TRD Pro grille lights
Discussion in '3rd Gen Tundras (2022+)' started by SirSwish32, Jun 15, 2022.
  1. Jun 15, 2022 at 10:38 AM
    SirSwish32
    SirSwish32 [OP] New Member
    Nick
    North Carolina
    2022 Tundra SR5 XP 4X4
    1.75" Rough Country Level
    Just ordered mine finally. Claims to be here in 2 weeks. Sorry if I missed this on another thread but does anyone have a link for the 3amber lights and light bar? I really don't need either one, would be ok without lights but would really like to at least have the 3 amber lights. Thanks in advance!
  2. Jun 15, 2022 at 11:25 AM
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    From what I can gather, the part number hasnt been released as of yet. Pop over to the Ultimate Gen 3 Parts thread from @Roman and follow along there...
  3. Jun 15, 2022 at 11:28 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    Marker lights and light bar aren't available yet.
    SirSwish32[OP] likes this.
  4. Jun 15, 2022 at 12:38 PM
    vosaeroplane
    vosaeroplane New Member
    2022 Tundra SR5
    Did you order the lights from Ebay?
  5. Jun 15, 2022 at 12:48 PM
    Brums
    Brums New Member
    Bethel, OH
    22 Tundra DC TRD Sport
    there are a couple of threads about the TRD Pro grill, the light bar and the lights
    https://www.tundras.com/threads/grille-interchangeable.100356/
    https://www.tundras.com/threads/22-trd-pro-heritage-grille-camera-mount-bracket.106639/
  6. Jun 16, 2022 at 5:33 AM
    SirSwish32
    Nick
    North Carolina
    I typed in the part number on Toyota then ordered from a Toyota dealer that was listed.
  7. Jun 16, 2022 at 5:40 AM
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    What’s the parts # for the marker lights and the light bar?
  8. Jun 16, 2022 at 5:41 AM
    SirSwish32
    Nick
    North Carolina
    Not for those...I was talking about the TRD Pro grille...still trying to find the lights.
  9. Jun 16, 2022 at 6:28 AM
    Brums
    Brums New Member
    Bethel, OH
  10. Jun 16, 2022 at 8:55 AM
    vosaeroplane
    2022 Tundra SR5
    Which dealer if you don't mind me asking? I tried my local dealers and it wouldn't populate.
  11. Jun 16, 2022 at 9:02 AM
    Brums
    Brums New Member
    Bethel, OH
    he was talking about the grille in that post, not the lights, no one has still found out anything about them
  12. Jun 16, 2022 at 9:03 AM
    SirSwish32
    Nick
    North Carolina
    Several popped up for me but the one I ordered from was one in New Hampshire. I will have to look up exactly which one. They basically told me there were like 64 of them coming to dealers right now and I would have it in about 2 weeks. I live in NC.
  13. Jun 16, 2022 at 10:52 AM
    vosaeroplane
    2022 Tundra SR5
    Ahh thanks! Yep I was asking about the lights.
  14. Jun 16, 2022 at 11:03 AM
    Brums
    Brums New Member
    Bethel, OH
    found this little guy at hardware store, gonna see if its close or what its going to take to make it fit when my grille gets here, its poly carbonate and that becomes pliable around 300 degrees if i need to shape it
  15. Jun 16, 2022 at 8:35 PM
    ByeF150HelloTundra
    ByeF150HelloTundra New Member
    DFW
    2022 Tundra SR5
    Where at?
  16. Jun 17, 2022 at 12:00 AM
    PK14
    PK14 New Member
    Really interested in how it looks after being installed!
  17. Jun 21, 2022 at 3:07 PM
    Brums
    Brums New Member
    Bethel, OH
    how's this? Maybe 40ish dollars in parts
  18. Jun 21, 2022 at 3:42 PM
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    need more info Chris!!
  19. Jun 21, 2022 at 3:43 PM
    Brums
    Brums New Member
    Bethel, OH
    typing it out RN
  20. Jun 21, 2022 at 4:47 PM
    Brums
    Brums New Member
    Bethel, OH
    So, i got my grille finally, working on the camera bracket, had to stop was going cross-eyed staring at the computer,
    @Jr3volution, @ByeF150HelloTundra
    i found some mini marker lights that i thought might fit the grille, and it turns out they do!
    now they may not be as fancy as the OEM ones, but they work and was cheap to do.
    oem ones fill the entire little area and have a slope to em on the front, and has that +75 HP sticker on the back of them
    what i installed,
    Soooooooooo,
    Tools Needed: *if you do the same as me,
    Drill
    Drill Bit Set, mainly 9/16, and a 5/32 for a few of them
    Some way to cut the bar stock, hacksaw, jigsaw, circular saw, porta band, cutoff wheel, die grinder with cutoff wheel, or i used an angle grinder with cutoff wheel
    some form of grinder, bench grinder, angle grinder with flap disc, etc..
    Bench vise is handy to have to bend the aluminum all purty like
    Hammer!
    Marker
    Tape Measure
    Miscellaneous hand tools, pliers vice grips etc..
    electrical terminal connector assortment
    optional:
    soldering iron, solder, heat shrink tubing
    plastic wire loom
    electrical tape
    Remember your PPE! Don't lose an eye!
    i went and saw my good buddy Homer at the Depot, (home depot for those who don't care for my bad jokes)
    Picked up a piece of 1/8 in x 1in x 3 ft aluminum flat bar stock, cost $8.00
    got the marker lights, 3 holes, 3 total... , yes i know they aren't led, i don't particularly care, $4.00 ea so $12.00
    also picked up some screws, this is what i used, use whatever you want, went with stainless as i live in the rust belt, this pack was $6.00
    now on to the fun part,
    i cut my flat bar at 24 inches as i wanted to have it overhang past the letters a bit on the sides so i know there would be support
    after i cut it, i took and laid the bar in above the letters and put the lights into place where i thought that they looked good,
    i then used a marker to mark out the base where the lights sit as you can't mark from top down, once the bases were marked i pulled it back off and used the marker light as a guide to mark the screw holes, then drilled them all with the 9/16ths drill bit.
    i then put the marker lights on the bar and used the screws to attach them,
    CAUTION - you go Hee Hawin on the screw your going to strip the aluminum where the screw is cutting the threads
    once the lights were screwed on, i then went and used a grinder to grind the screws flush on the bottom side of the bar or else it would not fit back in the spot at all
    after the lights were mounted i test fit again and all was kosher,
    took the leftover 1ft piece of bar stock and made 2 brackets by bending and cutting it, no real measurements here, i just made some that worked, they don't look the best, but they will hold it to the grille
    used 2 screws from the top of the bar down into the brackets i made, i used the 5/32nds drill bit for those holes for the screw to go through, and then used the 9/16ths on the bracket holes for them to cut threads into, these don't have to be ground down.
    after the mounting brackets were done only thing left was wiring,
    these particular marker lights use a "body" ground
    so wire all the black wires from the lights to power,+12v, "hot" whatever you want to call it
    i wired all mine together in a chain instead of 3 individual wires, you can use whatever you want to attach them together(except scotch locks - don't use those for anything they are terrible)
    me, i soldered my wires together and used some heat shrink tubing
    then i attached a ring terminal to a black wire for ground and used one of the bracket screws to hold it to the aluminum
    used a couple pieces of electrical tape to secure wires to the bar itself before i stuck it back in, could use plastic loom if you want.
    used 2 of the screws to screw the brackets to the grille!
    and finish!
  21. Jun 21, 2022 at 5:09 PM
    SirSwish32
    Nick
    North Carolina
    Man that’s awesome. Thanks for sharing this!!
  22. Jun 21, 2022 at 5:16 PM
    Brums
    Brums New Member
    Bethel, OH
    yep sure thing,
    you know what they say " first taste is free", get ya hooked!
    think this is the second time i have made a heart or two flutter, first time was getting the grille light bar to turn on without the factory connector
    i have another mod for the grille as well, but not quite done with it yet
  23. Jun 21, 2022 at 6:29 PM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    You have some skills, man! Too much work for me but if you ever decide to make more and sell them I’ll be your first customer lol
    oxlsu40 likes this.
  24. Jun 22, 2022 at 4:27 AM
    Jr3volution
    Johnnie
    DFW TX
    @Brums
    How do you feel about 3D printing some plates that will hold these leds?
  25. Jun 22, 2022 at 8:52 AM
    99ways2die
    99ways2die New Member
    NJ
  26. Jun 22, 2022 at 9:48 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I used a variation of that light on my 2014..
    FDB3B258-E8CE-43B8-8075-DDD2CAF90E48_zps_427eb1d0251338a571df4d41797bf7442a7de10c.jpg
    286637AF-C3EE-4A0D-873E-1877CC890D98_zps_8bcf3b3c6ebb7c3a2aee7f460b85c460865cd431.jpg
    B6F17F8B-D224-46F5-94D0-56B4CF45E488_zps_3d6f7a4d6dfa8ef4527d46dfd16102a8f0362dc4.jpg
    D9EBA7D3-462C-46D1-8875-3CB261A5B8D5_zps_9875b3895e5c8b8d203b1bd4b50079fb7d7ab5e7.jpg
    I put a connector inline for future grille removal.
    5F225999-563B-4406-85F4-7844858A0198_zps_38bd71c9b41ac8d77ea5450d02023e227c9d182e.jpg
  27. Jun 22, 2022 at 11:35 AM
    99ways2die
    NJ
    @1lowlife
    Yup; this is how I would have done it too (or similar).
    Clean+minimal installation.
    :thumbsup:
  28. Jun 22, 2022 at 11:42 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    They laughed at me and called me a Raptor wannabe in 2015..:eek2:
    Now it comes stock on a TRD Pro..:thumbsup:
    Mattyc, Jr3volution and g6t9ed like this.
  29. Jun 22, 2022 at 7:42 PM
    Brums
    Brums New Member
    Bethel, OH
    print to fit those holes, nah thats thinking tooo much
    i would get some of this and a heat gun, cut it larger than the light hole opening, use the heat gun to make it an L shape to go up the back of the hole, then drill two holes in the top of the grill and use some Pop rivets to hold it on, and then attach that light to the piece,
    but thats just me
  30. Jun 22, 2022 at 7:52 PM
    brucega7x
    brucega7x New Member
    2022 Tundra SR5 CrewMax 4X4
    Would any of you guys be willing to share where you’re tapping into as far as power ground, etc for your lights?
    And I mean like share in the most absolute basic of basic ways for those of us who don’t know squat about electrical stuff. Lol
    Maybe also how to go about wiring to a switch in cab if desired?
