Guide: Different Types of Lifts
Discussion in 'Suspension' started by csuviper, May 24, 2014.
  1. Nov 28, 2018 at 2:48 PM
    #121
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I wouldn’t shim stock shocks, but that’s just me. 5100’s ride better than stock suspension from what I’ve heard, and if you don’t want to drop much coin, they’re perfect.
    831Tun and KevinK like this.
  2. Nov 29, 2018 at 7:24 AM
    #122
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    5100s were our first suspension upgrade. They rode better than stock and provided exactly the level you’re looking for. No change in towing capacity either. With that light of a TT, you’ll have no issue towing without bags.
    If you offroad even a tiny bit, don’t do shims. It only takes one bad bounce to make for a broken shock and a sketchy day of travel to wherever you can get it replaced - supposing you can even drive it at all.
    zcarpenter92 and 831Tun like this.
  3. Nov 30, 2018 at 6:13 AM
    #123
    D old guy
    D old guy New Member
    2013 White Tundra Ltd.
    Wheels,tires, intake,exhaust, lift /level ,lights
    I am no expert but I did the 5100 and 1.5 shackles and the ride is great. The truck is pretty much level with a very slight almost unnoticeable rake which in my opinion is perfect. (THE LOOK thats it.). I stressed the look because I am now looking to buy a 6 inch lift kit. Zach said I should MANup:militarypress: and buy it so I am working on a excuse to give the wife :rofl:
  4. Dec 21, 2018 at 8:53 AM
    #124
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Can someone tell me if this is a typo?
    It seems to suggest that you would need a smaller tire after leveling. That doesn't make sense.
  5. Dec 21, 2018 at 11:06 AM
    #125
    D old guy
    I am not sure but I think the factory is 265/65/16. and what it is saying is that with 275/70/16 the wheels is wider and taller and with 265/75/16 the wheels are same width as factory BUT TALLER. that's my understanding. hope this helps.;)
  6. Feb 23, 2019 at 9:17 PM
    #126
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I do have to say that I have a renewed respect for the Toytec split 3” front Coilovers spacer Lift. It rides pretty much exactly like stock. Definitely worth it if you understand the limitations offroad. Perfect for on-road only cheaper lift. I have had my sport shocks with these spacers on for about a week now.
  7. Feb 24, 2019 at 11:12 AM
    #127
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    CSUViper, thanks for sharing so much good information- this thread is great.
    Do the toytec spacers require alignment after install?
    csuviper[OP] likes this.
  8. Feb 24, 2019 at 11:16 AM
    #128
    panicman
    Eric
    If you JUST did 5100’s in front, is that sufficient for leveling without modifying anything in the rear?
  9. Feb 26, 2019 at 5:58 AM
    #129
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    5100 will give you .87", 1.57" or 2.28"in the 1st, 2nd and 3rd position respectively. Standard rake is typically just under 2", so the 1st setting will leave you with some rake, 2nd setting will be just about level, and 3rd setting might leave you slightly nose high, in which case you can add something to the rear. However, adding 1" to the rear will again leave you with rake, which you try to get away from when leveling.
    Since each truck is different for some reason, either the 2nd or 3rd setting can get you level without doing anything to the rear, depending if your rake is under or over 2".
    I am thinking about 2nd setting with 1/4" shims which will be 1.82". My current rake is about 1.9", so that will be perfect for me. I don't want to be nose-high, and I don't want to really add to the rear. (still thinking about it....)
  10. Feb 26, 2019 at 6:33 AM
    #130
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    See my build below vvv That's what I did at first and ran it that way for seven months.
  11. Feb 26, 2019 at 8:38 AM
    #131
    panicman
    Eric
    Thanks you guys.
    r1-superstar likes this.
  12. Feb 27, 2019 at 8:00 PM
    #132
    r1-superstar
    DB
    UTAH
    NP, remember to post pics when you are done with the install. ;)
  13. Feb 27, 2019 at 8:36 PM
    #133
    csuviper
    Broomfield, CO
    I went from a 3”ish lift to a 3” lift so no I didn’t need to do an alignment.
  14. Feb 27, 2019 at 9:22 PM
    #134
    panicman
    Eric
    Ok- back again with questions. I have the Bilstein 4600 shocks on my truck now- they are part of the TRD off-road package.
    If I add the 5100’s the front, adjust to the second setting, and leave the back alone, it sounds like I will damn-near level the truck with a fraction of an inch of rake.
    If I do this, will I need to plan on an alignment?
    I only ask because I like to do stuff myself, but aligning the truck is not something I have the tools or wherewithal (at this point) to tackle.
    Chopperdog1962 likes this.
  15. Feb 27, 2019 at 9:24 PM
    #135
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Yes, you should still do an alignment.
  16. Feb 28, 2019 at 7:08 AM
    #136
    panicman
    Eric
    Absolutely!
    r1-superstar[QUOTED] likes this.
  17. Feb 28, 2019 at 7:13 AM
    #137
    r1-superstar
    DB
    UTAH
    Yes you will need an alignment. This is my truck with what you are going to do:
    panicman[QUOTED] likes this.
  18. Feb 28, 2019 at 8:51 AM
    #138
    zcarpenter92
    Zach
    NE Colorado
    In sig
    What happened to you having the Radflos?
  19. Feb 28, 2019 at 8:52 AM
    #139
    csuviper
    Broomfield, CO
    Being rebuilt at Toytec!!
    zcarpenter92[QUOTED] likes this.
  20. Feb 28, 2019 at 8:54 AM
    #140
    zcarpenter92
    Zach
    NE Colorado
    In sig
    That's kinda what I was thinking! You don't seem like the kind of guy that downgrades ha.
  21. Feb 28, 2019 at 5:50 PM
    #141
    panicman
    Eric
    Extremely helpful!! Thank you for posting. And sharp looking!
  22. Feb 28, 2019 at 8:11 PM
    #142
    r1-superstar
    DB
    UTAH
    Thanks! I have since lifted it more in preparation of new rims and tires.
  23. Apr 14, 2019 at 5:25 AM
    #143
    mohd.darmaki
    mohd.darmaki New Member
    Mohammed
    1794 platinum Black model 2017
    Honey-D kit , sos performance lowering kit , TRD daul exhaust , front & rear sway bars ,TRD Air Intake , TRD Pro Grill/Hood Bulge , 2018 Front lights/ Fog lights , Fuel marveick wheels 20x12 negattive44 with grapper 305 tires , Glossy Black Door Handles Cover Half mirrors tailgate w cam, Tundra Steep foot; Fridge center console ,Tundra black Tailgate Trim Bezel , 4x4 Tundra tail , cup olders , Disk Brake Calipers Cover , TRD Liscense Plate , kuda mount black, Super Charger
    Hello guys
    I need help or opinion whats the difference between king shocks 3.0 and icon . And would my car looks good in them or should i keep it the way how is it
    I have lowering kit know in my car which am thinking to install the king 3.0 custom made red ones
    I would like to ask whats the price for them
    saybng likes this.
  24. Sep 22, 2019 at 1:16 PM
    #144
    K1NJO
    K1NJO New Member
    Allen
    Bay Area, CA
    2011 Black Tundra TRD Sport
    When doing a coilover lift over 3" on a 2WD, is it necessary to upgrade to lift spindles?
  25. Oct 31, 2019 at 12:35 PM
    #145
    NHSSTundra27
    NHSSTundra27 New Member
    Jesse
    2015 SR5 CrewMax
    None Yet
    Is anyone getting driveline vibration when adding to the rear leaf pack? I'm going to get 5100s for front and rear, and then also either a single AAL of the AAL pack(3), odd but both claim to add 1-1.5 inches of lift, I'm guessing the single AAL rides smoother than the pack. I'm coming from a Tacoma so this is why I bring that up but as I'm typing this I'm realizing I now have a one-piece driveshaft so this could be completely irrelevant.
  26. Oct 31, 2019 at 6:49 PM
    #146
    KevinK
    Tundras to Sedona
    Welcome to your Tundra!
    What is the use case for your rear lift? If it's payload capacity, the AAL is a valid option. If you're just looking for some lift, I'd go shackle instead, as it won't make the unloaded ride harsh.
    Driveline vibration can be a thing on the Tundra. You'll notice it under acceleration if it happens at all. A carrier bearing drop solves it and is easy to do.
  27. Nov 1, 2019 at 6:43 AM
    #147
    NHSSTundra27
    Jesse
    2015 SR5 CrewMax
    None Yet
    Thanks for the reply. I have a crew max with the 5'6'' bed so payload is already pretty limited due to space. Its more just to gain some lift and maintain rake.
  28. Nov 2, 2019 at 11:27 AM
    #148
    KevinK
    Tundras to Sedona
    Yeah I’d look at doing a shackle instead of add a leaf in order to keep unloaded ride quality good.
    831Tun likes this.
  29. Feb 29, 2020 at 10:54 AM
    #149
    Pulido69
    Pulido69 Made in Texas!! Fight for what you love !!
    2016 black Tundra TSS off road
    I'm trying to level my 2016 Toyota tundra . I just want to bring the front end up. Not Looking to spend thousands of dollars. But am willing to spend hundreds . Does anyone have any ideas what would be the best one for that price range?
  30. Feb 29, 2020 at 10:57 AM
    #150
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I did a BDS 3/1.5 on mine. Its a 3" spacer in the front and a 1.5" shackle in the rear. I will be selling mine very soon as im going with a bigger lift !
