hello from Falken Tires
Discussion in 'Wheels & Tires' started by Falken QA, Sep 27, 2021.
  1. Sep 13, 2022 at 1:19 PM
    #151
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    Man that sucks, sorry it happened. I really want to upgrade the size of my Wildpeaks but not this way! @Falken QA have you seen this occur often? Also noticed the weight of the TRD Pro OE tire being 38lbs, big jump in weight to E rated...
  2. Sep 13, 2022 at 1:30 PM
    #152
    ALEON
    ALEON New Member
    Leon
    2022 Toyota Tundra TRD PRO
    Getting ready to go to 35” Toyo’s with a Westcott lift… 2 1/2 front 1” in rear. Also adding a Carvin exhaust system. Not comfortable with the Falken’s so much anymore. Had good look for 9 years with the Toyo’s on my 2012 Tundra. Also need it be a little for sound relevant. Compared to the flowmasters on the old tundra
  3. Sep 13, 2022 at 1:47 PM
    #153
    Falken QA
    Falken QA [OP] New Member
    This result happens when the tire is ran flat or on low pressure caused from a loss of air. The primary cause of failure is unknown at the moment and we are awaiting a response from Aleon so we can find the main cause of failure.
    @ALEON . we sent you a PM. Can you check in and provide feedback so we can come resolve the issue for you.
  4. May 29, 2024 at 11:13 AM
    #154
    damsamuel
    damsamuel New Member
    Huntsville, AL
    2022 Tundra SR5 TRD Sport 4x4
    do you have any pics of the H/T02s, even better if its a 275/70r18?
