Glass breakage sensor install and setup
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sting Ray, Dec 30, 2017.
  1. Jan 8, 2018 at 9:24 PM
    trainracer
    trainracer New Member
    I'll try to get pictures this weekend
  2. Jan 9, 2018 at 4:50 AM
    Sting Ray
    Sting Ray [OP] New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    No worries man. I don't want you to tear your truck apart just for that. Someone sent me the instructions for the 3rd gen and I think I can figure it out. Thanks though.
  3. Jan 18, 2018 at 5:17 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Got it installed, piece of cake. Actually didn't even need tech stream as it was already to set to use it. I adjusted the sensitivity so it would go off when I clapped my hands loudly inside the cab.
    Harness/plug for it was taped up to the yellow harness hereIMG_6202.jpg
    Here's a closeup
    Mounted it here
    Pretty simple.
  4. Jan 18, 2018 at 7:11 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Watching this one...
    Sting Ray[OP] and epa4wd like this.
  5. Jan 18, 2018 at 7:23 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    If you decide to do it let me know if you have any questions.
    Les7311[QUOTED] likes this.
  6. Jan 18, 2018 at 8:26 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    So alarm is working fine now?
    Sting Ray[QUOTED][OP] likes this.
  7. Jan 18, 2018 at 8:35 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Yes It worked fine before but didn't have the glass break sensor before.
    joonbug likes this.
  8. Jan 18, 2018 at 8:45 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Your alarm worked before the gbs? I turned my alarm on via techstream but don’t think it is working. Figured I needed the gbs. Hmm, I guess I need to try again.
  9. Jan 18, 2018 at 8:54 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Yes my alarm worked before installing the gbs. If you activated yours with techstream it should work as well. It doesn't need the gbs to work. You can test by sitting in the truck, locking your door with your fob, the lock light on the dash should come on steady, then after 30 seconds it should blink, now manually unlock your door, the horn should go off.
    bulldog93 and (deleted member) like this.
  10. Jan 18, 2018 at 8:58 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah I tried that but it didn’t work. I’ll try it again. I just always thought I needed the gbs. Good to know though. Thanks.
  11. Jan 18, 2018 at 9:00 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Do you have the alarm in passive mode? It should be if it's not already. You may have missed turning on a setting in techstream. I did that the first time I activated it.
    joonbug likes this.
  12. Jan 18, 2018 at 9:10 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Here's install Instructions as well as ops check instructions. The instructions I got with the gbs were for 2nd gens, even though they are pretty much the same these have better pics. The tech stream part didn't apply to mine as it seems like this was for an older version then what I have. http://toyotaparts.sparkstoyota.com/install/PT398-34142inst.pdf
  13. Jan 18, 2018 at 9:11 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Gonna hook back up on Sunday and see.
  14. Feb 8, 2018 at 4:25 PM
    Tom_Tundra_TN
    Tom_Tundra_TN New Member
    Tom
    2016 TRD CM
    TRD Exhaust, TRD Front&Rear Sway Bar, TRD Shifter Knob, BFG TAKO2, Toyota GBS, 3/1 Leveling Kit, K&N CAI, Leer 100XQ Topper, Tinted Windows, Tacotunes Upgrade, Bed LED Lights, Mirror Caps & Door Handle Color Match, BedRug, LED Interior Lighting, Tailgate Tundra fill, Toyota Step Rail, Katzkin Leather Seats, Leather Console, FRAC Harness, Stubby Antenna, Power Folding Mirrors, Autoloc One-Touch Window Mod, TRD Pro Wheels w/ Lug Nut Covers, Color Match Bumper Ends
    Installed the GBS today following your instructions and it worked perfectly. Mine worked before but I didn't have the GBS. I didn't do anything but install and plugged the two connectors. Thanks...
    Sting Ray[OP] likes this.
  15. Feb 8, 2018 at 4:29 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Awesome! Glad to hear! I was thinking of upping my sensitivity a notch the next time I tear my dash apart.
  16. Feb 8, 2018 at 4:33 PM
    Tom_Tundra_TN
    Tom
    2016 TRD CM
    I set my sensitivity to about 7 or 8 and the tapping on the glass with my key set off the alarm. The factory setting didn't set it off.
  17. Feb 8, 2018 at 4:47 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    I set mine to where the tapping on the glass didn't set it off but clapping my hands loudly did. I work at an Air Force base so I didnt want jets setting it off all day every day. But that hasn't happened yet so time to up it a little
  18. Feb 21, 2018 at 1:18 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  19. Feb 21, 2018 at 1:37 PM
    #49
    owb2gp
    owb2gp New Member
    ID
    I just bought a 2018 Tundra and the window sticker does say Anti-theft System with Alarm. I'll test it tonight to see if it's activated. So if mine is activated when I do the test how do I stop the horn and lights flashing?
    And if it's not activated I'll be going to the dealer to have it activated. I don't see how they can charge you when it's listed on the window sticker.
  20. Feb 21, 2018 at 2:17 PM
    #50
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Just hit your unlock button on the fob
  21. Feb 21, 2018 at 2:21 PM
    #51
    owb2gp
    owb2gp New Member
    ID
    Thanks!
  22. Feb 21, 2018 at 2:37 PM
    #52
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    When you're sitting I. The truck and after you lock it the little lock light on the dash will blink. Once it stops blinking and goes steady that means your alarm is armed (usually 30 seconds) but depends on what it's set to. Then you can open the door handle from the inside to set it off
    bulldog93 likes this.
  23. Feb 21, 2018 at 2:45 PM
    #53
    owb2gp
    owb2gp New Member
    ID
    Thanks for the info!
    Where would I change the settings?
  24. Feb 21, 2018 at 2:47 PM
    #54
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    You'll need to buy techstream and an obd cable
  25. Feb 21, 2018 at 2:49 PM
    #55
    owb2gp
    owb2gp New Member
    ID
    I honestly haven't had a car alarm in 20 years so I have a stupid question. To test it you have to actually open the door from inside the vehicle but would the alarm go off if the truck was locked and somebody pulled on the door handle from the outside?
  26. Feb 21, 2018 at 2:50 PM
    #56
    owb2gp
    owb2gp New Member
    ID
    :thumbsup:
  27. Feb 21, 2018 at 3:11 PM
    #57
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    It goes off when the alarm is armed and a door or the hood is opened. Or if you have a glass breakage sensor when it hears a loud noise.
  28. Feb 21, 2018 at 3:33 PM
    #58
    owb2gp
    owb2gp New Member
    ID
    Gotcha. Thanks!
  29. Feb 22, 2018 at 6:20 AM
    #59
    owb2gp
    owb2gp New Member
    ID
    Tested it last night. My alarm is activated. Thanks for all the help!
  30. Mar 25, 2018 at 7:41 PM
    #60
    mileena
    mileena New Member
    Keoki_m and bulldog93 like this.
