Help a Newb with first Mods
Discussion in 'General Tundra Discussion' started by HOTDAM, Jul 29, 2017.
  1. Jul 29, 2017 at 10:36 AM
    HOTDAM
    HOTDAM [OP] Feeling Dangerous
    2013 Crewmax 4x4
    I have spent weeks looking at Lift options for my truck and having no real knowledge on the subject the struggle is real.
    Here is what I am planning on so far.
    Toyo AT2's 295/70/18
    Black rhino warlord wheels18"
    Ionic black 51 series running boards.
    I originally was thinking a 3/1 leveling kit with spacers but after reading about towing and quality/ride/longevity I am now torn. Now leaning towards some billstein 5100's in front and no idea about back.
    Help a brother out.
    Some questions I have.
    What is stock stance on 13 crewmax? Will 2.5 lift in front level it?
    Will billstein 5100 go higher than 2.5 inches?
    Do I do billstein 5100's in front and rear or just front and spacer or shackles in back?
    Any advice is welcome and thanks.
    GNTundra and Jsena like this.
  2. Jul 29, 2017 at 10:39 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Toytec boss kit or radflo if you only wanna go 3 in
  3. Jul 29, 2017 at 10:39 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome from :canada:
    :worthless:
  4. Jul 29, 2017 at 10:42 AM
    If you want to save a few $ and still want 3" lift and be somewhat level, the OME setup is nice. Mine gets a workout almost every weekend now until end of hunting season this fall. Works quite well for me. Call ToyTec. Tell them your budget. ToyTec says 2.5" but easily 3". Stay away from spacer lift/level unless you never go off the road.
  5. Jul 29, 2017 at 10:49 AM
    206Tundra
    206Tundra New Member
    Black Diamond, WA
  6. Jul 29, 2017 at 10:50 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  7. Jul 29, 2017 at 11:07 AM
    Go with a Toytec BOSS kit. I have mine cranked to 3.5" here
    jfrd30, HOTDAM[OP], Law323 and 2 others like this.
  8. Jul 29, 2017 at 11:10 AM
    Bienvenidos de Tejas!...no pics of your ride?...no bueno!
    Jsena likes this.
  9. Jul 29, 2017 at 11:14 AM
    HOTDAM
    2013 Crewmax 4x4
    Thanks guys. So if I do 1 inch in the back and am loaded up will it still set level? Plan on buying a travel trailer in a year and want to try and sit level with it on.
    Jsena likes this.
  10. Jul 29, 2017 at 11:14 AM
    HOTDAM
    2013 Crewmax 4x4
    Slow learner here.
    jfrd30 and Law323 like this.
  11. Jul 29, 2017 at 11:14 AM
    Grumpy Uncle
    Pat
    CO
    I'll second the OME lift. I had it on my 99 4Runner, 00 Disco and 10 Tacoma. I plan on getting it for my Tundra as well.
    Jsena and Black Wolf like this.
  12. Jul 29, 2017 at 11:17 AM
    A very decent quality budget friendly setup. No complaints here either.
  13. Jul 29, 2017 at 11:18 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Welcome from Vegas..
  14. Jul 29, 2017 at 11:20 AM
    HOTDAM
    2013 Crewmax 4x4
    Is there any maintenance needed with these lifts over life of truck? Plan on keeping the truck until it dies.
    zcarpenter92 likes this.
  15. Jul 29, 2017 at 11:21 AM
    I have an Add-a-leaf on the rear springs. Truck sat level with no load. Added nuke proof ToyTec shackles to regain some rake. Truck rides level with a decent load in the back. Adding air bags at some point.
  16. Jul 29, 2017 at 11:22 AM
    Not really. Just inspect them occasionally..
  17. Jul 29, 2017 at 11:25 AM
    TXMiamiFan
    Jose
    If you go with ToyTec they recommend cleaning the springs and shocks at the same time you do oil changes. That's it.
    T-Rex266 and Law323 like this.
  18. Jul 29, 2017 at 11:31 AM
    I pressure wash mine almost every weekend at my local car wash. Actually the whole undercarriage...Old habit..Can't hurt...
    TXMiamiFan[QUOTED] and T-Rex266 like this.
  19. Jul 29, 2017 at 11:33 AM
    Grumpy Uncle
    Pat
    CO
    ^^^^ What he said. Then every spring I will spray the OME rear spring pack with a rust inhibitor and a little graphite spray on the bushings (ya I'm a geek)
    Black Wolf likes this.
  20. Jul 29, 2017 at 11:37 AM
    I do plan on losing my OEM springs and AAL at some point and complete the setup with the OME leaf pack.
  21. Jul 29, 2017 at 11:38 AM
    HOTDAM
    2013 Crewmax 4x4
    What would the leaf pack do?
  22. Jul 29, 2017 at 11:39 AM
    HOTDAM
    2013 Crewmax 4x4
    On another post I saw people talking about rubbing and having to hack at the CMC or something like that. Guessing any decent shop will fix rubbing it it's an issue.
  23. Jul 29, 2017 at 11:41 AM
    HOTDAM
    2013 Crewmax 4x4
    Also with these kits that are adjustable does anyone actual adjust them from time to time or just a benefit that is not really used?
  24. Jul 29, 2017 at 11:49 AM
    I wash mine with every wash. I just spray it down.
  25. Jul 29, 2017 at 11:50 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You might not need to do that since you're going a 34" tire. Just a skid plate trim and mud flaps removal. Should be golden.
    It's a good benefit to have but not needed. It helps with truck lean and if you're in the mood to go higher or lower, you can always crank it to your liking.
    I'm cranking mine up to 3.5 when I get bigger tires.
    zcarpenter92 and Black Wolf like this.
  26. Jul 29, 2017 at 11:53 AM
    TXMiamiFan
    Jose
    That's what she said.
    Law323 and Black Wolf like this.
  27. Jul 29, 2017 at 11:53 AM
    My stock springs are 10 years old now and will have to be replaced at some point. The OME spring packs give you rear lift to complement the OME front setup. My AAL and shackle combo suffices quite well for now.
    Law323 likes this.
  28. Jul 29, 2017 at 12:00 PM
    Grumpy Uncle
    Pat
    CO
    On my Tacoma I had a true lift, maybe that is an inaccurate description. With the OME spring pack there was no need for a 1"block or add a leaf to lift the rear. It also seemed to do well on and off road and it hasn't sagged in the rear yet. Pricier yes, buy once cry once.
  29. Jul 29, 2017 at 12:04 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Once you get them to the height you want, you really won't touch the height until you make some changes. But is really good to adjust for the Toyota lean.
    zcarpenter92 and Law323 like this.
  30. Jul 29, 2017 at 12:10 PM
    HOTDAM
    2013 Crewmax 4x4
    Is this something you can do easily with a turn and a took or take of wheels etc?
    What is the CMC?
