Half the engine is running!!
Discussion in '1st Gen Tundras (2000-2006)' started by Trails053, Mar 31, 2019.
  1. Mar 31, 2019 at 4:46 AM
    Trails053
    Trails053 [OP] New Member
    Steven
    New Jersey
    2001 Toyota Tundra SR5 TRD
    None
    Hello to all I am a new member I have a 2001 Toyota tundra SR 5TRD package. I noticed it was running very rough going down the road. I was down to about a quarter tank of gas so I decided to stop at a Shell station and fill up the gas tank with quality fuel. I called my mechanic and told him the problems that I was having and said to him that I was going to stop by and hook it up to the scanner to find out what’s wrong. He hook the scanner up and it read the codes PO 302 PO 304 PO 306 PO 308 and PO 300 . Needless to say all four cylinders on the passenger side or not firing. I change the spark plugs in the coil packs, still not firing. The engine starts and runs, but of course, not properly. I was thinking it might be the cam sensor or the crankshaft sensor. You can smell the fuel coming out of the exhaust, But it seems I might have an electrical problem before the coil’s. Half the engine is running what a head scratcher. Any help is deeply appreciated.
  2. Mar 31, 2019 at 5:00 AM
    Rod67
    Rod67 New Member
    Rod
    2019 SR5
    How many miles on it? 5.7?
  3. Mar 31, 2019 at 5:30 AM
    Trails053
    Steven
    New Jersey
    None
    Just turned 100k
  4. Mar 31, 2019 at 5:31 AM
    Trails053
    Steven
    New Jersey
    None
    Sorry..4.7 liter
  5. Mar 31, 2019 at 5:48 AM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    Swap the coils to the other side to make sure they’re not bad, also check for chewed wires, sometimes rodents shelter inside the engine compartment and start chewing on the wires, have you done any repair or mod lately?, if so, check for loose connections, just some ideas.
    Trails053[OP] and Black Wolf like this.
  6. Mar 31, 2019 at 6:00 AM
    Trails053
    Steven
    New Jersey
    None
    I checked the other coils and they’re working fine. The only other repair that I did was the timing belt and that was done by a professional. But no other mods were done to this truck.
  7. Mar 31, 2019 at 6:01 AM
    Trails053
    Steven
    New Jersey
    None
    .. I also checked many wires and vacuum lines to make sure there was no rodent infestation broken or chewed wires.
  8. Mar 31, 2019 at 6:04 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    No 5.7L in 2001.
  9. Mar 31, 2019 at 6:06 AM
    Aurora CO
    If all your coils are good then you to need to find out why there is no juice getting to four coils. Do you have a multimeter?
    Trails053[OP] likes this.
  10. Mar 31, 2019 at 6:10 AM
    Trails053
    Steven
    New Jersey
    None
    No 4.7 it says so on the engine cover and title. I had it for eight years it had 18,000 miles on it when I purchased it. I always used quality parts and Bosch spark plugs and premium fuel.
  11. Mar 31, 2019 at 6:12 AM
    Aurora CO
    I know. My 07 got the new 5.7L. A multimeter would help you out a lot if you can get your hands on one.
    Trails053[QUOTED][OP] likes this.
  12. Mar 31, 2019 at 6:14 AM
    Trails053
    Steven
    New Jersey
    None
    Yes I have a multimeter. I checked the fuses to make sure that they were all good.
    I think it might be a problem before the coil’s.
  13. Mar 31, 2019 at 6:33 AM
    Aurora CO
    So you are getting juice to the four coils in question? I'm certain some owners of the1st gen who are more familiar than me will chime in.
  14. Mar 31, 2019 at 6:38 AM
    Trails053
    Steven
    New Jersey
    None
    It sure doesn’t seem so. The plugs were wet when I pulled them out. I just purchased brand new coils And installed them.
  15. Mar 31, 2019 at 7:00 AM
    Dmas
    Dmas New Member
    FTL, FL
    So all 8 coils are new? Check for ground connection
  16. Mar 31, 2019 at 7:03 AM
    Trails053
    Steven
    New Jersey
    None
    Yes. All the coils are new. Where should I check for ground connections? The battery ground is good. Looked around the firewall and the main frame.
    Remember..2001 truck.
  17. Mar 31, 2019 at 7:05 AM
    Dmas
    Dmas New Member
    FTL, FL
    Follow the coil wires and you will see them
  18. Mar 31, 2019 at 7:10 AM
    Trails053
    Steven
    New Jersey
    None
    :thumbsup:
    I’ll keep you posted in the meantime any other suggestions would be appreciated:thumbsup:
  19. Mar 31, 2019 at 7:12 AM
    Rod67
    Rod67 New Member
    Rod
    2019 SR5
    Yup - I knew that (once upon a time)!
    Thanks Wolf
    Curious - What prompted you to replace all the coils?
    A lot of times when things go wrong it is best to go back and check the last thing you changed...
    Trooper2 likes this.
  20. Mar 31, 2019 at 7:22 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    How are the fuses arranged for this engine and the coils? One fuse for the left bank of 4 cylinders? One fuse for the right bank of 4 cylinders? Have you checked that it's not simply a blown fuse?
    Trails053[OP] and Dmas like this.
  21. Mar 31, 2019 at 7:36 AM
    Professional Hand Model
    Hand Protectors
  22. Mar 31, 2019 at 7:47 AM
    Hand Protectors
  23. Mar 31, 2019 at 8:13 AM
    Trails053
    Steven
    New Jersey
    None
    I change the coil’s because they weren’t firing.( first thing I thought of doing) The last thing that was worked on was the timing belt.
  24. Mar 31, 2019 at 8:44 AM
    Trails053
    Steven
    New Jersey
    None
    I checked all the fuses in the engine compartment I’m trying to upload a picture of the fuse box
  25. Mar 31, 2019 at 8:55 AM
    Trails053
    Steven
    New Jersey
    None
    Fuse box 2001 4.7l
  26. Mar 31, 2019 at 9:01 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Can't offer any help other than mentioned.
    FYI, Bosch plugs are not great quality. Better to go with OEM.
  27. Mar 31, 2019 at 9:04 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Ecu issue?
  28. Mar 31, 2019 at 9:08 AM
    Trails053
    Steven
    New Jersey
    None
    I hope not.. is there another fusible link between the injector banks if there is such a thing ?
  29. Mar 31, 2019 at 9:09 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    ECM issue?
  30. Mar 31, 2019 at 9:36 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Did it start with the belt replacement? I'm wondering if the belt jumped timing.... just sounds suspect, unless you know for sure its electrical
