Has anyone replaced the map database SD card?
Discussion in '2.5 Gen Tundras (2014-2021)' started by gosolo, Feb 6, 2016.
  1. Feb 28, 2018 at 8:06 AM
    #61
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Install fee that's a joke. I'd tell them to pound sand with that fee.
    nk1794 likes this.
  2. Feb 28, 2018 at 8:10 AM
    #62
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    A caveman could figured it out.
  3. May 18, 2018 at 11:27 AM
    #63
    BlackoutTRD
    BlackoutTRD New Member
    William
    2018 Tundra TRD Sport
    Trifold Bedcover, Custom Leather Seats
    Just wanted to let people know what I tried out. I wanted to update the maps in my 2016 highlander with my 2018 tundra maps. These are the stories. I copied my map SD card from my 2018 tundra onto my computer then put it on a Sandisk 64gig. That failed real quick. So I grabbed the SD card from the highlander and backed it up of course. I then put the data from the 2018 tundra on the 2016 highlander toyota labeled SD card. Did not work. So I put the backup data from my computer back on the 2016 highlander card and it worked again but still out of date maps. I put the SD card from my 2018 tundra into the 2016 highlander and it works perfect. All this to say you cant put new data on other cards, the maps are locked to that specific card somehow. If anyone else has ideas I'm out. Just glad putting the data back on the 2016 highlander SD card worked, its the wifes car and she would kill me if a messed up her navigation :)
    gosolo[OP] likes this.
  4. May 18, 2018 at 11:53 AM
    #64
    Sunnier
    Sunny
    San Diego, CA
    Idea: just like you would any other part from a junk yard, try locating a card with a new map on a recently wrecked vehicle.
    gosolo[OP] and Skippy like this.
  5. May 18, 2018 at 12:37 PM
    #65
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    From what I can gather there's a p12 license file Associated to the card in order to use the data from a different card you need to generate a new p12 file and input that into the new card with the copy data. My issue now is trying to generate a p12 file
    gosolo[OP], Skippy and Sunnier like this.
  6. Aug 22, 2018 at 10:33 PM
    #66
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    I did some research on this, and I believe the reason why it's so complicated is because it's not just about copying the data on the SD card (even doing a block-by-block dd of one card to another).
    SD cards have a built-in micro-controller with it's own very small memory that by design is supposed to only be written to once (during manufacture process). One of the registers in the micro-controller contains the CID of the card which contains information about the manufacturer, OEM / Application, Product ID, etc. So when the cards are manufactured for Toyota, they get specific codes written into the CID that identify the card as a Map card for Toyota (probably even has different version numbers, etc).
    According to the SD specs, the CID can only be written to once. See here:
    https://cdn-shop.adafruit.com/datasheets/TS16GUSDHC6.pdf
    However, some cheaply manufactured cards don't have this limitations and there are (difficult) ways to re-write the CID on a card from certain manufacturers. However, even doing that is complicated and doesn't always work. Also, it can't simply be done by putting the micro controller in SIP mode for direct command access to the micro-controller, you have to be able to put the controller into Firmware mode and not all cards respond to that. Also, each manufacturer uses different firmwares so you have to alter the method based on the manufacturer of the card (assuming you found a card that is poor enough quality that the CID isn't locked to write once).
    You can read the CID on the cards and see the data. For example, in Linux check the block interface (like "cat /sys/block/mmcblk0/device/cid" )
    Some people have had some success on reprogramming the CID data. Here's some fun reading:
    http://bunniefoo.com/bunnie/sdcard-30c3-pub.pdf
    http://forum.arduino.cc/index.php?topic=66586.0
    https://www.getusb.info/how-to-read-cid-on-sd-card/
    https://www.cameramemoryspeed.com/s...ding-sd-card-cid-serial-psn-internal-numbers/
    Software that might help:
    https://github.com/spoofcid/spoofcid
    So, with enough work you might be able to find the right type of card, and re-write the CID and then copy the new map files onto it. However, I'm more likely just to buy the ones off eBay that someone in China already spoofed the CID, and save me some time :)
    #66
    tinman10101 and gosolo[OP] like this.
  7. Aug 23, 2018 at 7:39 AM
    #67
    ScooterInNV
    ScooterInNV New Member
    Robert
    San Antonio, TX
    2019 VooDoo Blue TRD Pro
    Lift, AMP steps
    What's the best spot to see with the newest revision is to the map software?
  8. Aug 23, 2018 at 9:20 AM
    #68
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    Possibly @Roman can answer your question. He seems to know more solid information about our trucks than most people.
  9. Aug 23, 2018 at 12:21 PM
    #69
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Nav map update? If so, we're still rocking the 2017 version. They release new updates once a year, typically in the fall. Last year, I believe we got the update in October.
    AxelsHumanDad and gosolo[OP] like this.
  10. Aug 28, 2018 at 2:49 PM
    #70
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    A .p12 file is typically a compressed file that includes a public and private key pair. This is used in cryptography.
    lewi3069 and gosolo[OP] like this.
  11. Aug 28, 2018 at 9:40 PM
    #71
    silverhack
    Sacramento, CA
    I don't have any .p12 file on my map card
  12. Aug 29, 2018 at 2:58 AM
    #72
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Holy Moly I can barley cook toast in a toaster and this fries 2 out of my three brain cells left and that last one controls my breathing! Good on you for figuring this out.
    #72
    gosolo[OP] and Wvmoonshiner like this.
  13. Aug 29, 2018 at 7:42 AM
    #73
    d0zer
    2017 MGM Platinum
    I'll pull my map card this weekend and dig into it.
    Skippy and gosolo[OP] like this.
  14. Mar 2, 2019 at 3:45 PM
    #74
    tnine
    tnine New Member
    Todd
    2016 TRD Off Road
    ADS External Reservoir Shocks Deaver Leaf Springs 35" Tires C4 Fabrication Bumper Warn Winch Baja design LP9
    Anyone have any luck with this? On my Garmin hand held, I was able to download the open street map to a an SD card and it would read it. This was a .img GPS data file.
    Unfortunately it seems like Toyota used a proprietary format in my 2016 Tundra. I've done a lot of GIS work as a software engineer, and I have no idea what a .kwi file is!
    I'm just going to give up and have a Maestro and Pioneer or JBL Head unit installed that supports Apple Car Play and move on with my life. I can get everything installed with HUD direction integration for approximately $500. This seems worth it to me to be able to use CarPlay. With Google Maps offline download, I've found it to be more accurate than any proprietary mapping system I've used, even when I don't have a cellular data.
  15. Mar 3, 2019 at 12:50 PM
    #75
    d0zer
    2017 MGM Platinum
    Tried cloning the '17 map data (16gb) to a 32gb sandisk card with no luck. Not sure if it didn't like the larger size or if there is something else in play. Will try to find a 16gb card and clone again!
  16. Mar 3, 2019 at 12:56 PM
    #76
    14burrito
    2014 SR5 CM 4x4 5.7
    They have individual "passcodes", can't recall the actual term for it at the moment
  17. Mar 3, 2019 at 1:19 PM
    #77
    Tracy Perry
    Tracy Perry New Member
    Tracy
    East Texas
    2019 MGM TRD Off-Road 4x4
    If it's anything like the Fiat card I got for our Spider, it locks the card to the VIN of the vehicle after a short period of time - resulting in it only working in that one vehicle.
  18. Mar 3, 2019 at 3:44 PM
    #78
    jawjatek
    jawjatek New Member
    N GA
    2019 Tundra DC TRD
    Longtime SW/HW/crypto engineer here. These cards employ digital copy-protection, as is standard procedure for digital rights management these days in many such devices. When the cards are initially programmed, a private key held only by the manufacturer is used to digitally sign a block of card data that includes data unique to each individual card. The Nav units that read the card all contain the public key, and use it to verify the signature. This is well-known PKI (public key infrastructure) security technique used in all secure web communication and many other things. These signatures often employ strong crypto such as RSA/DSA with large keys. Trying to clone these cards is likely going to be an exercise in futility. Just sayin' - because I know.
    silverhack likes this.
  19. Oct 30, 2019 at 9:26 AM
    #79
    TURK8875
    TURK8875 New Member
    SKIPPER
    What is the latestsoftware, Please? Is this a good time to buy? Is the 2019 update been perfotmed?
    Thanks to all.
    anyone have a good ebay/Amazon link for a good source?
    #79
  20. Jan 3, 2020 at 2:45 PM
    #80
    jmv_colorado
    jmv_colorado New Member
    Bump. Also wondering if 2019 maps are out and if anyone has a part number or link.
  21. Jan 4, 2020 at 10:17 PM
    #81
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    I use the navigation from my phone, if I need to see it on my dash screen i just use the Crux to mirror my phone.
  22. Jan 5, 2020 at 3:40 AM
    #82
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    What does this mean? Could you be very specific? Thanks.
  23. Jan 6, 2020 at 6:38 PM
    #83
    TundraTXTSS
    Conroe
    2020 White TRD Pro
    Ronin73 likes this.
  24. Feb 2, 2020 at 5:53 PM
    #84
    JimVZ
    JimVZ New Member
  25. Feb 2, 2020 at 5:56 PM
    #85
    Welcome from NY.
    @Roman he's the parts guy who can answer that and provide a discount.
    Roman likes this.
  26. Feb 3, 2020 at 1:06 PM
    #86
    Roman
    Roman
    Franklin, TN
  27. Feb 3, 2020 at 5:33 PM
    #87
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Roman,
    I started this thread almost exactly 4 years ago. If you could, please please re-read posts#1&5.
    Questions still exist;
    1) are the cards region specific?
    2) are the cards/slots unchanged for years’15-‘19?
    3) is it really “dealer installed”, like my manual says?
    Thanks in advance!
  28. Feb 3, 2020 at 6:44 PM
    #88
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    What will the improvements be with the 2019 data? Anything specific? Please excuse my naivety...
  29. Feb 3, 2020 at 7:14 PM
    #89
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Updated traffic pattern , new roads. New POI
    Roman and HulkSmurf14[QUOTED] like this.
  30. Feb 4, 2020 at 7:22 AM
    #90
    Roman
    Roman
    Franklin, TN
    1. Our cards in the US are not region specific. Toyota Japan and Europe have their own cards, though.
    2. SD cards are the same for all Toyota models.
    3. No, you can just pop it in yourself. Nothing to it.
    The Patriot 1776 likes this.
