No walk of shame for me
  5. Jun 16, 2018 at 6:03 PM
    Diverguy
    Diverguy Breathes under water
    Leon
    PA, USA
    2018 Tundra Limited TRD Offroad-Inferno
    Windows tinted, window visors. Bedrug, led bedlights, Nfab nerf step bars, Lund toneau cover, Evo One remote start, BAMufflers 8"
    I had the same problem when I swapped out my chrome for black...it took longer to do the driver's door than the other three put together.
    jmdwifi[OP] likes this.
  6. Jun 16, 2018 at 6:46 PM
    jmdwifi
    Fredericksburg VA
    Lesson learned. Thank god for this forum.
  7. Jun 16, 2018 at 8:55 PM
    offsetplayer2
    offsetplayer2 New Member
    Woods and Fields, NC
    2018 Inferno CM 4WD
    Good to see you got it. :thumbsup:
    If you had been inferno I would have just swapped mine with you so you didn’t have to buy the flat black handle.
  8. Jun 16, 2018 at 9:03 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Steve to the rescue! Nice work buddy
  9. Oct 29, 2018 at 6:03 PM
    Iceman09
    Iceman09 New Member
    2018 Platinum in Blazing Blue
    Undercover Ridgelander Tonneau cover
    This thread saved my butt too. We had the exact same problem on two of four doors. Thanks for the explanation.
    SouthBoundSteve likes this.
  10. Oct 29, 2018 at 6:09 PM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    This happened to me on the weekend. After 1 hr of comparing I realized that the small interior black plastic piece was off. All I did was to push it and it snapped into place. This happens when you try to wiggle the handle piece and the screw is still inside. To avoid this you have to unscrew it all the way and then pull it a little bit before pulling the plastic handle piece.
  11. Oct 29, 2018 at 6:14 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I would be curious to see that actually :rofl:
  12. Dec 9, 2018 at 9:54 PM
    kgb4187
    kgb4187 New Member
    Add another one to the list of people saved by this thread, thank you very much!!!
  13. Dec 30, 2018 at 3:53 PM
    sbbrown333
    sbbrown333 MGM Wrecking Crew
    Blake
    2018 MGM Limited CM 4x4
    So can I start trying to screw the lock piece back a bit to get it to start threading then push the other part of the handle in place? I’ve tried everything and can’t get it
    OR18TRD likes this.
  14. Dec 30, 2018 at 6:02 PM
    rnssncman
    rnssncman Purveyor of the Good News
    2019 Tundra Limited White
    I had an issue of the driver door. Took 20 minutes to figure it out. Then 20 minutes to do the other 3 doors total. Glad it worked out for you.
  15. Jan 19, 2019 at 8:33 PM
    Joe Jabudy
    Joe Jabudy New Member
    Joe
    2016 Tundra SR5 Double Cab
    I was ready to go nurs until I found this. You guys rock!!! Thank you so much!!!
  16. Feb 21, 2019 at 8:44 AM
    2015TundraCrewXP
    2015TundraCrewXP New Member
    Charles
    SC
    2015 Black Tundra Crew Max XP
    20" blacks wheels, trd pro grille, color matched fender flares and handles, steel rear bumper, black leather, bakflip cover, spyder led headlights
    10 min job. Plenty of YouTube vids
  17. Apr 20, 2019 at 5:13 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    Alright so I’m having the same problem I’ve manipulated the inside plastic multiple ways and nothing is working any tips?
  18. Apr 20, 2019 at 5:22 PM
    jmdwifi
    Fredericksburg VA
    Look at this whole thread and look at it again. I recently had to refer back to it when the skin of my handle came unscrewed. Fought it for an hour, took a break, looked up this thread again and it was in in a few minutes with the door back together.
  19. Apr 20, 2019 at 5:38 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Update:
    After researching for a while and almost loosing my mind I have found the issue and were all done.:thumbsup:
    Sas and NewImprovedRon like this.
  20. Apr 20, 2019 at 5:51 PM
    Eric104
    Eric104 New Member
    Eric
    2018 Crewmax
    I had the same problem with my drivers door. We fought it for a while then the screw fell out and I could finally see what was wrong. Used an awl to realign the tab that the screw goes in, put the screw back in and Bam the handle was installed.
  21. May 13, 2019 at 1:33 PM
    BradWils
    BradWils New Member
    7” Procomp lift Procomp MX2.75 Coilovers SPC UCA’s Plus 3” Rear Shackle 35x12.50 R20 Duratracs Pro Com 20x9 0 offset rims Bora 1.5” wheel spacers OEM LED Headlight and Fog conversion LED interior lights TRD Pro Grill Borla Touring true dual exhaust AFE Magnum Force Stage 2 SI Pro Intake Bushwacker Fender Flairs Colour match door pulls, mirror caps and hood buldge Weather Techs Remote Start Factory Match Tint Toyota Bakflip Tonneau cover Line-X
    Thank you thank you thank you... thought I was gonna be driving around with no handle.. after 30 mins getting poured rain on I found this post... reached my fingers inside and pulled till I heard the snap.. threaded right in! Man this site is a life saver! Much appreciated
  22. May 13, 2019 at 2:38 PM
    JNorman84
    JNorman84 New Member
    Jesse
    2019 Tundra TRD 4X4 Limited
    Fox 2.5 coilovers Camburg UCAs Fuel 20X9 SHOK Nitto G2
    Doing handle swap on my crewmax Wednesday, it's starting to sound like I should do the drivers door FIRST then the rest will be easy ;)
    NewImprovedRon likes this.
  23. May 13, 2019 at 3:14 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    If ever stick refer back to this thread. It’s a lifesaver
    BradWils and JNorman84[QUOTED] like this.
  24. May 21, 2019 at 8:27 AM
    JNorman84
    Jesse
    I referred to this thread when I swapped my handles and it was a life safer. I did notice a unique problem that I wanted to address for future swappers. The rubber gasket seal on two of my handles slipped off, and when I went to 'seat' the new handles in place, the gaskets slid forward out of place. Some trusty loctite to the rescue.
  25. Jun 30, 2019 at 7:46 PM
    jpine707
    jpine707 New Member
    San Jose, CA
    2017 Limited CM 4x4 MGM
    Thanks. Lock cylinder was also misaligned for me during my test install. Snapped back the black plastic piece and able to re-install. Thanks for the help.
  26. Jul 4, 2019 at 5:56 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    What color black are you all getting? Classic, attitude or matte textured?
  27. Sep 14, 2019 at 9:54 PM
    mountainpanda
    mountainpanda New Member
    2016 Super White SR5 TRD 4x4
    I don't even want to admit how long I've been messing with this, but I just found this thread and 30 seconds and one pop later I'm good to go...thank you.
    SouthBoundSteve, OR18TRD and kgb4187 like this.
  28. Feb 16, 2020 at 5:58 AM
    JayCO
    JayCO New Member
    I’m running into whatever the issue is, but it seems the solution posted by “Steve” is no longer in this thread. Can someone clue me in???
  29. Apr 1, 2020 at 12:05 AM
    kgb4187
    kgb4187 New Member
    You have to make sure the plastic in the door didn't shift
  30. Apr 8, 2020 at 2:37 AM
    Kanekz
    Kanekz New Member
    Levi
    2019 1794 SC
    Same thing here! 1.5 hrs of wanting to break this shit. Read thread 1 min. Thanks guys!
