Ultimate OEM Toyota Parts Thread for 3rd gens (2022+)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2022.
  1. Apr 5, 2022 at 12:21 PM
    #91
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    It doesn't look like just that part of the mirror is available separately. The only part that is available separately from the assembly is the painted mirror cap. Those links I posted in the quote are for the window trim.
    HOU_4x4[QUOTED] likes this.
  2. Apr 5, 2022 at 12:37 PM
    #92
    Roman
    Roman
    Franklin, TN
    You're referring to the multi-terrain monitor system with the camera, correct? I did a little digging, and it appears the way in which the camera is mounted to the front is different depending on the grille of the truck.
    Bad news is the bracket we see holding the camera is not available separately from the camera itself, and they're all $1000. This may be a hurdle that we'll need to figure out how to get over if people are wanting to change the grille on their Tundra. Looks like someone with a 3d printer could possibly make a lot of money here. :D
    To answer your question on the grille differences, the 0C210 is showing to be the TRD Off Road grille for Platinum models, where the 0C490 is for SR5 models with the TRD Sport/Off Road package. I'd have to have both grilles in my hand to figure out what the difference is between the two. There is also the 0C500 which is for SR5 models with the TRD Off Road package and with the panoramic view monitor. Toyota is making this difficult....
    The Howard and ryanwgregg like this.
  3. Apr 5, 2022 at 12:41 PM
    #93
    Roman
    Roman
    Franklin, TN
    Correct. It is black and unpainted. I would roll with the black for a bit and see if you like it. Then, if you don't, you can always have it painted later on.
    Sure do.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grille-emblem-front-90975a2005
    TexasTundra90[QUOTED] likes this.
  4. Apr 5, 2022 at 12:44 PM
    #94
    TexasTundra90
    TexasTundra90 New Member
    Aaron
    2022 Crew Max Army Green Tundra TRD Off-Road
    2022 Crew Max Army Green Tundra TRD Off-Road Mods so far: 295/70/18 Falken Wildpeaks ‘18 Battle Born wheels ‘1.75 Rough Country Leveling kit
  5. Apr 5, 2022 at 12:47 PM
    #95
    Roman
    Roman
    Franklin, TN
    That is for the chrome emblem. I haven't seen a black emblem for the new models by itself. There are overlays you can get for it though. I need to add those to the OP.
    As far as I know it will work, but I haven't verified that for sure.
  6. Apr 5, 2022 at 3:36 PM
    #96
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    @Roman any pricing and availability on the two items above yet? Also looking for the tailgate letter inserts in black. Please and thank you!
  7. Apr 6, 2022 at 6:58 AM
    #97
    Roman
    Roman
    Franklin, TN
    No on the rock rails. I check a couple of times a week on them just to see if they have been included in the accessory guide.
    Dash cam is here:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-tun-dcam-unit-pt94934220
    Tailgate inserts are here:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-tun-bdge-black-tailgate-pt9483422002
    Medic343[QUOTED] likes this.
  8. Apr 6, 2022 at 8:50 AM
    #98
    Ralejandro80
    Ralejandro80 New Member
    Rj
    22 Tundra-SR5
    Dang, 2k for both non memory...the picture doesn't look like it's the tow mirrors and the description doesn't state that either...what's the return. Policy look like?
  9. Apr 6, 2022 at 9:42 AM
    #99
    Roman
    Roman
    Franklin, TN
    Nope, often the diagram image on the website doesn't match what the actual part is, or even the diagrams I have. The description in my catalog doesn't state tow mirror either on any of the option, but does show that it has the PVM, which from my research is the only way to get the tow mirrors. Again, this is yet another reason I wish our new car inventory was normal because I could just go out on the lot and check things myself.
    Normally, we take returns back and issue a full refund minus the shipping cost. Also, return shipping is up to the customer, unless we screw something up on our end, of course. Also, the parts can not have been installed and must be in the original packaging. Toyota won't take them back otherwise.
  10. Apr 6, 2022 at 9:58 AM
    #100
    The Howard
    The Howard New Member
    2022 White Tundra SR5
    What TRD grille part number would be correct for an SR5 without a front camera ?
    thanks
  11. Apr 6, 2022 at 12:15 PM
    #101
    Roman
    Roman
    Franklin, TN
    That's a good question. In that case, I would think any of them would work. I just can't verify without having tried to install one myself.
  12. Apr 6, 2022 at 10:20 PM
    #102
    SoCalJose
    SoCalJose New Member
    Hi @Roman , does toyota sell the adventure/tire wheel combo? or is it only a factory add on? For example if I get a base sr5 or a nontrd Limited, and I want to buy those wheels and tires. Screen Shot 2022-04-06 at 10.18.10 PM.jpg
    Medic343 likes this.
  13. Apr 7, 2022 at 5:33 AM
    #103
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    This thread should be stickied at this point!
    :thumbsup:
  14. Apr 7, 2022 at 8:51 AM
    #104
    Roman
    Roman
    Franklin, TN
    Those are the ones. Toyota still has not put out a black lug nut kit for the 2022 Tundras yet. They have the black wheel locks listed, but not the normal black lug nuts.
    ryanwgregg likes this.
  15. Apr 7, 2022 at 8:52 AM
    #105
    Roman
    Roman
    Franklin, TN
    Agreed.
  16. Apr 7, 2022 at 11:23 AM
    #106
    joescho
    joescho New Member
    Joe
    Scranton,PA
    2024 Supersonic Red Platinum
  17. Apr 7, 2022 at 12:13 PM
    #107
    Roman
    Roman
    Franklin, TN
    Nope.
  18. Apr 7, 2022 at 12:13 PM
    #108
    Roman
    Roman
    Franklin, TN
  19. Apr 7, 2022 at 12:36 PM
    #109
    joescho
    joescho New Member
    Joe
    Scranton,PA
    Roman[QUOTED][OP] likes this.
  20. Apr 7, 2022 at 5:04 PM
    #110
    CarlsSenior303
    CarlsSenior303 New Member
    Carl
    2022 Tundra Limited TRD Offroad Army Green (hopefully)
    Hey @Roman - do you all have the bed mat for crewmax short bed in stock? Part PT31834221SB
  21. Apr 8, 2022 at 9:56 AM
    #111
    606zpx
    606zpx New Member
    Roman, hoping you can answer a question and verify some part numbers:
    2022 Tundra Crewmax SB
    Are these correct numbers for the flaps
    76621-0C080
    76622-0C080
    76625-0C090
    76626-0C090
    Is this correct for short bed mat: PT318-34221-SB
    Is this correct for floor mats: PT206-34220-20
    Is the rear floor mat possibly available by itself?
    Dash Cam?: PT949-34220
    Bed step? PTS3034000
    Need correct part number for Crewmax Celestial Silver door edge guards
    Once I have this straight will put in order!
    Harry
  22. Apr 8, 2022 at 11:50 AM
    #112
    Roman
    Roman
    Franklin, TN
  23. Apr 8, 2022 at 11:56 AM
    #113
    Roman
    Roman
    Franklin, TN
    Yes to all of that, except the bed step is in two parts: PTS30-34000-ST and PTS30-34000-BK.
    Door edge guards are PT936-34221-11, or if you have a Platinum/1794/Capstone, it is PT936-34222-11. Not sure what the difference is on those.
  24. Apr 8, 2022 at 12:05 PM
    #114
    606zpx
    606zpx New Member
    To ask one more question:
    Is the rear rubber floor mat available by itself, if so part number (I like the weathershield fronts a bit better)
  25. Apr 8, 2022 at 12:12 PM
    #115
    Roman
    Roman
    Franklin, TN
    No sir, those mats are only available in a set.
  26. Apr 11, 2022 at 8:50 AM
    #116
    DoMoToyota
    DoMoToyota New Member
    Donald
    Monroe, Louisiana
    22 Tundra Limited 4x4 CM Black
    RC 1.75" Leveling Kit Cooper Rugged Trek 275/65r20 Pro Grille Diode Dynamics Grille Lightbar Rave OR Amber Grille Marker Lights GoRhino Dominator DSS Extreme step bars UnderCover Ultraflex bed cover
    Hi Roman, is it possible to get the lights and 120 power outlet for the bed?
  27. Apr 11, 2022 at 12:28 PM
    #117
    Roman
    Roman
    Franklin, TN
    Bed lights are here:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-lamp-bed-8151a0c010
    I do not know if you can add them, though. I'm not sure if there is a harness present on models that do not come with the bed lights.
    Same with the plug in the bed. I'm not sure if the wiring is there.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-socket-assembly-power-o-855300c081
  28. Apr 11, 2022 at 6:58 PM
    #118
    KelticK9
    KelticK9 New Member
    Craig
    O-Town
    2022 Tundra 1794 Midnight
    Evening Roman,
    Do you have midnight black mirror caps and item number?
  29. Apr 12, 2022 at 11:03 AM
    #119
    Roman
    Roman
    Franklin, TN
  30. Apr 12, 2022 at 11:59 AM
    #120
    KelticK9
    KelticK9 New Member
    Craig
    O-Town
