General Supercharger Thread
  1. Apr 4, 2023 at 12:50 PM
    #7261
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    That's what I understand as well, boost is a measure of restriction, basically more air going into the head than can be processed and exhausted out of the head, the headers alleviate some of this pressure so the head can flow more. HP is a direct result of CFM, so the more you can get through your head the more power you'll unlock. The stock pistons are prone to issues resulting from heat and shock, the limit with the stock rods is RPM. Tuning is the key in controlling all three of those and pulling power before it becomes a problem, but then you're only pushing the envelope to become "that one guy that ran his Tundra at 700HP on the stock internals...until he didn't".
  2. Apr 4, 2023 at 12:56 PM
    #7262
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    If you’re going magnuson and not looking to get carried away i would personally go with the 2.3 pulley, 650cc deatschwerk injectors and deatschwerks 300c 340LPH pump, and a custom tune. I have that setup on my Harrop with an 80mm pulley which is about the same amount of air/boost and it’s just right. Runs great, reliable, no problems, just get in and enjoy it. Should be in the 600ish crank hp range.
  3. Apr 4, 2023 at 1:02 PM
    #7263
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Is there a knock off issue with this pump?
  4. Apr 4, 2023 at 1:05 PM
    #7264
    Silver17
    Eastern PA
    The Deatschwerks or the Walbro?
  5. Apr 4, 2023 at 1:07 PM
    #7265
    e30cabrio
    Deatschwerks. I know Walbro has an issue, I need to order a pump
  6. Apr 4, 2023 at 1:12 PM
    #7266
    Silver17
    Eastern PA
    Not that I’m aware of. Could order off their website to be sure. They make a kit for the tundra. It gets installed just like replacing the stock pump. It’s the highest flowing pump that fits in there like OEM to my knowledge.
    HulkSmurf14 likes this.
  7. Apr 4, 2023 at 1:17 PM
    #7267
    Saltyhero13
    Saltyhero13 Throbbing Member
  8. Apr 4, 2023 at 1:25 PM
    #7268
    e30cabrio
    Ordered from their site. I just want to be done. I'm going to order fuel line too & get rid of the plastic hoses just in case. What did we land on being the best?
  9. Apr 4, 2023 at 1:35 PM
    #7269
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    e30cabrio[QUOTED] likes this.
  10. Apr 4, 2023 at 1:36 PM
    #7270
    e30cabrio
    Email confirming the order says 4-5 business day shipping, called and was told expedited shipping is not expedited handling, we're slammed it will be 4/10 the earliest. I canceled the order.
  11. Apr 4, 2023 at 1:37 PM
    #7271
    e30cabrio
  12. Apr 4, 2023 at 1:39 PM
    #7272
    M3Tundra-JK
    Scott
    2005 GX470
    I just used the one to replace the feed line from the new pump, and also for the radium venturi
  13. Apr 4, 2023 at 1:42 PM
    #7273
    e30cabrio
    So to do both feed & return & the Radium I'd need 2? I'm ripping it all out & going new.
  14. Apr 4, 2023 at 1:45 PM
    #7274
    M3Tundra-JK
    Scott
    2005 GX470
    Just the one covered both. I used 8" of plastic PTFE hose for the syphon part of the Venturi. But you could just get a second Gates hose for that part.
  15. Apr 4, 2023 at 1:51 PM
    #7275
    e30cabrio
    I'm just afraid of everything at this point. I thought I had covered every angle but I'm ripping it apart & starting over & I just want this to be it!
    I'll order 2 & go from their Thanks!
    M3Tundra-JK and HulkSmurf14 like this.
  16. Apr 4, 2023 at 1:53 PM
    #7276
    e30cabrio
    It said 1 left, I ordered it and ordered another that it said would be delivered Saturday
    Fastlane47 likes this.
  17. Apr 4, 2023 at 6:10 PM
    #7277
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    What was your specific issue(s) that caused you to get this harness?
    Saltyhero13 likes this.
  18. Apr 4, 2023 at 6:13 PM
    #7278
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, interesting. I emailed and got a reply from him Sunday. He didn't suggest anything, but we really weren't on that subject. I was just updating him on a glitch that we were experiencing with my tune (it turned out to not be the tune) that I'd sorted and I asked a tune related question that he didn't have information about. I miss the drag strip videos...:burnrubber:
  19. Apr 4, 2023 at 7:38 PM
    #7279
    AZTundra
    Paul
    Phoenix, AZ
    Hopefully your order is on track for delivery.
    Mine was supposed to be delivered today and now it shows running late with a new expected delivery date of April 5 - April 6. It notes if it doesn't arrive by the next day (4/7) I can cancel for a refund. Problem is that I leave on Thursday for CA and don't return until Sunday afternoon and my install date is Monday morning. If it doesn't show up on time I don't have time to order another one at that point.
    Just placed an order for another kit from Summit with next day air so I'll get it on Thursday.
  20. Apr 4, 2023 at 7:42 PM
    #7280
    e30cabrio
    Mine says tomorrow but not shipped.
    HulkSmurf14 and AZTundra[QUOTED] like this.
  21. Apr 4, 2023 at 9:06 PM
    #7281
    ZPhilip
    Philip
    West Chester, PA
    No pics but I just swapped out my 85mm Harrop pulley for the 80mm. First pulley swap here and it took under 15 minutes.
    Easy peasy how to:
    Broke free the 4 bolts on the pulley while the belt is still tight. Loosened tensioner with my 1/2” breaker bar and was able to jam it on top of the sway bar to keep tension off the belt. Swapped pulley, blue Loctite 4 bolts, put belt back on all the various pulleys it moved off of, release breaker bar on tensioner, and then finally use my imaginary torque wrench to snug up bolts.
  22. Apr 5, 2023 at 4:12 AM
    #7282
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I'll chime in from the peanut gallery. As I usually lurk or worse say wrong sh1t.
    I am Harrop w/ 80mm pulley + 650cc injectors. I use the fuel pump that came with the Harrop. whatever that is.
    So, I'm a "base" stage 2. my intake is stock.
    I love it. it's my daily driver.
    if you decide to jump in, but not wanting get your head under water....do a base stage 2, like @Silver17 said.
    Get it done at a shop that has done a few.
    get it tuned on a dyno at the same shop. aim for 10's AFR at WOT.
    a TRD exhaust makes things sound great.
    then, life will be good.
    this whole stage 2 kit is avail at Harrop for a single purchase. or at it was at some point.
    oh...and put in cooler spark plugs...because someone said so.
    Saltyhero13, V10Ace, Silver17 and 2 others like this.
  23. Apr 5, 2023 at 5:33 AM
    #7283
    nchlsbr
    nchlsbr New Member
    2018 Tundra
    Good deal lol. I like to tinker a bit as well. Just can’t with this truck as it is daily driver/work out of it and can’t afford for it to be down with this and that. Posted a while back that I have stock Maggie setup OTT tuned and love it. Just wanted a bit more. I also have a coworker who has a whipple on his 5.3 Silverado and need to show him the deal lol.
  24. Apr 5, 2023 at 5:59 AM
    #7284
    e30cabrio
    It shipped!
    AZTundra likes this.
  25. Apr 5, 2023 at 7:16 AM
    #7285
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Honestly if there's any single modification with a stock supercharger, or if looking to bump the power, I think it's getting a wideband AFR gauge. Everything else to support more power is an assumption, but a wideband will actually tell you cold hard facts like if you're running out of fuel and how safe your tune is. There is a lot of data and knowledge it gives in real time, and it's an easy install if you can find someone with a welder and 5 minutes of their time.
  26. Apr 5, 2023 at 7:18 AM
    #7286
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    Without it the fuel pump doesn't come on at key turn and it takes a little bit to build pressure so the truck doesn't always start right up and cranks for a few seconds.
    armyoffoo likes this.
  27. Apr 5, 2023 at 7:36 AM
    #7287
    Silver17
    Eastern PA
    The fuel jumper harness is to remedy the issue of the aftermarket FPRs not holding pressure after shutdown. @ZPhilip is using the OE style FPR which should maintain fuel pressure, so that’s probably not his issue. It’s more likely going to be tune related in regards to the airflow adder based on coolant temp as well as the larger injectors effecting the startup fueling. If the airflow adder adjustment doesn’t fix it, adjusting the injector pulse width at startup is probably the next step based on what I had read on the issue.
  28. Apr 5, 2023 at 7:38 AM
    #7288
    e30cabrio
    I had the slow(er) start with the oem FPR fwiw. It's only a few cranks vs immediate, not that big a deal imho
  29. Apr 5, 2023 at 8:07 AM
    #7289
    nchlsbr
    nchlsbr New Member
    2018 Tundra
    Yep. Will be the first on the list.
  30. Apr 5, 2023 at 8:24 AM
    #7290
    snivilous
    SW UT
    I don't think the startup airflow has anything to do with it, that doesn't seem to be related to fuel pressure at startup and his tune doesn't show a startup pulse width. I've only seen that on one tune file actually, so it seems to be an uncommon version.
