hello from Falken Tires
Discussion in 'Wheels & Tires' started by Falken QA, Sep 27, 2021.
  1. Dec 9, 2021 at 10:13 AM
    #91
    sequoia007
    sequoia007 New Member
    2007 Toyota Sequoia 4WD Limited
    Hi all,
    I just bought 5 Falken Wildpeak AT3W LT235/80R17 Load E's for my 2007 Toyota Sequoia (1st gen).
    These pizza cutters / skinnies are about 32x9 -- almost 1.5" taller and 1.5" narrower than the stock size. I'm very happy with the tire choice & everything fit perfectly on stock suspension with no rub or cutting, and even the spare tire fits perfectly underneath with more vertical clearance than the stock 265s.
    Now for the bad news....
    I just noticed that the date codes on at least 3 of the tires are about 17 months old. I haven't checked the spare but I'm assuming it's also the old date.
    WMDV2121 - May 24, 2021 (China)
    WMDV3020 - July 20, 2020 (Thailand)
    Spare (Date/Country unknown)
    The Falken warranty shows coverage period "within six years of date of production (for 2021 produced and newer)." I only drive ~4,000 miles/yr so I'm concerned about the 1-1/2 year loss of warranty time on these tires.
    I put 33 miles on the tires since I had them installed yesterday at America's Tire (aka Discount Tire).
    Hoping Falken support or someone on the forum has some experience or advice on whether I should try to exchange these for a fresher set or if it's fine or not worth the hassle.
    Thanks in advance!
    Ben
  2. Dec 9, 2021 at 10:23 AM
    #92
    PermaFrostTRD
    Northern NY
    That's roughly 350 miles a month or a tank of gas a month. I'd say you'll know if the tires are good to go or not by your first year with them. And still under warranty. If you're that concerned, exchange them. Just about everyone on this forum is a Falken fan if not from direct experience, certainly they know someone with a positive experience. You should be fine.
  3. Dec 9, 2021 at 10:30 AM
    #93
    Falken QA
    Falken QA [OP] New Member
    Hello Ben,
    We will honor our 6 year manufacturer warranty from date of purchase as well, though this is informal. So if there are any manufacturer related issues like separations or dry rotting that occurs, say late 2026, we'll still be able to prorate the tires based on your purchase date of 12/8/2021.
    You have every right to exercise the 30 day trial period on the tires, with your return reason being "old tires." The 30 day trail period allows any type of return (smell, ride, noise, traction, etc). However, it only covers the tire cost, so by getting another set, you'll be paying for another round of labor & taxes.
  4. Dec 9, 2021 at 1:34 PM
    #94
    sequoia007
    I didn't want to unnecessarily create hassle & cost (for either side) so I'm glad I asked & got the reassurance I was hoping to get.
    Thanks to PermaFrostTRD & Falken for the quick replies!
    [EDIT]: Would you recommend a different tire pressure from the factory recommended 32psi (F/R)? (With standard weight -- no mods)
  5. Dec 10, 2021 at 8:24 AM
    #95
    Falken QA
    Since you are running a non-OE tire size, please provide your OE tire size so I can get a baseline. I'm assuming the OE pressure is 32 all around?
  6. Dec 10, 2021 at 8:29 AM
    #96
    sequoia007
    OE size is 265/65/17. Yes, 32psi front & rear.
  7. Dec 10, 2021 at 10:38 AM
    #97
    Falken QA
    OE size supported 2260 lbs per tire. To get that same load capacity, you'll inflate your LT235/80R17 to 50 PSI.
    sequoia007[QUOTED] likes this.
  8. Dec 12, 2021 at 5:39 AM
    #98
    texascolt45
    texascolt45 New Member
    mike
    future
    none
    3 set of falkens I've bought so far.great service from my local off-road shop.buy bread and household supplies at Wally World,definetly not tires.
    Falken QA[OP] likes this.
  9. Dec 12, 2021 at 2:18 PM
    #99
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Put the new Wildpeaks to the challenge and am very impressed with the performance
  10. Dec 27, 2021 at 2:34 PM
    #100
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    checking in to see if you ever confirmed if 285/75/18 on stock off-road rims (+60) with SPC uppers will fit?
  11. Dec 27, 2021 at 2:40 PM
    #101
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Psi for 315/70/17 load e on a 2016 tundra?
  12. Dec 27, 2021 at 2:48 PM
    #102
    2mchfun
    Actually I bought some +30 rims and sold my stock trail rims. That said, It looks like they may have worked. I know it would have been really close. I changed my plan mainly because I found some low profile flares that I really like and a little more width on the footprint is a good thing IMO. If you really want to try without a big cost, maybe throw down a deposit to borrow a used tire from a used shop, have it mounted and check it out. That is what I would have done had I not found these flares. 20211120_085609.jpg
    Seafury and justfortun[QUOTED] like this.
  13. Dec 27, 2021 at 3:06 PM
    #103
    justfortun
    James
    Boston
    2016 SR5
    Ty
    +30 is probably what I’d go with too. How do they sit with the flares?
  14. Dec 27, 2021 at 3:42 PM
    #104
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    Robert,
    I can't believe I missed this tread.
    My wife's Lexus GX470 needed some tires about this time a couple of years ago. (12/23/2019) I was able to get some FN Wheels from Dustin and these AT3w tires at the same time. All I can say is that I am more than stoked on tire wear, performance, handling and looks!
    These AT3w's are incredible and will continue to buy these awesome tires moving forward. The set I did purchase at Wally world for pretty darn cheap. I believe I got these for $120ish in 2019. And they were made in the U.S.A. (note: just below where the white "O" is on the tire. You can see "Made in U.S.A.)
    Are stickers still available?
    O.S.T.
    TelemarkTumalo and Seafury like this.
  15. Dec 27, 2021 at 3:50 PM
    #105
    2mchfun
    Yw! Sits pretty good, very happy! Not poking out putting other vehicles and windshields at any increased risk. The flares provide about an extra 3/4", but they also make the wheel wells look "finished or complete". They also provide some door ding and shopping cart protection too.
  16. Dec 28, 2021 at 6:59 AM
    #106
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Late to the party but I have 2 sets of Falken Wildpeak A/T3W on order for Wednesday install.
    Stock wheels with 3in front lift and SPC UCA's.
    Stock 275/55R20 (32x10.8R20) Yoko craplander AT's.
    Ordered 275/60R20 (33x10.8R20)
    And 275/65R20 (34x10.8R20)
    Hoping the 65R20's will clear my UCA, if not I'll go with the 60R20 until I decide to waste money on wheels just to get a reasonable offset. (Thanks Toyota)
    I'm super excited!
    I do wish these did not look so much like Nitto Terra Grapplers.
    I had those on my 98 4runner, road great, lasted all of 20k miles.
    Regular driving in northern VA with winter snow and ice, and several trips on the beach aired down in the OBX NC.
    Overall poor product overpriced and waste of money.
    That was like 8 years ago to be fair.
    Based on what I have seen and read, I have high expectations for these Falkens on my Tundra, hope I'm not disappointed like I was with the Nitto's
    $1300 installed is a lot of money for some tires.
    jhardy1979 likes this.
  17. Dec 29, 2021 at 7:45 AM
    #107
    Falken QA
    Can you provide your OE tire size and tire pressure so I can get a baseline for the new tire size? We'll be adjusted based on load capacity.
    Tundra14Platinum likes this.
  18. Dec 29, 2021 at 7:50 AM
    #108
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    This is true and I have many years ago came out and said we are walking down a bad path.
    If something every broke out between us and them, there is no one in this country who makes bicycle tires, no one.
    Somehow, when world scale wars happen, the world goes back in time a little with major utilities and things getting blown to hell.
    We should always have the capability to produce / manufacture everything we need without assistance from any country.
  19. Jan 13, 2022 at 9:28 AM
    #109
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Reached out to the email address for some stickers, and got a box about a week later.
    They even smelled like a tire shop a little bit!A9ECD3D7-E603-4DE7-B12D-E4F6BAA5A7AA.jpg
    r1-superstar, U-moto, bflooks and 7 others like this.
  20. Jan 13, 2022 at 9:38 AM
    #110
    ErikTRDTUNDRA
    Erik
    Which email did you use? Did you just ask for some stickers? Those are pretty cool.
  21. Jan 13, 2022 at 9:44 AM
    #111
    RainMan_PNW
    Casey
    Clark County, WA
    I emailed inquiries@srnatire.com
    Just told them I was running Falken Wildpeaks on my Tundra and would love a few stickers for my beer fridge/safe/garage wall.
  22. Jan 13, 2022 at 9:49 AM
    #112
    ErikTRDTUNDRA
    Erik
    Awesome, Thank you sir.
  23. Jan 13, 2022 at 10:09 AM
    #113
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    That’s cool.
    I’ve emailed them twice and haven’t gotten shit back for a response!
    Zebruaj likes this.
  24. Jan 13, 2022 at 11:44 AM
    #114
    RainMan_PNW
    Casey
    Clark County, WA
    I also sent them a couple pictures. :notsure:
  25. Jan 13, 2022 at 1:39 PM
    #115
    SAGE63
    San Diego County
    Like the blue round one...
    RainMan_PNW[QUOTED] likes this.
  26. Jan 14, 2022 at 8:40 AM
    #116
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Same. Nothing
  27. Jan 14, 2022 at 8:50 AM
    #117
    Wallygator
    No issues here, love these Wildpeak AT3's! Welcome! :thumbsup:
  28. Feb 3, 2022 at 1:23 PM
    #118
    Elroy_unlimited
    Eric
    Murfreesboro TN
    Got mine today. They smell like a tire shop as well!
  29. Feb 3, 2022 at 2:45 PM
    #119
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Have a set of Wildpeaks on hold at discount tire, hopefully Saturday I can get there to have them mounted on my 4runner. Keeping the stock tire size 265/70R/17 on stock TRD Off Road wheels.
    Falken QA[OP] and Wallygator like this.
  30. Feb 11, 2022 at 1:06 PM
    #120
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Had to resend a 2nd email, but got a reply and stickers today. Thanks!
