Grease your drive shaft you lazy sods.
Discussion in '1st Gen Tundras (2000-2006)' started by Aerindel, Oct 18, 2019.
  1. Aug 19, 2021 at 8:36 PM
    AWilliams
    AWilliams New Member
    Did mine last month after 10 years...get off my case..lol
    MTRock and HBTundra like this.
  2. Aug 19, 2021 at 8:43 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Op, you are right on point with this required maintenance. And needle bearings are very weak. When they run dry, they turn to dust when other bearings just make noise.
    Cody06tundra likes this.
  3. Sep 3, 2021 at 12:40 PM
    Cody06tundra
    Cody06tundra New Member
    Cody
    2006 Tundra Crew Cab SR5 4.7L
    Just wow. It was a sealed non greasable U-joint that I imagine was original to the truck. I replaced them with Moog greasable u joints. Thank goodness that road trip was canceled. I felt the vibration on the way home from shopping and I'm so in tune with my truck I just knew something was not right. 20210903_123827.jpg
    Igrip, Bmktw2, Aerindel[OP] and 9 others like this.
  4. Sep 3, 2021 at 3:06 PM
    I can't even tell you how much better my truck feels after greasing my shaft. It drives so much smoother. No more knocking when stop/go at lights and signs.
    I'll be re-lubing every 5k or 12-18 months from here on out.
  5. Sep 3, 2021 at 3:10 PM
    Cody06tundra
    Cody
    Yeah I had a strange clunking, kind of shifting, kind of settling in the drive line when I would be sitting at a red light and the AC compressor would cycle off. I'm guessing that was probably the bad U-joint?
    And I will also be greasing at every 5k oil change from here on out. It was such a pain in the ass to change them and I don't want to do it again.
  6. Sep 3, 2021 at 3:15 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Could also be your slip yoke. That's what mine did.
    shifty` and FrenchToasty like this.
  7. Sep 3, 2021 at 4:47 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
  8. Sep 4, 2021 at 1:29 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Its amazing the clarity you have afterwards. I always try to grease it before I make any huge life decisions.
    Nimitz_, Serge928 and bmf4069 like this.
  9. Sep 4, 2021 at 7:08 AM
    Yeah, I just hate fighting the urge to stroke my motor after greasing the shaft. Good thing I'm not driving a lot these days.
    bmf4069 and Cody06tundra like this.
  10. Sep 4, 2021 at 12:33 PM
    Cody06tundra
    Cody
    Haha. Oh man.
  11. Sep 5, 2021 at 4:50 AM
    Drfarquad
    Drfarquad New Member
    Bobby
    Milford
    2005 Tundra Limited DC
    OME 3 inch lift level, UCAs, Icon AAL
    Was roughly a year since I last greased mine. Did it yesterday and oh yeah no more "bump" at stops. Super happy I did it.
  12. Sep 5, 2021 at 8:11 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Doing mine today. Any pointers? Just to confirm, they are all located on the drive shaft?
    FrenchToasty likes this.
  13. Sep 5, 2021 at 8:20 AM
    @BubbaW posted the pertinent info here: https://www.tundras.com/threads/jolt-when-stopping-at-a-light.60699/#post-1590863
    Supplemental find some commentary in these two with some tips, especially with regard to one specific zerk, and the other thread covers 4WD zerks at the end:
    https://www.tundras.com/threads/what-would-you-say-if-i-told-you.71827/
    https://www.tundras.com/threads/black-hole-zerk-wtf.93630/
    SouthPaw[QUOTED] likes this.
  14. Sep 5, 2021 at 11:35 AM
    Cody06tundra
    Cody
    Yeah once I got the new one on and the other is regrease that the ride is so much smoother now. No more low speed vibration and the clunking when the AC compressor turns off at a stop has gone away.
    Drfarquad[QUOTED] likes this.
  15. Sep 5, 2021 at 11:43 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    So no zirks on a 2006 DC RWD ?
    Tryna stay Sod-Free.
  16. Sep 5, 2021 at 11:55 AM
    Cody06tundra
    Cody
    There's not any from the factory. But you can buy them with zerk fittings or you can buy them as a sealed unit. I prefer them with those zerk fitting so that I can grease them myself.
    HBTundra[QUOTED] likes this.
  17. Sep 5, 2021 at 1:48 PM
    SouthPaw
    2000 Limited 4x4 AC
    So I’ve been working on mine for the last 30min. Either they are all full (doubtful) or the zerks are frozen. Any suggestions? I tried heating up one with a heat gun with no luck. Grease just pumps outside the fitting.
  18. Sep 5, 2021 at 2:25 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Which ones are you referring to? The 4WD zerks are a lot harder to do. Are you sure the grease gun is fully latching onto the zerk? I've had that happen too and grease will just shoot out the side.
  19. Sep 5, 2021 at 3:46 PM
    #49
    SouthPaw
    2000 Limited 4x4 AC
    All of them on the 4wd Drive lines. The one on the rear driveshaft is frozen. I removed it and tried to shoot grease through it and it still comes out the sides. I tried the other with the same results. I’ll try again next week at work on the rack with an auto grease gun but today was a failure lol.
    I did screw the tip onto the zerk and kept pressure on it as well. I think I had too much pressure on the tip because grease was coming out the sides as well as through the threads on the on the gun itself.
  20. Sep 5, 2021 at 5:18 PM
    #50
  21. Sep 5, 2021 at 6:11 PM
    #51
    SouthPaw
    2000 Limited 4x4 AC
    I feel like I was able to latch on each one. Two of them are actually right angle zerks and you can put a 10mm wrench over the zerk and twist to clock it. I had no problem getting them but grease was going everywhere except where I wanted it lol.
    Since it’s all pretty crusty, I think I may go to work and use the Hotsy to knock all the chucks out. I had all kinds of crap falling on my face and into my eyes. I also need to blast the chunks off my rear drum backing plate from when the axle seal was leaking. After that, I’ll give it a shot again and see if they will take.
    shifty`[QUOTED] likes this.
  22. Sep 5, 2021 at 6:43 PM
    #52
    I found all of the "A" zerks (propeller shaft spiders) from the FSM actually difficult to get a good lock on. I managed to do it with a a straight tip, it just took getting exactly the right angle, and the two front ones I had to rotate the 4WD shaft by hand to get the right angle.
    Next go-round, I'm going to just try my right-angle tip on the "A" zerks and see if it's an easier task. I'll say: I've been greasing stuff with zerks my whole life. I've never had an issue locking on a zerk, but my FGT really has me wanting to go out and buy one of those cheater lock-on tips with a flex hose that clips onto the zerk so there's no question, you're gonna get a good lock and the only way grease isn't going in is if something is frozen.
  23. Sep 5, 2021 at 6:47 PM
    #53
    Cody06tundra
    Cody
    I support that.
  24. Sep 8, 2021 at 12:13 AM
    #54
    swallace
    swallace Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    So I greased my Tundra drive shaft this weekend for the first time. All 5 zerks were painted black. This leaves me with a few questions…
    1. Is that a factory thing that they were painted?
    2. If so, is it a fair assumption that means they have never been greased on my truck?
    3. Truck has 92,000 miles. If the drive shaft was never greased before, should I be concerned? I have not observed any problems…but I also don’t know what I would be looking for.
    Thanks in advance!
  25. Sep 10, 2021 at 7:24 PM
    #55
    ProudTundran
    ProudTundran New Member
    2005 Tundra SR5 DC RWD
    I looked at the underside of my 2005 DC 2WD and there was not a single zerk to be found along the full length of the drive shafts.
  26. Sep 10, 2021 at 7:46 PM
    #56
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    OK sorry, there’s just something a bit off about that first sentence. Intentional? Or am I just Beavis & Butthead level immature?
  27. Sep 11, 2021 at 6:16 PM
    #57
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    2wd has no zerks.
  28. Sep 12, 2021 at 6:20 AM
    #58
    A previous owner could've replaced, or more likely maybe your previous owner sprayed the truck's undercarriage with Rustoleum to make it look one color or cover some rust? My truck has 25% less mileage and mine were definitely not painted black, they'd been used. I think the fair assumption is they haven't been recently used. How they got that way, if it's not a 1-owner truck is beyond the scope of what we here on Tundras.com can answer. And as for how much you need to be concerned, just get it done correctly, make it a regular thing every 5k miles or 12 months, and move on.
    If it helps, my stripper name in high school was Intentionally Ambiguous.
    bmf4069 likes this.
  29. Sep 12, 2021 at 6:54 AM
    #59
    FortyNorth
    Northern ON
    If it helps, my stripper name in high school was Intentionally Ambiguous.[/QUOTE]
    TMI hahaha
  30. Sep 12, 2021 at 7:54 AM
    #60
    thunder100
    thunder100 New Member
    MD
    Black 06 DC 4x4
    Thanks for the reminder just got to mine! Nice Sunday morning for a good lube. Just got the truck and at 145k they were really dry, zero evidence they’ve been done in years. Cleaned the zerk heads and they all pumped fine. Took it for a drive to get the grease worked in. Tried to clean up the old stuff that came out but still got a lot of flinging. Any good tips for cleaning them up after greasing?
