Grille Interchangeable?
Discussion in '3rd Gen Tundras (2022+)' started by sinisterj, Dec 31, 2021.
  1. Apr 25, 2022 at 12:43 PM
    #61
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Nope.
  2. Apr 26, 2022 at 11:23 AM
    #62
    gregor12
    gregor12 New Member
    PHIL
    2022 Tundra Limited
    did you have any issues with sensors or anything after replacing the grill?? someone tried to tell me i would have to reprogram the sensors
  3. Apr 26, 2022 at 11:28 AM
    #63
    Buellride
    Buellride New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    No problem with the sensors unless you forget to hook them up. The only sensors you actually disconnect are the main harness cables on either side of the top of the front clip, the large sensor in the grill, and the shutter control cable for the louvers behind the grill. I forgot to re-hook up the louver cable (got a message on the dash), hooked it up and all is good. Be careful with the main sensor in that if you get it dirty or otherwise you WILL get a parking brake sensor warning light and "take the vehicle to the dealer" message along with the check engine light.
    Just make sure all cables are fully seated and you should be good to go.
  4. Apr 26, 2022 at 11:54 AM
    #64
    gregor12
    gregor12 New Member
    PHIL
    2022 Tundra Limited
    Thank you for confirming! the body shop guy that was going to paint match my grill swore i would have to "reprogram all my sensors" if i removed the grill lol
  5. Apr 26, 2022 at 12:37 PM
    #65
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Body shop is probably telling you that cause you’re “suppose” to calibrate the sensors anytime removing parts with sensors. It’s actually part of the service procedure anytime the bumper is installed for accuracy of the sensors.
    You most likely won’t get any warnings message or lights but anytime you removing parts with sensor and reinstall, it could be just slightly a little off as it won’t be exactly where it was when you removed it. So you should always be calibrating sensors after repair.
    gregor12[QUOTED] likes this.
  6. Apr 26, 2022 at 1:06 PM
    #66
    Buellride
    Olympia
    THE BOULDER
    Well now I am curious, how do you calibrate the sensors??? Truth in Lending my Parking Support Brake System warning message came on after about 15 minutes.....I double checked the entire install, everything was tight and seated....I wiped the front main sensor, turned off the truck, turned it back on, and magically the PSBS check engine light went away.....
    ryanwgregg likes this.
  7. Apr 26, 2022 at 1:21 PM
    #67
    gregor12
    gregor12 New Member
    PHIL
    2022 Tundra Limited
    Thank you for sharing. Would love to know the re-calibration procedure as well
  8. Apr 26, 2022 at 3:25 PM
    #68
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    The proper way and perfectionist way to calibrate the sensors requires taking measuring tools and checking that all sensors are the right angle within specs, and making adjustment if needed. Then they would perform a calibration using diagnostic tools. Some shops will just skip the measuring part and will just do a calibration with scan tool and as long as no DTC comes back, done job.
    If you ever have professional shop work, it will be called something like ADAS (advance driver assistance system) sensor calibration on a repair order, cost of calibrations depending on vehicle. Most newer vehicle requires this service with all the driver assistance in them.
  9. Apr 27, 2022 at 6:37 AM
    #69
    lopeza86
    lopeza86 New Member
    No issues at all. Sensor sits in the same spot on both grills
  10. Apr 27, 2022 at 10:40 AM
    #70
    gregor12
    gregor12 New Member
    PHIL
    2022 Tundra Limited
    yes that was my initial thought as well until i was told about having to reprogram. looks like most people get away without having to reprogram
  11. Apr 28, 2022 at 2:10 PM
    #71
    Dick Proenneke
    Dick Proenneke New Member
    Dick
    2022 Toyota Tundra Limited
    Tonneau, 3M, Tires
    Does the standard TRD grille come with a black emblem, or chrome emblem? Do you have to buy the emblem separate, or does it come with the grille. I want to order the standard TRD grille with the chrome emblem for my limited and then color match the mustache. Need to know what to order.
  12. Apr 28, 2022 at 2:57 PM
    #72
    Buellride
    Olympia
    THE BOULDER
    If you are asking if the main Toyota Emblem centered on the grille comes with the *new* grille....it doesn't. There is just an empty space where you snap-in/apply the emblem.
  13. Apr 30, 2022 at 4:23 AM
    #73
    mattgold
    mattgold New Member
    Guys… I am soooo sorry!
    Im obviously new and forgot about this thread/post.
    53101-0C220
    Now, about those lamps!
  14. Apr 30, 2022 at 5:36 AM
    #74
    Brums
    Brums New Member
    Bethel, OH
    22 Tundra DC TRD Sport
    Sir, i believe you may have just made a bunch of people happy
    TweakedMang0 likes this.
  15. Apr 30, 2022 at 5:39 AM
    #75
    TweakedMang0
    TweakedMang0 New Member
    Jimmy
    2022 Limited - MGM - CM - 6.5ft - 4x4
    Bless, but since this is basically the trd pro grill with the camera, is there one without the camera mount?
    Just ordered and hopefully will ship in May 9-11. Stupid excited :dancingbacon:
  16. Apr 30, 2022 at 5:47 AM
    #76
    Brums
    Brums New Member
    Bethel, OH
    Probably not as the pro only comes one way, if you dont have the OR package, then you could maybe cut it off with a dremel or similar i would assume
    TweakedMang0[QUOTED] likes this.
  17. Apr 30, 2022 at 5:50 AM
    #77
    ByeF150HelloTundra
    ByeF150HelloTundra New Member
    DFW
    2022 Tundra SR5
    Just ordered! Let’s hope it fits
  18. Apr 30, 2022 at 6:05 AM
    #78
    Brums
    Brums New Member
    Bethel, OH
    i don't even have a truck yet and i ordered one as well,
    reading Romans 3rd gen OEM parts thread, looks like there is a different bracket for the cameras,
    https://www.tundras.com/threads/ult...-for-3rd-gens-2022.102951/page-4#post-2714513
    if/when i get the grill i'm going to take a look at making a bracket as i have a 3d printer that has been sitting idle for some time and i like to tinker in fusion360
  19. Apr 30, 2022 at 8:35 AM
    #79
    mattgold
    mattgold New Member
    I’m happy to help.
    But what are you all planning on doing with the three TRD lamps on top and light bar below the nameplate?
    One thing that got me slightly concerned was being on the hook for another $500 for possibly average lighting (haven’t seen the output in person).
    vosaeroplane likes this.
  20. Apr 30, 2022 at 9:48 AM
    #80
    Prohit
    Prohit New Member
    2024 Sequoia Platinum
    The question I have is about the wiring. I highly doubt these are pre-wired to accommodate the led bar. Any diagrams yet that would indicate part number for wires and switch?
  21. Apr 30, 2022 at 10:23 AM
    #81
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    I impulse ordered the trd pro grille.
    Hopefully it’s the correct one.
  22. Apr 30, 2022 at 5:13 PM
    #82
    Prohit
    Prohit New Member
    #82
  23. Apr 30, 2022 at 6:17 PM
    #83
    Jr3volution
    Johnnie
    DFW TX
    #83
  24. Apr 30, 2022 at 6:22 PM
    #84
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    If I had to guess,rejects that someone swiped from the factory rather than disposed of or Chinese knockoff attempts. They state in the description some come complete while others do not.
  25. Apr 30, 2022 at 7:32 PM
    #85
    Prohit
    Prohit New Member
    If you can zoom in clearly enough there is a part # listed on there
  26. Apr 30, 2022 at 8:04 PM
    #86
    Brums
    Brums New Member
    Bethel, OH
    according to the camera on my phone reading that QR code, 8121A-YY010 210601101714, google shows crap results
    the number in the middle did not come up on phone, PT 358? 353? - 34 2,Z? 2 0,9? -AA
    Jr3volution and jproy12 like this.
  27. Apr 30, 2022 at 8:57 PM
    #87
    Brums
    Brums New Member
    Bethel, OH
    i'm sure the clearance lights will be available eventually, one would think they wouldn't be tooo overly expensive, as far as the center light bar, that may be pricy, but you know, i actually like the look of the grill without the center light,
    My reasoning for going with the pro grill is that i absolutely hate the chrome toyota emblem, to me it looks like a goofy guy in a cowboy hat
    Nothing against cowboy hats, i just don't like the emblem and would rather see toyota spelled out in big letters
    the heritage grill reminds me of this for some reason when i see it
  28. Apr 30, 2022 at 9:47 PM
    #88
    Jr3volution
    Johnnie
    DFW TX
    Now to figure the more import part.
    How the hell do we get our front cameras to mount and function correctly………
  29. May 1, 2022 at 12:32 PM
    #89
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    #89
  30. May 2, 2022 at 5:22 AM
    #90
    Ralejandro80
    Ralejandro80 New Member
    Rj
    22 Tundra-SR5
    Lmk it's the right one also! Planning on it once it's verified to be legit.
