Gym/workouts
Discussion in 'Sports, Hobbies & Interests' started by T-Rex266, Jan 7, 2014.
  1. Jan 8, 2021 at 6:38 PM
    #1351
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Not looking for the cover of mens fitness...lol
  2. Jan 8, 2021 at 7:41 PM
    #1352
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    What are you doing for chest currently?
  3. Jan 8, 2021 at 7:50 PM
    #1353
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I go full Ape with a portable generator! Lol
  4. Jan 8, 2021 at 8:10 PM
    #1354
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    • Lift twice a week. Make those days, bench days ONLY to ensure maximum effort, going to ACTUAL failure (or as close as you can come and still be safe without a spotter).
    • Flat bench press ONLY [not dumbbell flys, cable flys, or dumbbell presses, dips, inclines, etc.].
    • The vast majority of body types grow best with 8 reps as their optimal #: adjust weight as needed to stay very close to this number.
    • Do the eccentric portion of the lift [negatives, lowering the weight] VERY slowly while maintaining tension on the muscle at all times; then, try to explode upward on the concentric [positive, raising the weight] movements. [Don't go too wide or too narrow on the grip.]
    • If possible, work with a partner: the encouragement is necessary; and it allows you to work safely. [Bar and bench demand neuromuscular control, which is far superior to machines.] If you can get a partner, use a scientific program that uses your max bench number to calculate heavy and light days: this will really accelerate your strength gains; and strength gains lead to mass gains.
    • Take protein supplements before working out.
    • Don't drop the weight all the way to your chest; keep it a couple inches above that. Dropping all the way puts unnecessary strain on our shoulders. [If you want to get into power-lifting competitions, drop all the way.:D]
    • Squeeze your shoulder blades in, keep your butt on the bench and your feet on the floor at all times: there should be tension throughout your entire body. Everything should be stiff [locked in], just like you need to stiffen your whole body to do pull-ups effectively.
    • Most of this is mental. You have to want to be there. You have to want to lift heavy weights and put out maximum effort.
    • Over-training is as bad as under-training. Your muscles should be sore the next day, but you should recover COMPLETELY before lifting again.
    Your mileage may vary; others may disagree.: :hattip:
    Kung likes this.
  5. Jan 8, 2021 at 8:33 PM
    #1355
    I highly disagree with flat bench only. I was doing 355 until shoulder issues. Switched to db’s and I’m up to 140-145’s per side. No shoulder issues. Stay away from BB if you can. Much harder on ur joints.
    Protein supps before? Not sure I follow. I would add sea salt for sodium to eggs or whatever if ur training in AM to help with blood flow.
    I get sore and love it. You can still train on it.
    Just my .02
    Or .03
    but idk what I’m doing. :hattip: Just ask @ColoradoTJ or @Squatting Pigeon or others
  6. Jan 8, 2021 at 9:05 PM
    #1356
    RollTide82
    Michael
    2019 Tundra 4x4
    All sorts of stuff....incline decline and flat bench....pushups.....dips......and some other stuff I found from a guy that does a YouTube called anabolic aliens....that includes resistance bands and such. I just don't have time for a gym ....I can easily dedicate 45 mins about 5 days a week at home. Just limited on equipment
  7. Jan 8, 2021 at 9:08 PM
    #1357
    Watch some John Meadows videos. He categorizes it and is a tried and true dude.
  8. Jan 8, 2021 at 9:14 PM
    #1358
    Salsaverda16'
    Salsaverda16' New Member
    Gaervyn
    2016 Black Tundra 4x4
    @RollTide82 and others interested.
    I recently started a modified 5x5 program where first two lift are heavy compound movements (5 sets, 5 reps) where the 5th reps should be a struggle but not compromising form. Then 2-3 more exercises of 8-12 reps (3 sets). When doing the 5 reps at least 1min 30 sec of rest, and when doing 8-12 reps 30-45 sec of rest. This has been working well for me the last 6ish weeks, been lifting a little heavier and put on a 5ish lbs. Also, I finish everything with doing as many full reps as possible of an exercise paired with an accessory lift.
    For example; Day 1: Chest and Tricep would be:
    Bench Press 5x5
    Incline Bench 5x5
    Incline DB Bench 3x8-12
    Flys 3x8-12
    Rope Tricep Ext 5x8-12
    Skull crushers 3x8-12
    Push ups or Dips 3x as many as possible
    Single Arm Tricep Ext
    I also keep have a spreadsheet so I remember what weight was lifted the previous week so I can adjust the present week's weight accordingly. With a warm up this takes me about an 1hr 15mins. This again is just an example and can be modified to your liking. Hope this helps.
  9. Jan 9, 2021 at 10:47 AM
    #1359
    wakeboarder
    wakeboarder New Member
    13 Tundra
    What you need is volume, and that’s going to be tough to get only working chest once a week. Up it to twice and you’ll be on the right track. And the 2nd day can be just body weight stuff if that makes it easier on your schedule.
    Hypertrophy is probably the best way to build size, so here’s a good guide: https://www.t-nation.com/training/set-rep-bible
    Not everything on Tnation is gospel, but they usually know what they’re talking about.
  10. Jan 9, 2021 at 11:52 AM
    #1360
    TundraDude18
    'Merica
    '21 Limited CM
    Just do one thing that everyone said ... :rofl::rofl::rofl:
    T-Rex266[OP] likes this.
  11. Jan 9, 2021 at 5:35 PM
    #1361
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Except...drop the bar. Don’t ever drop the bar!
    There are way to many variables to help nail down a specific plan without more info. However, there is some good advice given here. Volume will definitely help and there’s a bunch of ways to do that. If you don’t have the time or your program/schedule doesn’t allow for a dedicated second chest day every week you could start a tricep day with incline neutral grip dumbell press. This would be 2x30. Then finish that with whatever tricep work you normally do. With the neutral grip you take out any stress of the shoulder. And if you don’t think it won’t kill your chest and fry your tri’s give it a shot. Plus I’d be willing to bet that you won’t need more then 50-60 pound dumbbells for this.
  12. Jan 16, 2021 at 1:55 PM
    #1362
    RollTide82
    Michael
    2019 Tundra 4x4
    I get to work with a few urologists....speaking of dropping...I saw pics of a guys penis that was annihilated from him dropping a heavy dumbell in his lap....it was horrible. Didnt lose it but dang sure messed it up.
  13. Jan 16, 2021 at 2:24 PM
    #1363
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    I used to lift 3-4 times a week till this past year. With covid and the gyms being closed, I picked up biking again and ended up putting on about 2500 miles last year. I finally scored a set of Bowflex 1090 adjustable dumbbells and a bench in Aug and have been lifting about twice a week however bought a trainer for the bike so I'm still riding too.
    I was a founding member of Golds so I've got a $19.99/month membership that I'm trying to decide whether to keep or not. Haven't been there since March 13th.
  14. Jan 16, 2021 at 2:58 PM
    #1364
    Juanjoolio007
    Oregon
    That sounds horrible! I was just referring to the “drop” as in the negative. Don’t ever drop the negative. It’s a controlled lower.
  15. Jan 16, 2021 at 7:06 PM
    #1365
    TundraDude18
    'Merica
    '21 Limited CM
    Wow. Thanks for the mangled penis story. That was inspiring. You really have the gift of encouragement.:D
    But yeah, great advice: don't drop heavy crap on your dingus. Duly noted. Pro tip. Thanks for not posting the pic.:bananadead:
    Kung and BravoDeltaRomeo like this.
  16. Mar 31, 2021 at 8:15 AM
    #1366
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    needing some new stations to workout to. i use Amazon music and pandora. getting bored with the stations I got. any suggestions welcome. i listen to pretty much everything. prefer hard rock, metal, and even some trap/edm. every once in a while, some hip-hop...but not as much. let me know what y'all got. i don't get offended, nothing surprises me, and if your station doesn't do it for me, i just won't listen to it. thnx in advance guys/gals
  17. Mar 31, 2021 at 7:58 PM
    #1367
    MotoTundra
    MotoTundra The Ocho
    Don
    Just a head up, PowerBlock Pro EXP are finally in stock on their web page, along with both expansion sets to go up to 90lbs.
    I have an older set of PowerBlock’s that go up to 85, I have been waiting to upgrade!
  18. Mar 31, 2021 at 9:11 PM
    #1368
    This is just Pandora
    Fotnot[QUOTED] likes this.
  19. Mar 31, 2021 at 10:45 PM
    #1369
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Yeah right !!!!
  20. May 13, 2021 at 8:26 AM
    #1370
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Any recommendations for home gym equipment/setups for powerlifting? I go to a commercial gym but the hours have been cut with COVID which has severely affected my training as i can't go after work anymore. That and for the yearly cost i might as well buy equipment. I was looking at the Rogue RML 90 Slim rack, an Ohio Power Bar, and then grabbing some York plates since they're close to me.
    Juanjoolio007 likes this.
  21. May 13, 2021 at 12:39 PM
    #1371
    Juanjoolio007
    Oregon
    Depending on budget/location the 5k ships free from Rogue is pretty nice.
    That’s what I did when I started my build.
    Then I almost gave into back problems and sold a bunch of stuff. Buying plates again this year sucked.
    At least they are starting to catch back up.
    Rogue power bar is a good start. I added SSB, Texas dl bar, a cheap ass multi grip bar, and a trap bar. I sold the trap bar.
    depending on programming a full set of bands. Or at least maybe a couple different sizes.
    I have full set of EliteFTS for long bands, full set of Rogue for short. Truth be told I don’t use the short ones that often. Probably wouldn’t get those...unless you know you need them.
    Spud inc makes a bunch of stuff for pulleys, handles, straps etc. love the swing set straps for a yoke alternative.
    Other stuff depending on space, budget- reverse hyper, GHD or combo unit.
  22. May 13, 2021 at 3:33 PM
    #1372
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Zakk Wylde, Texas Hippy Coalition and things like that are my go to in the gym
  23. May 14, 2021 at 8:16 AM
    #1373
    snomoman
    snomoman New Member
    North Aurora, IL
    2020 Cement SR5 4WD Tundra
    Bed liner, truxedo tonneau cover, Westin step rails, cover king seat covers
    I thought I would post on this site for some possible advice, I’m about to turn 64 next month and due to semi retirement and inactivity I’ve gained some belly weight, I said to myself once I get to 200 pounds that’s it I’m making a lifestyle change, so I weighed myself yesterday and I was 199.8, close enough, so at this point I’ve stopped drinking beer and started to do some walking, I have a prairie path near me so I took a walk this morning, decided to do a little jogging but because of my Big belly my pants started to drop, ha ha, so I tightened it up a notch and combined jogging with walking, at this time I can only jog about 30 seconds before being out of breath but I hope to do this every morning and continue to see how this helps me out, I really can’t do any weight lifting because I’ve got a hernia in my abdominal area so I’m going to have that looked at soon, Planning on getting my bicycle out and doing that as well, I have to watch what I eat because I have gout attacks, the doctor said to stay away from red meat along with other things, I will post back and see how my results go, thanks for reading and any advice
    red_5ive likes this.
  24. May 14, 2021 at 9:12 AM
    #1374
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    How is that going? I have cut out a lot of things, but one Guinness per night is my weakness.
  25. May 14, 2021 at 9:17 AM
    #1375
    snomoman
    snomoman New Member
    North Aurora, IL
    Yeah my problem is if I drink one I want to drink more, 1 just gets the pump primed, LOL, guiness is too strong for me, I drink busch light which is almost like water but I’ve cut it out now and I think things will get better
  26. May 14, 2021 at 9:46 AM
    #1376
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    I used to think that of Guinness. In reality, is has the same alcohol content as your Busch lite (4.2% vs 4.3%) and only 11 more calories per 12 oz. (125 vs 114).
  27. May 14, 2021 at 9:55 AM
    #1377
    snomoman
    snomoman New Member
    North Aurora, IL
    After my second gout surgery I was getting advice from other gout afflicted people, One told me that Anheuser-Busch products are rice-based fermentation which didn’t affect his gout as much as other beers, whether that’s a fallacy or not I don’t know but since I started drinking Busch light I’ve never had any gout attacks, I guess the wisest thing would be don’t drink any beer at all because it does have an effect on gout. I think I’m gonna go take another walk/jog and hopefully shed a little more “blubber”...haha
  28. May 20, 2021 at 7:53 PM
    #1378
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    Real late to the party but did this because of Covid. Yes I am a Titan fan boy! LoL.
  29. Jun 17, 2021 at 9:54 AM
    #1379
    rockmup
    rockmup New Member
    Todd
    @ 58 yrs old I had a PR of 855 for 2 clean reps on the leg press. I was told I needed a new knee a few months ago so to say I'm stoked is an under statement
    Thats all, just bragging a little
    EDIT: Props to whoever moved this. I forgot about it
    Kung, Fotnot, Luckydog and 1 other person like this.
  30. Jun 17, 2021 at 10:01 AM
    #1380
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    LOL Did you get the knee or are you doing this on the one you were told needs replacement?
    Well done. I now alternate leg workouts between squats and leg presses. Leg press facilitates the use of higher weight but what's more important to me about it is it allows a deeper rep with the extra weight without the strain on the lower back that normally starts to come with doing squats once you hit your 40s and 50s. My back rather than legs is starting to become a limiting factor in my squat progress but doesn't hold me back on leg presses.
    rockmup[QUOTED] likes this.
