Grease your drive shaft you lazy sods.
Discussion in '1st Gen Tundras (2000-2006)' started by Aerindel, Oct 18, 2019.
  1. Oct 18, 2019 at 9:09 PM
    Aerindel
    Aerindel [OP] New Member
    Montana
    I've been having some bad and puzzling vibrations the last month or so. Only happens during acceleration, gets bad at about 20 MPH...then goes away...then gets bad again at 50-60, then goes almost away at higher speeds....goes away completely when I let off the gas.
    I replaced a badly worn out tie-rod end....little change.
    I replaced my warped brake calipers, and CV axles....no change.
    I removed the front leveling blocks....not change.
    I replaced my completely torn out center bearing....little change.
    I replaced the rear U joint.......vibration GONE!
    And when I got the joint out, I could tell that the two bearings that still had a little grease in them where just fine...and the two that had gone dry where trashed with broken needle bearings and rust everywhere.
    I should have greased the driveline first thing when I bought the truck but I kept forgetting. It was something I always did every six months on my old 94 toyota but I was out of grease...etc etc.
    But it really does matter, and a dry rusted U joint will seriously ruin your ride and make you wonder what is going on.
    In-fact...I'm still out of grease for my gun.....any recommendations for driveline grease? I used white lithium for my old truck....but the left in the rear sliding section of the driveline was pink and translucent...
  2. Oct 18, 2019 at 9:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Superlube is what I use
  3. Oct 18, 2019 at 9:56 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Op-
    That title is a Friday win!
  4. Oct 19, 2019 at 3:16 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Wish I could -my 18’ doesn’t have one dam zerk on it !!
  5. Oct 19, 2019 at 3:53 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Thanks for the reminder. I'm definitely a lazy sod when it comes to preventative greasing. Think I'll try the Superlube - mainly because of the name.o_O
  6. Oct 19, 2019 at 4:51 AM
    georgie
    georgie New Member
    2018 doesn't have them but my 2019 does ? I think I'm never going know why lol
    Mountun Goat likes this.
  7. Oct 19, 2019 at 7:07 AM
    Professional Hand Model
    Hand Protectors
    2002 Tundra 4WD
    Refer to Manual Specs for grease type.
    Corndog123, JasonC., mve and 12 others like this.
  8. Oct 19, 2019 at 7:16 AM
    Hand Protectors
    Corndog123 and Teutonics like this.
  9. Oct 19, 2019 at 7:50 PM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
  10. Oct 19, 2019 at 7:55 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    I use Lucas Red N Tacky on our 2016 4Runner with good results. My 2019 4WD Tundra does NOT have zerk fittings. Why Toyota? Why?
  11. Oct 19, 2019 at 11:08 PM
    Aerindel
    Montana
  12. Oct 19, 2019 at 11:38 PM
    marbleville
    Yep, last name too.
    State of Confusion
    Good to know that for once I didn't step in a pile of ...M&Ms.
    So your sudden project is to lube your truck, while my sudden project is to remove the anti-seize from my spark plugs. Your road is easier, if you have a lift that is.
    I just finished flushing my wife's heater in her Expedition. Ford has these quick disconnects on the heater hoses that are everything but quick disconnects. Took two days of off and on struggling to finally get them disconnected. Scrapped and bloody arms and knuckles later, I thought I'd earned a break. Nope, I've got goo on my plugs that I have to clean off. Seriously, my horses required less from me. Well, except money - horses are truly expensive. And off topic...again.
    Would you think a tampon would work to remove the goo from the spark plug hole's threads?:eek2:
    D4x4TRD and Mountun Goat like this.
  13. Oct 20, 2019 at 12:35 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Tampon in a drill.
  14. Oct 20, 2019 at 12:48 AM
    marbleville
    Yep, last name too.
    State of Confusion
    My burly old 1/2" drill is going to have issues with this, I'm sure. This might be video worthy! Chucked tampon swinging away like a drunk on a bucking horse.:rolleyes:
    Gravy, Cody06tundra, bmf4069 and 2 others like this.
  15. Oct 20, 2019 at 7:36 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    This thread title immediately brings me.back to this rock n roll classic
    https://m.youtube.com/watch?v=6bAbQgKKiwA
  16. Oct 21, 2019 at 6:13 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I dunno, but I bet the turd gen section might.
  17. Oct 22, 2019 at 4:05 AM
    Hand Protectors
    Turd Gen Section would be in full crybaby mode after gweasing their zerks.
    Thread: Gwease Stains, Help!
    “I got gwease sling on my undercawidge from the zerks. While I was under, I saw gwease stains on my diff.”
    397 responses 89 likes.
    des2mtn, Half Assed, alb1k and 6 others like this.
  18. Oct 22, 2019 at 6:06 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I've always done this with every oil change. Coming from a 4th gen 4Runner, the driveline likes to clunk at stops if its not properly lubed up. Just did it out of habit and moved the service over to the Tundra.
    Mobil1 red just ran out last week finally after a couple years and picked up a tube of the Shell Rotella HD grease for $2.50 on sale.
  19. Oct 22, 2019 at 6:12 AM
    15whtrd
    15whtrd Mr. Blonde
    I’m not crying about it! I know it will never rust in those places now LOL
  20. Oct 22, 2019 at 2:11 PM
    Hand Protectors
    You’re good. Some people over there are cwying about Class Action Suits! Hahahaha
    Half Assed and 15whtrd[QUOTED] like this.
  21. Aug 19, 2021 at 10:22 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    So, does my 2002 not have zerks because it’s RWD?
    Any pointers on how to grease her up? Do I need a needle?
  22. Aug 19, 2021 at 2:49 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    1/2 of my driveline zerk fittings are frozen. Not sure if I should hit it with a torch or something else.
    FrenchToasty likes this.
  23. Aug 19, 2021 at 3:09 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Yep. 2wd/Rwd driveshafts don't have zerk fittings or a slip yoke.
  24. Aug 19, 2021 at 4:03 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    2006 2WD DC Zirks ? I don't wanna be labeled a Sod ! LOL
  25. Aug 19, 2021 at 4:36 PM
    MEWaters
    MEWaters New Member
    Maine
    So do I just get as much grease as I can around my U joints and carrier bearing anyway?
  26. Aug 19, 2021 at 5:25 PM
    Is this true? I thought 2WD had 5, and 4WD had 8? I must've read som'n funny somewhere.
    Can't tell you how smooth my truck is driving after greasing everything up several days ago. I didn't realize I was getting little vibrations here or there. Feel like I'm sliding across hot butter in a nonstick pan while driving now.
    Mater likes this.
  27. Aug 19, 2021 at 5:38 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Nope.
    You'd have to remove them altogether to add grease. But they are considered non-serviceable, just replace if they go bad.
  28. Aug 19, 2021 at 5:45 PM
    MEWaters
    MEWaters New Member
    Maine
    Thanks. So far so good. Carrier bearing bushing has a minimal tear / wear but no vibes or noises.
  29. Aug 19, 2021 at 6:44 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I can 100% guarantee that OEM 2wd U-joints don’t have grease zerks.
  30. Aug 19, 2021 at 7:16 PM
    My 4wd U-joints don't have grease zerks either.
