Half the engine is running!!
Discussion in '1st Gen Tundras (2000-2006)' started by Trails053, Mar 31, 2019.
  1. Mar 31, 2019 at 9:44 AM
    speedtre
    speedtre New Member
    Dirty South
    2006 Toyota Tundra DC TRD 4x4
    I thought the same thing if electrical checks out...
  2. Mar 31, 2019 at 11:17 AM
    empty_lord
    empty_lord New Member
    05 rollover special
    custom body work
    I don’t know if the 05 has grounds in different spots. But there’s a ground on the front of the motor one each side with a 10mm bolt, I believe it is the ground for each banks injectors and spark plugs, I would pull that and clean it. That ground can cause many ignition problems
    Grey Wolf and Darkness like this.
  3. Mar 31, 2019 at 11:36 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I think Denso is Toyota's tier 1 supplier for spark plugs?
  4. Mar 31, 2019 at 12:03 PM
    empty_lord
    05 rollover special
    custom body work
    Denso or ngk. Denso is what you get when you go to the dealer
    Sas and Darkness like this.
  5. Mar 31, 2019 at 12:30 PM
    Trails053
    Trails053 [OP] New Member
    Steven
    New Jersey
    2001 Toyota Tundra SR5 TRD
    None
    No. It didn’t start after the belt was changed. Just driving along and started running bad.
    Racingjohndeere55 likes this.
  6. Mar 31, 2019 at 12:30 PM
    Trails053
    Steven
    New Jersey
    None
    I’ll check this when I get home later and keep you updated.
  7. Mar 31, 2019 at 12:59 PM
    Darkness
    Darkness New Member
    Luis
    All over SoCal
    The darkest
    It's really dark
    How long ago was the timing belt done? How many miles ago?
    I am thinking what Empty Lord is thinking. Seems like the coil packs and plugs are okay but not getting spark. Since it's all 4 on one bank its possibly a communal ground.
    If that isnt it, I would look into the fuel injector wiring to see if they have a similar set up with one ground per bank. Misfire doesn't just mean electrical. If not that either I would suspect maybe the belt jumped on the cam and your valves aren't working in sync with your fuel/spark.
    Grey Wolf, Trails053 [OP] and 15whtrd like this.
  8. Mar 31, 2019 at 1:39 PM
    Trails053
    Steven
    New Jersey
    None
    About 3,000 miles ago. I’m going to recheck grounds...
    Grounds are good.
  9. Mar 31, 2019 at 3:23 PM
    Professional Hand Model
    Professional Hand Model Fred Brookes
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    I went out and checked mine too. There is just one ground on the pass side connecting the engine block backside to the firewall. Couldn’t find another second ground, so assuming there is just one on mine.
    Trails053 [OP] likes this.
  10. Mar 31, 2019 at 3:46 PM
    Trails053
    Steven
    New Jersey
    None
    I saw that, as well. Good ground.
  11. Mar 31, 2019 at 6:13 PM
    JSM
    JSM New Member
    Jeff (Orlando, FL)
    2003 Tundra 4wd
    Stock
    One thing if you have a local Toyota dealer is swing by the service department. Out back where they work on the cars. Walk in like you own the place. Find the first tech and ask who is good with the older 4.7l v8. Explain it to him and get his input. Thank him and slide him $10.
    My guy knows me but name now. He shows me things, explains how to do things and I save lots of $$$.
    I don’t think it’s it timing belt related. It’s going to be electrical in my opinion. I wonder if your crank angle sensor bit the dust.
  12. Mar 31, 2019 at 7:50 PM
    empty_lord
    05 rollover special
    custom body work
    If he skipped time he’d have a slight tapping sound if it’s more than a tooth. The sound of the valve just barely hitting the piston. Any worse and it would be a horrible racket.
  13. Mar 31, 2019 at 7:51 PM
    empty_lord
    05 rollover special
    custom body work
    I do believe the 2uz only has one cam sensor so if it died he’d have nothing on both banks
    Trails053 [OP] and JSM like this.
  14. Mar 31, 2019 at 7:57 PM
    Rod67
    Rod67 New Member
    Rod
    2019 SR5
    Baring mechanical failure (like a broken cam, clogged exhaust pipe etc.) a miss is caused by one of 3 things -
    No fuel, or improper fuel air mix.
    Insufficient or nonexistent spark.
    Timing - fuel and spark not arriving at the proper relative time.
    Sounds like fuel isn't the issue.
    I'd pull a plug and see if it sparks when you crank the key. If it does than either spark or cam timing would be the issue.
    Just my 2 cents...
  15. Mar 31, 2019 at 8:01 PM
    JSM
    JSM New Member
    Jeff (Orlando, FL)
    2003 Tundra 4wd
    Stock
    Interesting. This guys was a timing belt slip. I might have missed this but was spark confirmed on the half side of the engine coding or is it just missfiring? Wondering if the OP is thinking missfire means no spark?
    Trails053 [OP] and speedtre like this.
  16. Apr 1, 2019 at 4:34 AM
    zombie
    zombie New Member
    paul
    Those IGNITORS over by your shock tower.....Do you want me to grab the spare out of my truck and show you a picture..................ummmmmmmmmmmm, why do I keep a spare set of these. There are 2, 1 for each half of the engine.
  17. Apr 1, 2019 at 5:20 AM
    Trails053
    Steven
    New Jersey
    None
    No tapping while running.
  18. Apr 1, 2019 at 5:29 AM
    Trails053
    Steven
    New Jersey
    None
    Ya know?.. I never tried to notice if I had spark, checking the spark plug, outside the cylinder using the coil for “hot”....I feel compelled to do so now.
    speedtre likes this.
  19. Apr 1, 2019 at 5:35 AM
    #49
    Rod67
    Rod67 New Member
    Rod
    2019 SR5
    Just make sure you ground the plug. Jumper cables will work.
  20. Apr 1, 2019 at 5:35 AM
    #50
    Trails053
    Steven
    New Jersey
    None
    I’m still looking for those...post a picture if you could.
    4.7L
  21. Apr 1, 2019 at 5:43 AM
    #51
    Rod67
    Rod67 New Member
    Rod
    2019 SR5
    So if you don't have spark try swapping the ignitors while the plug is still out and see if you get spark
  22. Apr 1, 2019 at 5:51 AM
    #52
    Trails053
    Steven
    New Jersey
    None
    I took the truck to the mechanic. I’ll post when it’s diagnosed.(hopefully)
    He might have to see this thread...
  23. Apr 2, 2019 at 8:49 AM
    #53
    JSM
    JSM New Member
    Jeff (Orlando, FL)
    2003 Tundra 4wd
    Stock
    Inquiring minds want to know!
    ZappBrannigan likes this.
  24. Apr 3, 2019 at 8:08 AM
    #54
    TX-TRD1stGEN
    TX-TRD1stGEN ...
    Seth
    South East Texas
    2000 Tundra 4x4
    Any update??
  25. Apr 3, 2019 at 8:35 AM
    #55
    Trails053
    Steven
    New Jersey
    None
    Nothing yet, I will post when diagnosed.
  26. Apr 3, 2019 at 9:14 AM
    #56
    Trails053
    Steven
    New Jersey
    None
    I just got off the phone with my mechanic and he said the timing belt jumped.
  27. Apr 3, 2019 at 9:42 AM
    #57
    Trooper2
    Trooper2 Texas Size Member
    (Southern Suburban) Houston, TX
    2007 Tundra 5.7 L Double Cab TRD 4x2
    TSS 20's with Dynapro ATs, N Fab 3 Hoop Nerf Bars, TRD Wheel Locks, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Suspects or confirmed? :popcorn:
  28. Apr 3, 2019 at 9:54 AM
    #58
    Trails053
    Steven
    New Jersey
    None
    Confirmed...jumped four teeth. Luckily didn’t bend any valves.
    Jumped due to tensioner pully failure.
    speedtre and NewImprovedRon like this.
  29. Apr 3, 2019 at 9:56 AM
    #59
    Trooper2
    That sucks.
    Recent timing belt change- Not replaced tensioner? or overdue timing belt/tensioner?
  30. Apr 3, 2019 at 10:20 AM
    #60
    Trails053
    Steven
    New Jersey
    None
    When the timing belt was changed they changed all the pulleys plus the tensioner. The tensioner failed. There’s a warranty on that tensioner. I asked the mechanic to go to a Toyota dealership to get a tensioner.
