Good deal (06 DC)? Hunting for my 1st Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by GIRRAS, Dec 20, 2019.
  1. Dec 26, 2019 at 11:00 PM
    #61
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    its not really much of a pan. its more of a stiffener for the bottom of the engine.
    Darkness[QUOTED] likes this.
  2. Dec 27, 2019 at 5:07 AM
    #62
    McMason
    McMason New Member
    Scott
    Boise, Idaho
    2019 TRDOR CM Cement
    Congratulations. Sounds like a solid deal to me. If those leaks aren't hitting the ground, I'd maybe re-torque some bolts and cross my fingers. Definitely wouldn't pay those dealership prices. I'd bet you can cut those brake numbers down by 50% or more by shopping online for OEM parts and bringing them to a local mechanic to install. I'm sure you'll get it all sorted without too much headache. $7k for a solid looking full size 4WD Toyota truck that has $1k worth of tires on it is a win in my book. Enjoy!
  3. Dec 27, 2019 at 5:20 AM
    #63
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    The constant vibe when pulling your foot of the gas might be the carrier bearing. I just ordered window weld to try and keep mine alive for a little longer. Seems like a common practice for the car guys.
    Anyway, good on you and enjoy your truck!
  4. Dec 27, 2019 at 6:40 AM
    #64
    Professional Hand Model
    Hand Protectors
    My thought was carrier bearing vibes, as well.
    GIRRAS[OP] and KarmaKannon like this.
  5. Dec 27, 2019 at 6:41 AM
    #65
    Bubbles
    Bubbles Decent!
    Sunnyvale Trailer Park
    05 Tundra Limited, 96 Supra Turbo 6MT
    Congratulations! And agreed on that vibration likely being the carrier bearing.
    GIRRAS[OP] likes this.
  6. Dec 27, 2019 at 8:06 AM
    #66
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    Cool beans!:bananadance::dancingbacon::broccoli:
  7. Dec 27, 2019 at 9:12 AM
    #67
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Congrats! Keep us posted as you start the rehab on your new-to-you truck.
  8. Jan 8, 2020 at 10:44 AM
    #68
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Depending on the leaks, you probably don't need to do those repairs. If you're losing enough fluid that you adding regularly then I would, but small leaks are normal and not a big deal. My steering rack leaks, but I haven't had to add fluid in 6 months. Stick with OEM brake drums, but order online. You should be able to have a shop replace the rear brake shoes for around $100. Fronts are dead simple check youtube and give it a shot.
  9. Jan 8, 2020 at 11:50 AM
    #69
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Have the dealer replace those bulbs at 65.00
    I could do a few of those a day and retire
