General Supercharger Thread
  1. Oct 28, 2021 at 4:42 AM
    #511
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    I can certainly understand some apprehension! They way I look at it, I’ve already achieved guinea pig status by slapping a 2.6 liter blower on my truck without a tune which goes against everything the tuning community knows about forced induction. So getting a custom tune, even if by someone newer to the game, probably isn’t the worst thing. If the place was up the road from me I’d give it a look.
    Saltyhero13 likes this.
  2. Oct 28, 2021 at 4:49 AM
    #512
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    oh Contraire' ... Harrop tested our unit & it safely stayed on the map with the 85mm pulley. they also said it needs a tune for anything over that.
    I confirmed this with dyno results from my installer. (let's leave out my lean codes for now)
    then...I read the stories that @Saltyhero13 so graciously posted, and shudder at having to replace a 3UR.
    with that said...I'll go by there and confirm if my skeptical meter is accurate.
    I'll report back forthwith.
    The main dude is very kind & easy to communicate with. I'm presently working on both those skills....
  3. Oct 28, 2021 at 4:55 AM
    #513
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    “We cannot support the 21 Sequoia yet.
    Thanks,
    Dinesh Hospeti
    www.d3performance.net
    260 Dickinson Avenue
    League City, TX 77573”
  4. Oct 28, 2021 at 6:09 AM
    #514
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Thanks for the info I’m def looking into this then!!
  5. Oct 28, 2021 at 6:30 AM
    #515
    nobodyintexas
    nobodyintexas What?
    South of Houston
    If you have the $, the Harrop solution is quite nice.
  6. Oct 28, 2021 at 9:52 AM
    #516
    Saltyhero13
    Saltyhero13 Throbbing Member
    I sincerely hope this works out to be a great product. Skeptical on the delivery of "Stage 3 big HP" however, at least not without fortifying the engine and transmission.
    This thread has a lot of details that went into his project, its worth the read/watch.
    https://www.tundras.com/threads/pro...-1000-hp-daily-driven-awd-tundra-build.54634/
  7. Oct 28, 2021 at 10:17 AM
    #517
    Silver17
    Northeast
    Based on what I’ve read, unless you’re going to build up the engine internally there isn’t more safe power to be had beyond what a stage 2 Harrop with the addition of a 4.5” intake, RCF throttle body, Longtube headers and parallel/Prospeed fuel system, and an ITP valve body can provide. I would have to assume his “stage 3” would be a package consisting of those additional parts but that is a total guess as I don’t believe they are engine builders. That would be pushing it to its max, and at that point you are making 600whp give or take.
    Saltyhero13[QUOTED] likes this.
  8. Oct 28, 2021 at 10:18 AM
    #518
    nobodyintexas
    nobodyintexas What?
    South of Houston
    "Skeptical on the delivery of "Stage 3 big HP" however, at least not without fortifying the engine and transmission."
    agreed.
    The 2650 Eaton can easily put 14psi into the engine. however, the stock engine can't take it. 8psi is the upper limit - best I can tell.
    I'm OK with my 6psi......for now.
    easy as that.
  9. Oct 28, 2021 at 10:20 AM
    #519
    nobodyintexas
    nobodyintexas What?
    South of Houston
    past stage 2 (8psi)you would, at least, need ...rings, rods & bearings. and an open tab @ discount tire.
  10. Oct 28, 2021 at 10:39 AM
    #520
    Saltyhero13
    I think you are 100% correct. The closer to 600WHP the more disproportionately expensive the mods get to squeak out the extra HP.
    I would be happy if the AWD swap was an option for newer model Tundras (2014+).
    https://www.tundras.com/threads/how...013-tundra-to-full-time-awd-capability.54474/
    ViktorG likes this.
  11. Oct 28, 2021 at 10:43 AM
    #521
    Silver17
    Northeast
    SDHQ built one with the following setup:
    “2014 FFV, Harrop Stage 2, parallel fuel rails, Ti Automotive 450lph fuel pump, delete FFV control valve, all 6AN fittings with 3/8" pressure and return lines, 46psi at idle with boost reference hooked up, 4" intake, stock 76mm throttle body, stock manifolds and coverter, Magna Flo cat back single exhaust.”
    So with factory exhaust manifolds and all the cats in place it made 543whp and 555wtq on a dynapack hub dyno. The same mods but adding long tubes on seems to net you another 50-60hp.
  12. Oct 28, 2021 at 10:44 AM
    #522
    Saltyhero13
    "Sir, will you be having the racing slicks again?"
    "No those were MT Tires."
    boostedtrdpro and snivilous[OP] like this.
  13. Oct 28, 2021 at 2:47 PM
    #523
    Saltyhero13
    RE: Pressure ratio question I asked earlier regarding reading the adiabatic map.
    The simple calculation is done by (gauge boost pressure + 14.7 psi)/ 14.7 psi; the adjusted calculation is similar (gauge boost pressure + 14.7 psi)/(14.7 psi - 1 psi for depression)
    So a pressure ratio of 1.3 means you are creating 4.41 gauge boost psi . If you adjusted for depression it means you are creating 3.11 gauge boost psi.
    A pressure ratio of 2 means you are creating 14.7 psi or 13.7 if you use the adjusted formula.
    The article goes into calculating air flow as well as explaining other fundamentals (for turbos and centrifugal superchargers). Just keep in mind some of these factors like surge lines and choke lines wont apply to TVS blowers. The VE still applies.
    https://www.garrettmotion.com/news/...derstanding-calculations-to-turbo-any-engine/
    sd172 likes this.
  14. Oct 28, 2021 at 2:55 PM
    #524
    Saltyhero13
  15. Oct 28, 2021 at 3:29 PM
    #525
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  16. Oct 28, 2021 at 3:33 PM
    #526
    boringdriver
    boringdriver New Member
    2015 LX 570
    Have my appointment with Prospeed setup in November to do the following upgrades to my LX 570:
    -Prospeed fuel system (billet fuel rails, 750cc injectors, 450lph in-tank, adjustable FPR, 6AN feed and return lines)
    -American Racing Headers long tube headers 1-3/4" x 3" with high flow cats
    -Harrop 80mm pulley
    -Magnuson air box lid with AFe pro dry filter
    -HP Tuners ECM and TCM tuning on an AWD dyno
    Honestly I'm most excited about the tune and the headers. I'm on a stock cat-back so the increase in sound should be subtle in a good way. I don't think the stock catback will be holding me back too much.
  17. Oct 28, 2021 at 4:03 PM
    #527
    d3performance
    d3performance New Member
    We are working on a SC patched calibration for all 2018+ Tundras. This calibration will included many of the changes that Toyota added for their FitKit calibration. We should have this available for testing by the end of next week.
  18. Oct 28, 2021 at 4:10 PM
    #528
    Vizsla
    Vizsla pretend2send
    The black truck beside mine is Harrop charged with 600hp at the wheels, sorry don’t have better pic.. Sounds nasty.
  19. Oct 28, 2021 at 4:16 PM
    #529
    sd172
    sd172 New Member
    South Dakota
    Thank you @Saltyhero13. You are too good to us.
    Dr Doobie likes this.
  20. Oct 28, 2021 at 4:19 PM
    #530
    sd172
    sd172 New Member
    South Dakota
    Any chance for the Sequoias being supported as well? How different are the ECUs compared to Tundras?
  21. Oct 28, 2021 at 4:20 PM
    #531
    Saltyhero13
    Most welcome!
    Trying to share what I find so folks can make informed decisions. Please question what I post or correct any errors I made. I'm not a motor-head mechanic type so I'm trying to get up to speed with the rest of y'all.
  22. Oct 28, 2021 at 4:23 PM
    #532
    Saltyhero13
    Welcome to the forums!
    When you are ready I would recommend introducing yourself and your product in a separate thread under "Performance and Tuning" (not sure if special permission is required from the mods)
  23. Oct 28, 2021 at 4:52 PM
    #533
    Saltyhero13
    Is this person a member here? Did they share a build out with you?
    Thnx
  24. Oct 28, 2021 at 5:13 PM
    #534
    Silver17
    Northeast
    Is this the same truck?
  25. Oct 28, 2021 at 6:12 PM
    #535
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Do IT! Mine will be here in just a couple short weeks…join the crew :thumbsup:
  26. Oct 28, 2021 at 6:24 PM
    #536
    boostedtrdpro
    Jeremy
    Speaking of, I know it’s a big ask, but I’d be forever in debt to you guys if you could come up with a few talking points I should hit on with the installing shop. Harrop says this shop has installed one before but it wasn’t their first choice. Their first choice was a shop 70 miles one way from my house that wouldn’t even return my calls or emails, let alone get me a quote on the install. I really dig the vibe I get from the shop that will be doing it, but I know very little about superchargers and installing them. I’ve had turbos my whole life, but never a supercharger. Is there any concerns or things I should talk to the shop about regarding the install? My main concerns at this point are the lean codes @nobodyintexas is getting and the PCV issue @Puba was having…hoping his issues are a thing of the past.
  27. Oct 28, 2021 at 9:37 PM
    #537
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    My thing as I’m doing more research into truly turning my truck into a monster is between whipple and magnusons they both require injectors and tune and this doesn’t just the fuel pump. What’s the difference? More hp from others so needs tune?
  28. Oct 29, 2021 at 1:46 AM
    #538
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yes. the 85mm pulley (~6psi)is the limit for the stock ecu to run a harrop. go higher and you need a tune.
  29. Oct 29, 2021 at 1:50 AM
    #539
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'm stepping up to starter fluid this weekend. I will find the vacuum leak!
    the truck runs perfect until I idle during a cold front.
    it never runs lean under load.
    and......this cool front has me averaging 18.2mpg for 175 miles. not running a/c compressor.
  30. Oct 29, 2021 at 3:18 AM
    #540
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I am intrigued & jealous. a Dirty Deeds exhaust would be the cherry on top. A vicious sounding LX.
