Help a Newb with first Mods
Discussion in 'General Tundra Discussion' started by HOTDAM, Jul 29, 2017.
  1. Jul 29, 2017 at 12:19 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    CMC = cab mount chop
    HOTDAM[QUOTED][OP] likes this.
  2. Jul 29, 2017 at 12:55 PM
    With proper wheel offset.. example...my rims are +12... you can avoid CMC mod and run 295's but still need to move front fender liner forward which is covered on this forum. I have CMC plates and will eventually do the mod for even more clearance.
    zcarpenter92 and HOTDAM[OP] like this.
  3. Jul 29, 2017 at 1:28 PM
    chphilo
    chphilo Tundra addict
    Western PA
    OME 614 with aal in the rear here and I love this set-up. Flawless for 3+ years, and I do not expect any problem for many more years to come. Maintenance-wise, it's as maintenance free as can be.
    If you get OME Dakar leaf pack (full leaf spring replacement), expect 2.5 inches of lift in the rear. With OME 614, I got 3.5 inches of lift in the front. With aal (1.5), I am about dead even. So with Dakar springs, you will probably get about 1 inch rake.
    HOTDAM[OP] likes this.
  4. Jul 29, 2017 at 1:59 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Oh yeah. Just get your spanner wrench that's provided w/ the lift and crank.
    It's probably easier to take the wheels off to do so.
    CMC is a part of the frame that sticks out an inch or so in the wheel well.
  5. Jul 29, 2017 at 8:49 PM
    HOTDAM
    HOTDAM [OP] Feeling Dangerous
    2013 Crewmax 4x4
    Lots of great info.
    Also what do guys do with their old stock wheels?
  6. Jul 29, 2017 at 9:14 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I have a 3" Toytec coilover and I rub in reverse @ full lock with Black Rhino Warlords and 285/65r18s. You will almost surely have worse rubbing with a taller and wider tire.
    I am considering moving to 295/70 too, so if you go this route please let us know how it works.
  7. Jul 29, 2017 at 9:44 PM
    HOTDAM
    2013 Crewmax 4x4
    Can you post a pic if your truck? Would like to see set up. And I will for sure post pics after.
  8. Jul 30, 2017 at 1:57 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Welcome..........Depending on your travel trailer size/tongue weight, you will want to go with rear airbags. Firestone/ride-rite is my choice. Also make sure you use a good quality W/D (weight distribution) hitch in conjunction with your bags. If doing any off-roading with suspension articulation, airbag cradles are a must. Good luck with all.......
  9. Jul 30, 2017 at 2:52 PM
    HOTDAM
    2013 Crewmax 4x4
    Thanks CM Lenny. Once lifted won't the airbags just raise the back end higher? or is it more of leveling due to the trailer dropping the back end?
    Dustydirt19 likes this.
  10. Jul 30, 2017 at 3:28 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Correct. Keeps it level under load
  11. Jul 31, 2017 at 9:51 PM
    HOTDAM
    2013 Crewmax 4x4
    @Sean266 what size tires you have on?
  12. Jul 31, 2017 at 9:52 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    I believe he has 305's
  13. Jul 31, 2017 at 9:53 PM
    35"
    305/70/18
    Dustydirt19[QUOTED] likes this.
  14. Jul 31, 2017 at 9:55 PM
    HOTDAM
    2013 Crewmax 4x4
    Thanks. Truck looks good.
    T-Rex266[QUOTED] likes this.
  15. Jul 31, 2017 at 11:54 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Go fox and don't look back
    JH5370, trdlife and Wvmoonshiner like this.
  16. Aug 1, 2017 at 10:37 AM
    jfrd30
    jfrd30 Lead, Follow, or Get the Hell Out of My Way
    2013 TRD Tundra
    Hey bud, If you get a descent equalizing hitch with the trailer you're planning on purchasing, you don't need any suspension mods. That is unless you plan on taking your anvil collection to the swap meet and/or anvil enthusiast show in Amarillo, then you may need to have some work done on the suspension. You can pick up a brand new hitch from U-haul for a fairly descent price or visit these guys and they'll get you hooked up. etrailers.com When you set up your rig, make sure to take your time and read the freakin instructions. You'll need to take measurements and shit, but it is definitely worth it in the end. If you don't want to mess with all that, have a local RV shop do all that for you. Of course you'll pay more and you won't have the satisfaction of knowing you did it yourself, but it's a lot less of a hassle.
  17. Aug 5, 2017 at 10:28 PM
    HOTDAM
    2013 Crewmax 4x4
    Did anyone also upgrade their UCA's when they got the lift? Hearing it is suppose to really help with the alignment.
    Eclipsed & Floating likes this.
  18. Aug 8, 2017 at 7:49 PM
    HOTDAM
    2013 Crewmax 4x4
    How do you like the ride on these for street driving?
  19. Aug 8, 2017 at 7:50 PM
    #49
    HOTDAM
    2013 Crewmax 4x4
    how do you like the ride on these for street driving?
  20. Aug 8, 2017 at 8:09 PM
    #50
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    DEFINITELY
  21. Aug 8, 2017 at 8:23 PM
    #51
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Check out ICON for your shocks/springs and Firestone bags.
    That's what I'm running...
    Bags will certainly save some wear on the springs and are great for towing. Just need abt 5# for normal driving. You can add air for towing, but let it out when your done or your ride can get a little bouncy.
  22. Aug 9, 2017 at 5:56 AM
    #52
    The ride is fine although somewhat stiffer than OEM of course.
  23. Aug 9, 2017 at 7:03 AM
    #53
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    FYI the Bilstein 5100's will give you a front lift of about 2 1/4 inches. That should be enough to stuff the 295/70R18's you are looking for. I'd do the 5100 rears and shackles to lift the rear if you decide that route.
