General Supercharger Thread
  1. Jun 17, 2022 at 11:32 AM
    #2221
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I learnt on this forum - once your are blown, exhaust don't matter....bigger the better. @dirtydeeds
  2. Jun 17, 2022 at 12:04 PM
    #2222
    AZTundra
    Paul
    Phoenix, AZ
    Ok, thanks for the insight and $ saved.
  3. Jun 17, 2022 at 12:05 PM
    #2223
    Saltyhero13
    Saltyhero13 Throbbing Member
    nobodyintexas and Silver17 like this.
  4. Jun 17, 2022 at 12:20 PM
    #2224
    Saltyhero13
    Comments on remedy for dual torque loss:
    Any torque loss felt after installation of TRD dual exhaust?
    At best you'll regain what you lost with the exhaust but I doubt it will be significant.
    Tire weight is more important than diameter. Lighter is better but depends on your application if it is even feasible to do so.
  5. Jun 17, 2022 at 1:30 PM
    #2225
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Did you know
    if my intercooler pump is actually on. My intake temp is 132-ish
    if the damn relay ain’t working it will be 167
    that’s how much the HX Works
    Now I go back in this thread and order that new relay
    have a great weekend
    Taking the plaid on a road trip
    Silver17 and Saltyhero13 like this.
  6. Jun 17, 2022 at 1:42 PM
    #2226
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Agreed on the fact that once you have a supercharger that dual exhaust torque loss is no longer a thing. I too have TRD duals. As far as tires, I just went from 32 lb wheels with 69 lb tires to 27 lb wheels with 65 lb tires. Also the diameter shrank from 33.4 to 32.7”. Hard to say on full throttle acceleration if it’s noticeable by the seat of my pants, I’m sure it would put down a couple more hp on a chassis dyno. I have noticed better gear holding on hills though.
  7. Jun 17, 2022 at 2:36 PM
    #2227
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Silver17[QUOTED] likes this.
  8. Jun 17, 2022 at 2:45 PM
    #2228
    Silver17
    Eastern PA
    No problem! Mine has worked flawless so far. Don’t forget to swap the included 30amp fuse out for the correct 10 amp in your excitement to change it! Lol
  9. Jun 17, 2022 at 2:56 PM
    #2229
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Here’s what is weird
    When it faults. my Amber backlights are not on. My damn main fogs are on
    that’s how I caught it
    I Shake the relay and it all goes back to normal
    it never ends….
  10. Jun 17, 2022 at 2:57 PM
    #2230
    Saltyhero13
    You can try rotating it 90 degrees to see if it keeps it from sticking.
    Edit: Also dampen with a rubber pad.
    nobodyintexas[QUOTED] likes this.
  11. Jun 17, 2022 at 3:13 PM
    #2231
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Another observation
    leaving my house the temp was 159
    I thought, damn heat soak
    then it stay that temp till I got to the main road, went about. A mile
    then
    I hit a bump and the temp dropped to 129 in about 20 seconds
    that’s how good it works
    HonorNotInner and Silver17 like this.
  12. Jun 17, 2022 at 4:45 PM
    #2232
    Saltyhero13
  13. Jun 17, 2022 at 5:57 PM
    #2233
    Saltyhero13
    Tells me the HX is doing a big chunk of the work to lower charge temp. Edit: relative to Ambient
  14. Jun 18, 2022 at 2:36 AM
    #2234
    nobodyintexas
    nobodyintexas What?
    South of Houston
    agreed.
    and it works fast. it was quite awesome to watch the temp dropping.
    I guess ~129 is the thermal wall.and/or capacity limit for the HX.
    It was 96 degrees yesterday.
  15. Jun 18, 2022 at 5:37 AM
    #2235
    Silver17
    Eastern PA
    Living in Texas, if you were crazy enough about it I bet you could use 80% distilled water and cut the antifreeze portion down to about 20% and still have enough freeze protection but have much better heat transfer. Water is a lot better heat transfer medium than glycol. Glycol also takes more pump energy to move around the system. Here is brief article on the subject that lays it out quickly and concisely. https://www.motortrend.com/how-to/glycol-or-water-coolant/amp/
  16. Jun 18, 2022 at 6:14 AM
    #2236
    Silver17
    Eastern PA
    Wow check this out too. I would assume the Harrop could suffer from a similar issue as this magnuson (both tvs2650). Sounds to me like the design and intention of putting the sensor after the intercooler is good for reading the real IATs, but only if they did a proper job of precisely locating it. There’s evidently a solution in the way of these 1” thermal spacers which helps getter a better reading. They also create more of a thermal barrier between the hot engine and the blower housing which keeps the blower from getting as hot. I gather that our actual IAT is likely cooler than our sensors are telling us it is based on their location. The problem with this is if it says it’s too high it can pull more timing and thus make less power. On the flip side the ECU thinking the IAT is hotter could be safer as it will pull timing it advance and likely prevent knock. Either way, the reading being accurate would probably be the best of both worlds. Maybe if there was enough interest Prospeed would make them for our trucks. https://fiinterchillers.com/product/magnuson-2650-tub-spacer/
  17. Jun 19, 2022 at 6:22 AM
    #2237
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I hear you
    but the speed in which the HX pulled the temp down from 156 to 129 tells me our system is quite adequate
    it also tells me it works exponentially better when the f’ing pump is on!!!
    I’m gone give the water thing a go. See what happens
    I’m willing to bet the 129 degrees is fairly accurate. And your comment about reading a higher temp is safer. Is comforting
    129 iat on a 97 degree day is kosher with me
  18. Jun 19, 2022 at 11:57 AM
    #2238
    Saltyhero13
    Nice numbers. Sealed box is probably better if you aren't constrained by air flow.
    Took the truck out on a spirited drive last night. Definitely hit the +40 degree over ambient threshold.
    Can't say how much is pulling air from the bay and how much is the S/C coolant soaking up heat. Based on your numbers I would bet it is pulling about 50% or more from the bay (without a larger or second hole).
    Someone mentioned Water wetter to me; not sure if you can run it through the intercooler.
  19. Jun 20, 2022 at 9:11 AM
    #2239
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Just an FYI,, Whipple has updated their pull down tab on the years now to include the 2021 Tundra,, 72 hundred and some change and they are also saying you add the flash tool. -200 if you choose no flash tool. Plus it says the supercharger comes with new injectors.
    Saltyhero13 and AZTundra like this.
  20. Jun 20, 2022 at 9:51 AM
    #2240
    Saltyhero13
    Too bad it took them so long. Whipple was my first choice, even had a significant end of the year deal on one. No tune meant no joy. If even possible, probably would have needed a 90 to 100mm pulley to run it without a tune (until they got it sorted) lol
    For anyone interested in Whipple, I recommend signing up to their site's newsletter for periodic deals. You can do the same with the local speed shops in your area if you don't plan on doing the install yourself. I've seen deals as high as -20% off in some cases.
  21. Jun 20, 2022 at 9:58 AM
    #2241
    nobodyintexas
    nobodyintexas What?
    South of Houston
    my memory...
    did we agree - way back when - that the whipple, while possibly producing a cooler charge, lacks a smidge of low end TQ compared to the Roots/TVS style?
  22. Jun 20, 2022 at 11:06 AM
    #2242
    Saltyhero13
    I think it was @ViktorG that made some comments about the Whipple.
  23. Jun 20, 2022 at 12:31 PM
    #2243
    Black@Blue19
    Ken
    SE Texas
    Whipple has done some rearranging in the last couple years from what I read if I remember correctly. That being said they do state running low RPMs theirs run without boost and produce better city/highway MPG or something to that effect??:)
    I’ll look and see if I can find their exact words so I can phrase that better.
    here it is, they still have it up on their site.
    The all-new system features Whipple’s massive oversized air-to-water intercooler for unmatched cooling capacity, the massive 2.9 liter Whipple twin-screw supercharger that reaches 99% volumetric efficiency, 102mm built in inlet, high flow intake manifold and industry leading power potential. The unique bypass system offers less than 1hp of consumption during cruising for excellent fuel economy.
    So I imagine there might be the slightest whatever but doubt if it would be that noticeable?? But who knows, I have not run one or the other so I can’t say. I hope that will change some day. I have been waiting for Whipple to join the fun for Tundras.
    nobodyintexas and Saltyhero13 like this.
  24. Jun 20, 2022 at 12:55 PM
    #2244
    Silver17
    Eastern PA
    That’s how it looks based on comments from the Prospeed guys who install all 3. I’ve seen videos of other cars like 5.0 mustangs and camaros comparing the larger Whipple to the TVS. Usually the smaller TVS blowers give a stronger punch down low, and despite being smaller often can make higher peak numbers as well.
    Whipple strikes me as the Ford Motor co of superchargers. All talk with playing the numbers game and claiming to be the biggest and best performing, but for many applications they are not. I think there’s more to picking the right supercharger for your vehicle than largest displacement. Larger doesn’t necessarily mean better IMO. A smaller blower will be more spun up at lower speeds which is better for snappier torque at the lower RPMs. I guess I just figure if you can have more low end torque, why go with a Whipple that makes less but also doesn’t make more up top either.
  25. Jun 20, 2022 at 12:57 PM
    #2245
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    My ex will argue with you on that one.
  26. Jun 20, 2022 at 2:50 PM
    #2246
    Saltyhero13
  27. Jun 20, 2022 at 2:56 PM
    #2247
    Black@Blue19
    Ken
    SE Texas
    I wish there were real world numbers with the same model same year Tundra with the four systems on them. Harrop, Magnuson, ProAir, Whipple. From what I have read Whipple isn’t bad bigger is better with the right application, ProAir sounds good on paper too. You can find what ever you want to find on each of the four but if there was a real world (Show Me Whatcha Got)!! there would be no fudging on that.? Just put a bigger fuel pump on with injectors hook up the Superchargers and run it on the same dyno??:)
  28. Jun 20, 2022 at 3:30 PM
    #2248
    nobodyintexas
    nobodyintexas What?
    South of Houston
    There is a tundra whipple install on YouTube
    Vivid racing I think
    I’ll look in morning
    I think that’s the one that shows boost down low is lacking a tad.
    at the end of day. Its all about low end grunt. Top end ain’t fun is a 6000lb rolling brick
    and ~600hp is about the limit on the stock blocks
    so get your low end first, the roots/tvs type will get your there
    Black@Blue19 and M3Tundra-JK like this.
  29. Jun 20, 2022 at 3:45 PM
    #2249
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Is proair = pro charger? I heard that is cancelled.
    Sometimes, part of me says what's the point, as EVs are just so fast, which I'm sure you are aware with the plaid, save money and spend it on something else.
    Then sometimes, the part of me says, "why not turbo it...... Or why not keep the sc and add turbo..... And why not challenge the laws of physics...."
  30. Jun 20, 2022 at 3:56 PM
    #2250
    nobodyintexas
    nobodyintexas What?
    South of Houston
    All good points
    ev’s are brutal. We took a 190mile road trip. Fillup cost $23. Disregarding the cost of the car for now.
    A 500whp tundra is perfection.
    Utilitarian and scoots. You can haul shit and carry full size humans.
