Half the engine is running!!
Discussion in '1st Gen Tundras (2000-2006)' started by Trails053, Mar 31, 2019.
  1. Apr 3, 2019 at 10:26 AM
    #61
    Trooper2
    Trooper2 Texas Size Member
    (Southern Suburban) Houston, TX
    2007 Tundra 5.7 L Double Cab TRD 4x2
    TSS 20's with Dynapro ATs, N Fab 3 Hoop Nerf Bars, TRD Wheel Locks, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Gotcha. At least you are getting ahead of it. Would be nice if failed tensioner mfg. covered the cost of repairs.......
    Trails053 [OP] and 15whtrd like this.
  2. Apr 3, 2019 at 10:55 AM
    #62
    Rod67
    Rod67 New Member
    Rod
    2019 SR5
    Spark, fuel or timing - every time!
  3. Apr 3, 2019 at 2:13 PM
    #63
    Trails053
    Trails053 [OP] New Member
    Steven
    New Jersey
    2001 Toyota Tundra SR5 TRD
    None
    I'd like to thank all the people who posted their ideas and possible causes of the problem I occurred with this truck. It should be taken care of very soon. Maybe I'll be reimbursed for the failure of this part and my mechanic compensated for labor.
    Let's see....
    Once again, thank you tundras.com!!
    Trails053
  4. Apr 14, 2019 at 2:36 PM
    #64
    Trails053
    Steven
    New Jersey
    None
    Update: The manufacture upheld their warranty and replaced the tensioner and the timing belt. I did have to pay the mechanic labor, but he's a good friend of mine and it was well worth it.
    Since I replaced four of the coils, I replaced the other four today. I boxed up the oem coils and will "shelf" them with a big note on the box that says "these are ok" on it.
    Once again, thanks for the advice!!
    bmf4069, Darkness, Boerseun and 6 others like this.
  5. Apr 14, 2019 at 3:45 PM
    #65
    Trooper2
    Glad to hear it.
  6. Apr 15, 2019 at 8:27 AM
    #66
    Trails053
    Steven
    New Jersey
    None
    Wait...there's more.
    Leaving for work this morning, truck fired right up, started idling rough, and the engine light came on. Took it to my mechanic, plugged the scanner in and #2,6,&8 cylinders aren't working as they should.(#4 was firing this time) Going to take the covers off to see if it jumped timing again.
    Stay tuned.....
  7. Apr 15, 2019 at 8:39 AM
    #67
    JSM
    JSM New Member
    Jeff (Orlando, FL)
    2003 Tundra 4wd
    Stock
    Man this is bizarre. These are OEM Toyota parts?
    speedtre and 15whtrd like this.
  8. Apr 15, 2019 at 9:46 AM
    #68
    Trails053
    Steven
    New Jersey
    None
    The belt slipped two teeth on the passenger side bank. Very strange, indeed. All the rest of the timing marks are true. Though it could be something wrong with the cam in the head. My mechanic said that he has never seen this happen before. Two belts and tensioner pulleys go bad this soon? Unbelievable!
    Dayco manufacturing...WTH?
    Darkness likes this.
  9. Apr 15, 2019 at 9:59 AM
    #69
    speedtre
    speedtre New Member
    Dirty South
    2006 Toyota Tundra DC TRD 4x4
    I think at this point if he doesn't find anything wrong with the cam I would go with an OEM timing belt and tensioner pulley if you still trust the mechanic...
    15whtrd, JSM and Trails053 [OP] like this.
  10. Apr 15, 2019 at 10:26 AM
    #70
    Trails053
    Steven
    New Jersey
    None
    I just ordered them...now I'm gonna stare at the floor for a while.
  11. Apr 15, 2019 at 10:28 AM
    #71
    Racingjohndeere55
    Racingjohndeere55 Asst. Pot Stirrer
    Harv
    NEPA
    None
    I wonder if a bearing has gone bad and is causing drag on that cam? Could I be two for two?
    TX-TRD1stGEN and speedtre like this.
  12. Apr 15, 2019 at 11:28 AM
    #72
    JSM
    JSM New Member
    Jeff (Orlando, FL)
    2003 Tundra 4wd
    Stock
    Interesting. Yeah go OEM. I’ve heard good things about Dayco though.
  13. Apr 15, 2019 at 12:41 PM
    #73
    15whtrd
    15whtrd Mr. Blonde
    White 2015 Tundra DC SR5 TRD 4x4 5.7L
    TRD Pro suspension, 2015 TRD Pro headlights, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate.
    Aisin is oem without the Toyota name stamped on it. Much cheaper. I only suggest either the parts from the dealer or Aisin. Good deals on Amazon.
  14. Apr 15, 2019 at 2:58 PM
    #74
    Professional Hand Model
    Professional Hand Model Fred Brookes
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Yeah, I dislike paying double or triple for Toyota (Denso, Aisin) parts but I do it because I dislike even more having the work fail.
    Well, keep at it and hope you get things resolved soon.
  15. Apr 15, 2019 at 7:04 PM
    #75
    Darkness
    Darkness New Member
    Luis
    All over SoCal
    The darkest
    It's really dark
    I would go Toyota or Gates, nothing else.
  16. Apr 15, 2019 at 11:05 PM
    #76
    empty_lord
    empty_lord New Member
    05 rollover special
    custom body work
    I have seen aftermarket belts that fit great, but issue is the belts just a hair longer than the oem somehow and they skip. Cost sucks... but something like the t-belt i would say oem is theonly way.
    gates is actually the belt i saw have issues.. granted it was a rav4 4 cylinder.. but every time youd start it up once you hit 2k rpm the belt would skip and off the covers came again
  17. Apr 16, 2019 at 2:40 AM
    #77
    Adam New Member
    2014 Radiant Red Tundra
    That sucks. Could be a bad "lot" from the manufacturer.
  18. Apr 16, 2019 at 4:34 AM
    #78
    Darkness
    Darkness New Member
    Luis
    All over SoCal
    The darkest
    It's really dark
    I guess everyone can make a bad belt here and there.
