Grille Interchangeable?
Discussion in '3rd Gen Tundras (2022+)' started by sinisterj, Dec 31, 2021.
  1. Jul 1, 2022 at 2:04 PM
    #331
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Sitting at the dealership right now and showing an eta of the 14th for mine that we ordered 2 weeks ago
  2. Jul 1, 2022 at 11:27 PM
    #332
    SoCalJose
    SoCalJose New Member
    Has anyone done a pro grill swap from a Limited? If so, hows the camera mounting and did you need to put spacers in between pro grill and shutters?
  3. Jul 2, 2022 at 2:38 AM
    #333
    Brums
    Brums New Member
    Bethel, OH
    22 Tundra DC TRD Sport
    i don't know if anyone has swapped from a limited to a pro grille yet, but there are 3 threads encompassing the pro grille and its bits, this one your on, and these 2
    https://www.tundras.com/threads/22-trd-pro-heritage-grille-camera-mount-bracket.106639
    https://www.tundras.com/threads/trd-pro-grille-lights.108645
    currently a camera bracket has been developed for the pro grille, just waiting on testing and verification
    the only reason that you need spacers between the shutters and grille is if you are using the OEM center of the grille light bar, currently there have been a few found on ebay that have been bought up since they were posted some time ago, the measurements for the bolts and spacers has been posted in one of these three threads
    Azrsx and Dmon187 like this.
  4. Jul 2, 2022 at 3:56 AM
    #334
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    So the spacers are only necessary if you are using the light bar?
  5. Jul 2, 2022 at 3:57 AM
    #335
    Brums
    Brums New Member
    Bethel, OH
    Correct
    Dmon187[QUOTED] likes this.
  6. Jul 2, 2022 at 7:31 PM
    #336
    scruff1221
    scruff1221 New Member
    Ryan
    2022 Tundra Trd Off-road
    I know I’ve seen this posted on here but can’t find… can someone send me the part numbers … looking to change the front end trd chrome grille parts to matching color of my truck….
  7. Jul 2, 2022 at 9:03 PM
    #337
    Brums
    Brums New Member
    Bethel, OH
    scruff1221[QUOTED] likes this.
  8. Jul 10, 2022 at 3:48 AM
    #338
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    Anyone that swapped their Platinum grill for the TRD one, can you see what the part number is for the Platinum grill, inside it?
  9. Jul 26, 2022 at 7:20 PM
    #339
    Tundy2022#
    Tundy2022# New Member
    Forest
    Where Did you get the LED light I actually found one but I don’t have the wiring for it
  10. Jul 27, 2022 at 12:59 PM
    #340
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    TRD OR grill camera mount first prototype printed.. fit check done and making some changes to the file before one more fit up ..
    raveoffroad and doublethebass like this.
  11. Aug 3, 2022 at 11:34 AM
    #341
    roboots21
    Second prototype fit checked Monday .. made minor changes and final should be done printing this afternoon. Doing the grill swap this weekend.
    Brums likes this.
  12. Aug 3, 2022 at 10:46 PM
    #342
    knewcomb
    knewcomb New Member
    The video showing the uninstall does not show how to remove the mustache part. Is it just held in place with plastic tabs?
  13. Aug 4, 2022 at 4:17 AM
    #343
    brucega7x
    brucega7x New Member
    2022 Tundra SR5 CrewMax 4X4
    Yep. And screws.
    Yaboy likes this.
  14. Aug 13, 2022 at 11:23 AM
    #344
    Pg1329
    Pg1329 New Member
    2022 tundra limited
    Im swapping out my limited grille for a trd pro grille. Was wonder do i need to recalibrate my tss?
  15. Aug 15, 2022 at 2:50 PM
    #345
    brucega7x
  16. Aug 15, 2022 at 2:57 PM
    #346
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    not working
  17. Aug 15, 2022 at 3:07 PM
    #347
    eddiefromcali
    Eddie
    100% Stock
    assuming thats included with the switch? Order placed for the lights and switch
  18. Aug 15, 2022 at 3:33 PM
    #348
    Southshore30
    Southshore30 New Member
    2018 Limited Crew Max
    Heat gun is your friend. Really helps saving the clips from cracking right off if you hit them with a heat gun for 20 seconds or so before trying to pop the grille insert clips
  19. Aug 15, 2022 at 3:40 PM
    #349
    brucega7x
    Oof. Yeah that looks like more wiring than I'm ready to get into. I'm gonna have to stick with my peasant switch that only required 3 wires. :(
  20. Aug 15, 2022 at 3:50 PM
    #350
    eddiefromcali
    Eddie
    100% Stock
    2 jumper wires and 3 going out (12v constant, ground, 12v to light/relay) the jumpers are for the lights on the switch
  21. Aug 15, 2022 at 5:22 PM
    #351
    brucega7x
    Oh...so the three I already have are all I need. Interesting lol.
  22. Aug 15, 2022 at 6:12 PM
    #352
    brucega7x
    Sorry, not too big on electrical.
    So what I have on my current switch is 12v constant, ground, then the 12V to relay. So what exactly do the two "jumpers" on the pig tail go to? (Sorry if it's a dumb question.)
    So using my current switches wires, I would simply:
    splice the black and white both to my current ground
    splice the red and yellow both to the my current constant 12V
    splice the green to my current 12V to relay
    Is that correct?
  23. Aug 16, 2022 at 6:09 AM
    #353
    Prohit
    Prohit New Member
    2024 Sequoia Platinum
    would it dim with the other switches if wired that way? Which wire is the illumination positive? Red or yellow?
  24. Aug 16, 2022 at 1:02 PM
    #354
    918 Tundra
    918 Tundra New Member
    2022 Tundra Limited TRD Offroad
    I just ordered your raptor lights and would love to order this as well. ??
  25. Aug 21, 2022 at 6:40 AM
    #355
    Prohit
    Prohit New Member
  26. Oct 27, 2022 at 8:30 AM
    #356
    v-wiz
    v-wiz New Member
    Vic
    Lunar Rock Tundra
    If I understand correctly the Pro/heritage grill does fit on my Limited, however I would need the 3D printed camera mount and the LED bar is available through a couple of vendors (very expensive)
    My local dealer does sell the grill for around $287. Any help or guidance would be much appreciated
  27. Oct 27, 2022 at 8:32 AM
    #357
    roboots21
    With shipping you're going to pay about the same for the grill from an online source. As for the camera mount, I have 3 printed and ready to ship for $25 each (you can check my post in the marketplace also). If you're interested in that let me know!
  28. Oct 27, 2022 at 8:41 AM
    #358
    v-wiz
    v-wiz New Member
    Vic
    Lunar Rock Tundra
    Awesome, thank you. I plan to buy the grill and afterwards the mount. Thanks
  29. Oct 27, 2022 at 11:21 AM
    #359
    v-wiz
    v-wiz New Member
    Vic
    Lunar Rock Tundra
    I should mention that I have the TRD off road grill, would I still need to make modifications to fit the Pro grill?
  30. Nov 15, 2022 at 6:54 AM
    #360
    v-wiz
    v-wiz New Member
    Vic
    Lunar Rock Tundra
    Anyone have the ebay bar light who can share a photo of a nightime light output?
