HELP DIAGNOSING POPPING SOUND!!!
Discussion in 'General Tundra Discussion' started by zachzap361, Aug 12, 2021.
  1. Oct 12, 2021 at 3:51 PM
    TXTundra2722
    2015 Black Tundra
    I got mine figured out and fixed in about 30 minutes. Mine ended up being the driver side, upper spindle bolt. It was easily observed after jacking up the front like I recommended above. Fingers crossed that yours is an easy fix. :thumbsup:
    NueveTundra and zachzap361[OP] like this.
  2. Oct 12, 2021 at 4:22 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If it started right after the alignment, first thing I’d check are the alignment cam bolts. Those things need to be torqued to like 200lbs and the alignment shops never tighten them enough.
    JLS in WA and zachzap361[OP] like this.
  3. Oct 13, 2021 at 7:03 AM
    zachzap361
    zachzap361 [OP] MEAN GREEN MACHINE
    Zach
    San Antonio
    2010 Green Tundra CrewMax
    Toytec Aluma 2.5 Coilovers and Toytec rear shocks, Method NV 17", Nitto Ridge Grappler 35", RCI Skid Plate, Dirtydeeds Dual Dumped Exhaust, Volant Cold Air Intake and Throttle Body Spacer, SDHQ Ditch Mount Brackets, Rigid Blackout Spot Lights, Stampede Fender Flares, N-Fab Nerf Bars, Morimoto Fog Lights, 55 watt HID's, AJT Design Climate Knobs, Ellis Precision Shift Knob, Coverking Seat Covers, Husky Floor Liner's,Demello Off-road Bumper, Rigid and Baja Designs Lights, Jomax ABS Sensor covers
  4. Oct 13, 2021 at 7:12 AM
    zachzap361
    Zach
    San Antonio
  5. Oct 13, 2021 at 7:17 AM
    zachzap361
    Zach
    San Antonio
  6. Oct 13, 2021 at 2:23 PM
    TXTundra2722
    2015 Black Tundra
    Have you checked yours yet?
  7. Oct 13, 2021 at 2:36 PM
    zachzap361
    Zach
    San Antonio
    The spindle bolts are good and tightened up with the JBA UCA’s
  8. Oct 13, 2021 at 2:36 PM
    zachzap361
    Zach
    San Antonio
    Check out the videos above and that’s the problem, loose CV
  9. Oct 13, 2021 at 2:54 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    I had a similar issue with pooping while going into reverse , sometimes at full lock. I spent hours of every other day just going over every thing checking and checking. I eventually developed a intermittent wheel shake that would shake the wheel very badly. after the months of dealing of dealing with this issue I started taking it in to the dealer and a few other places. no one could figure it out , months go by and just the other week the intermittent wheel shake came back so bad on the hwy I pulled over at the next exit and started going through the front end there. what I found was my left front CV axel was binding an releasing (pop) and would come loose (wheel shake) but then it would tighten back up going away. when I rechecked it at home it seemed to be back in the tight position so I started turning the wheel and checking it every angle and sure enough I confirmed up the slop it had in the upper CV for up and down play. this issue was so illusive that it wasn't found by 7 master techs. I dealt with it building up for roughly 2 years till I got my conclusive answer , so I recommended checking every bushing joint and checking the CV up and down play in every position of the tires being turned and even then moving the vehicle forwards or backwards to rotate the axle and rechecking CV up and down play.
    after doing both my CVA's the issue I had went away also noticed my steering wasn't so tight while turning or making a u turn and my braking distance decreased and my random once in a blue moon pop went away.
    hope some of this info helps out on getting to bottom of it , also how is your front tire tread ware?
    zachzap361[OP] likes this.
  10. Oct 14, 2021 at 12:01 PM
    zachzap361
    Zach
    San Antonio
    @TXTundra2722 @NueveTundra So I went to the shop today here in San An, the shop I typically take it too (Anthony's Planet Pickup). I talked to the guys, specifcally Chris who has always been helpful and showed him the videos and explained the issue. He said, and its his opinion that the tolerance in the CV shown in the video https://youtube.com/shorts/5OokSRTEqoc?feature=share is COMPLETELY NORMAL and that is should have some play in there. Personally, and I am no expert but I feel like that is false based off of conversation with @Coachbuilder1 and a few other people. I am still scheduled to take it in next friday either way and they are going to look at it. I even threw the possibility of it being the spindle joint like @TXTundra2722 suggested and they said it could be that so they are going to check it out.
    I just really feel like it is the CV cause @NueveTundra had similar instances where it seems the same for me.
  11. Oct 14, 2021 at 12:03 PM
    zachzap361
    Zach
    San Antonio
    @NueveTundra I know you mentioned a wheel shake that was "intermittent" my question to you is how bad or aggressive was it cause at times this does happen such as today but its very minimal in my opinion, nothing that would scare me or make me think that I need to pull over.
  12. Oct 14, 2021 at 12:14 PM
    NueveTundra
    Planet Earth
    My wheel shake was first maybe twice a month that was just a little over common wheel vibration but eventually turned into a good violent 1/4" shake back an forth that was triggered from slight road vibrations but would go away during corning or other road conditions it eventually caused cupping in front tires witch made it worse till I got a tire rotation then it went away. For a few days and came back in small just over vibrations to shake till it got really bad. Somedays it wasn't there at all somedays it was annoying and other days it felt like full blown both wheels are loose and about to fall off. One spot I noticed it loved to start shaking was 60mph with hard acceleration letting off to rest at 85mph on the highway it would really love to start the shake.
  13. Oct 21, 2021 at 6:59 PM
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    Same exact popping sound on my 2.5 lifted 15 Tundra. Changed CB steering ends after performing the 9oclock-3oclock tire wiggle and had play. I replaced the CB steering ends with another brand new set from Mr Ekstrom. Popping noise persists and is very annoying. Ive researched and read and read. Your truck sounds exactly like mine and how you replicate the noise is how mine behaves also. Im keenly interested in what you find out. Thanks for your post.
  14. Jan 13, 2022 at 5:57 PM
    ThisGuy03
    ThisGuy03 New Member
    Las Vegas, NV
    ‘17 CM LTD TRD 4x4 MGM
    King 2.5s..TC UCA..35x12.50-18 M/T..AMP Steps
    Another reason I finally signed up here. This is the exact same sounds mine makes. It started after putting Kings 2.5s, TC UCA, new spindles with gussets, and replacing BOTH driver and pax side axles. This all done at 50k miles. That popping, almost metal fatigue popping, is so very annoying and embarrassing. I don’t know what to do. My axles were purchased as assemblies with the CVs already installed and ready to go. I’ve checked that same area you did for play, mine has some VERY minor movement, but not as much as what you found. Not nearly that much. I thought it was my lower control arm cam bolts/sleeves/bushings that I am almost ready to take it in and have the LCAs and LBJs replaced. Have you found anything since Oct when this thread was going off? Did you ever fix it? If so, how?
  15. Jan 19, 2022 at 8:21 AM
    ThisGuy03
    Las Vegas, NV
  16. Jan 19, 2022 at 8:41 AM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    My 2020 makes all kinds of noise from the front end, I think the passenger side. Only things I've done to it is TRD front sway bar, AMP Powersteps, and @Classy63 aluminum cat plates. I guess the first thing to do would be to remove the cat plates and see if it persists, but those looked like such a PITA to install, I'm kind of averse to removing them.
  17. Jan 19, 2022 at 9:31 AM
    ThisGuy03
    Las Vegas, NV
    If you haven’t changed any suspension components, it could be your cat plates or skid plate?
  18. Jan 26, 2022 at 8:11 AM
    ThisGuy03
    Las Vegas, NV
    Took mine into the dealer Monday. Unable to reproduce the sound without me, and with me driving lol. Terrible!
    AggiePhil likes this.
  19. Jan 26, 2022 at 8:40 AM
    #49
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    :popcorn:
    Same issue here… Toyota wanted atleast 4 hours at 200 an hour to POSSIBLY diagnose it.
  20. Jan 26, 2022 at 8:56 AM
    #50
    NueveTundra
    Planet Earth
    Just a update, since its been a few months now, my popping noise did indeed go away with doing my CVs :yay:, and my wheel shake went away for a month. But it seems as I Fix one issue another one lets loose as Wheel shake has returned but its no longer a center wheel feeling but a lower wheel feeling. :pout: I know I need bushings, but bills and moving expenses's are stacking up. :rain: I'm due for a front end rebuild since everything is 7/10ths gone and fixing one just makes the another get more of the stress still it shows.:facepalm:
  21. May 9, 2022 at 6:13 PM
    #51
    BettyWhite20
    BettyWhite20 New Member
    2020 DC SR5 4X4
    2020 SR5 Double Cab with Bilstein 6112/5160 front at 1.9" with .250" shims for 2.5" front and CB +2 Shackles in the rear. 24k miles and now I'm hearing a popping sound in reverse after the lift was installed at 23,715.
  22. May 9, 2022 at 6:16 PM
    #52
    ThisGuy03
    Las Vegas, NV
    Mine needed a realignment after about 6 months from lift install and initial alignment. Suspension settled in and a after second alignment all the pops went away
    BettyWhite20[QUOTED] likes this.
  23. Sep 30, 2022 at 2:43 PM
    #53
    DondeContente
    DondeContente New Member
    Nathan
    2014 Tundra
    Hey @zachzap361 any update on your truck? I'm having the same issue, did you replace CV's ?
  24. Dec 21, 2022 at 1:19 PM
    #54
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Bump. Just started having this issue after wheeling the four peaks trail here in Arizona. Went a little faster than usual but nothing too crazy. I plan on retorqueing the skid tonight and see if that helps. Fingers Crossed!
  25. Dec 22, 2022 at 1:39 PM
    #55
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Just fixed this issue on my truck. Turned out to be the two rear bolts on the TRD skid. They became loose after wheeling over the weekend. I re-torqued to 38 ft. lbs and all is well.
  26. Dec 22, 2022 at 2:09 PM
    #56
    centex
    centex New Member
    Mine has a similar pop but only does it one time after sitting stationary for a bit and then turning. Doesn’t matter direction. It sounds like a loose plate but I just tightened everything and it’s good. Can’t chase a noise that only makes sound one time a day.
  27. Jul 9, 2023 at 5:51 PM
    #57
    woodlandFF
    woodlandFF New Member
    2019 SR5 Cement Tundra CrewMax 4x4
    Black Rhino 20s
    I know this is an old thread but any updates on this? I'm starting to notice this clunking noise in full lock to the left in forward and reverse over a hump or up/down an incline. This happens in our 4runner with a 2.5 Icon lift with UCAs and the Tundra with 2.5 bilsteins. Will look at CVs and tie rods and skids
    lukedias00 likes this.
  28. Feb 18, 2024 at 4:34 PM
    #58
    lukedias00
    lukedias00 New Member
    2014 Tundra 4x4 Off-Road Limited
    Same. I have moog tie rod inner and outers. Pop went away for a little while then came back
  29. Feb 18, 2024 at 6:03 PM
    #59
    centex
    centex New Member
    Over a year later and the sound persists. Truck still driving so just gonna let it ride for now. Got a 2100 mile road trip in June so will be doing new upper and lower arms and alignment and see if that helps.
