General Supercharger Thread
  1. May 28, 2024 at 4:10 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Some folks are running blocky AT tires and they are still managing to push sub 5s laden with some even pushing sub 4s.
    Wheel hop and axle wrap are the bigger problems in my experience. Once you tame hop/twist, GripPro or locker. Not saying rubber wont help, its just part of the equation.
    I've considered running the 420Vs as a second set but their wet performance has kept me away. They run in F if you tow but for drag you probably don't want them that heavy.
  2. May 28, 2024 at 4:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    I spoke with Baxter Performance and they confirmed there is no issue running a sandwich thermostatic cooler off their adapter.
    They have heard of certain issues with sway bar contact. In their query of incidents the sway bar bushings were old or loose. Also front end damage that shifted the engine or loose and worn engine mounts caused the sway bar contact with oil filter. The sway bar should only have torsional force.
  3. May 28, 2024 at 5:04 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    What are people utilizing to manage wheel hop/axel twist...full four link systems or similar?
  4. May 28, 2024 at 5:07 PM
    Saltyhero13
    Traction bars or to a lesser degree RAS
    Winks4x4Toy, ARES35 and Mdl like this.
  5. May 28, 2024 at 5:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  6. May 28, 2024 at 5:18 PM
    Saltyhero13
    Yes the RAS don't tame it completely. There is a set of bars that allow offroad articulation and decent clearance but I can't seem to find them in my history or bookmarks. Traction bars for drag/street set ups, RAS for towing/offroad set ups.
    ARES35 likes this.
  7. May 28, 2024 at 5:19 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Long travel spring under helps with axle wrap lol
    BajaTurd, Fastlane47, ARES35 and 3 others like this.
  8. May 28, 2024 at 5:22 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’ve never had axle hopping issues with mine personally, I just have a progressive AAL mini leaf pack on the stock leaf pack. I’m sure the axle still rotates under the springs like a mofo though when laying on the throttle.
  9. May 28, 2024 at 5:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Forgot about the SDHQ ones...
    Winks4x4Toy, BigAl, reywcms and 2 others like this.
  10. May 28, 2024 at 5:39 PM
    Saltyhero13
    Mdl[QUOTED] and BigAl like this.
  11. May 28, 2024 at 6:15 PM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    Can confirm the SDHQ traction bars do their job. Spendy, but also make sense if you're like me and destroyed a driveshaft because of too much axle wrap and throttle misuse when in Mexico!
  12. May 28, 2024 at 6:44 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Same here. Ran a Deaver mini pack for years and currently an Icon leaf pack. The Grip pro LSD really helps until I get home and do the AWD swap.
  13. May 28, 2024 at 6:55 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's my next thing to do. Go AWD and ditch my burnt Auburn for Powertrax... cause with the PNW rain I be spinning. The @snivilous 2.0 pulley doesn't help!
  14. May 28, 2024 at 6:57 PM
    Saltyhero13
    Yes. I know others have pushed these platforms harder without issue.
    Filmed mine attempting launches. While Toyota overbuilds their kit I don't think the U joint would last long with the abuse I was witnessing. I figure I better be safe than sorry.
    BigAl[QUOTED] and Mdl like this.
  15. May 28, 2024 at 7:01 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I noticed with my traction bars it really hooks up and has more stable cornering. As I don't have a rear sway bar.
    ARES35, BigAl and Saltyhero13[QUOTED] like this.
  16. May 28, 2024 at 7:03 PM
    Saltyhero13
    Your rear leafs are likely in better condition than mine.
    Next for me is a suspension upgrade and brakes after I finish tweaking my exhaust.
    reywcms and Mdl like this.
  17. May 28, 2024 at 7:44 PM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Currently running RAS, some aal's and sway bar. Tried to set up for towing for loaded trailer with distribution hitch, it was sagging pretty bad in the past. With RAS on stiffest setting and the rake im level with heavy load. When not towing and in 4 hi truck launches pretty damn hard. No traction issues here with that combo.
    Saltyhero13 and HulkSmurf14 like this.
  18. May 28, 2024 at 7:53 PM
    ARES35
    Mile high
    That's sounds like my P0420 code. Tip in on throttle and bam. Clear code, mid throttle and misfires, wacked out Air/fuel. Sounds like a broken cat to me:mad:
  19. May 28, 2024 at 8:19 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Yeah around here if you want to do anything other than making noise I have to be in 4wd. Driving around in my FJ “AWD” manual the difference is very noticeable. I wonder what it would cost for a shop to put in the Land Cruiser torsen box.
    Mdl[QUOTED] and Saltyhero13 like this.
  20. May 28, 2024 at 9:19 PM
    blenton
    blenton New Member
    Paging @Jowett and @ViktorG
    I don’t recall if the LC box will work in 2014+ since the sequoia box is ‘13 and earlier only due to the electronics change that came with the new tundra case in 14.
  21. May 28, 2024 at 9:52 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Gen 2.5 2014+ is a no go until someone figures out how to swap in the Aisin style transfer case.
  22. May 28, 2024 at 9:57 PM
    Saltyhero13
    There is an AWD conversion thread lurking around here somewhere. Pretty sure its a carry over from another forum (that a few of you are read into)
    Ponderosa_Pine and Mdl like this.
  23. May 29, 2024 at 5:35 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'm in 4HI 99% of the time.
    Terndrerrr, LILTRD and HulkSmurf14 like this.
  24. May 29, 2024 at 5:36 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  25. May 29, 2024 at 6:51 AM
    Saltyhero13
  26. May 29, 2024 at 7:53 AM
    LILTRD
    LILTRD New Member
    2013 Tundra RCSB
    Mdl likes this.
  27. May 29, 2024 at 8:03 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Loaded a final revision tune in the truck from @snivilous and can say this thing is dialed. Adjusted the pedal sensitivity back off since it was too touchy for me in the dirt over the big hits and made a tweak for the LS 103. The shifting and drivability is perfect. Siked how its come together with this new intake setup. Thanks @snivilous
    ZPhilip, e30cabrio, ARES35 and 9 others like this.
  28. May 29, 2024 at 8:09 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That is great news! @snivilous is a great help!
    bflooks, e30cabrio, ARES35 and 3 others like this.
  29. May 29, 2024 at 8:20 AM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Rey's current tune is all the way at +50% for airload to make the throttle body happy. I'll get your tune tweaked and sent over in a couple minutes.
    e30cabrio, ARES35, Wynnded and 2 others like this.
  30. May 29, 2024 at 8:31 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Sweet! Even though the turbokits MAF is dialed in I can't get PE for low rpm's as I'm already making 2-6psi and at 3rd gear in the 12's for afr.
    So I'm looking forward to it! Start from scratch as @Wynnded did.
