gear indicator lamp
Discussion in '1st Gen Tundras (2000-2006)' started by chunk, Mar 31, 2017.
  1. Feb 18, 2019 at 1:21 AM
    Aerindel
    Aerindel New Member
    Montana
    For my truck I bought these for the PRNDL lights.
    https://www.amazon.com/gp/product/B01FS6R30A/ref=ppx_yo_dt_b_asin_title_o00__o00_s00?ie=UTF8&psc=1
    You keep the holder and straighten the wires and pull the old bulbs and then place the new bulbs in that same holder and just bend the wires into the right shape and cut to length. Works very well and is much cheaper than the OEM replacement lights that coset $12 each!
    I wish I had taken some pictures showing exactly how you do it, but once you look at the OEM holder and bulb you will see how its just the bends in the wires that hold the bulb in the holder in the first place so you just make the wires on your LEDs match that.
    You may have to break the original bulb to get it out of the holder as some of mine seemed stuck but that is no big deal.
    And remember, if it doesn't light, turn the holder 180 degrees and try again.
    For the other lights I used these, they where direct plug in replacements.
    https://www.amazon.com/gp/product/B01DE7UC6C/ref=ppx_yo_dt_b_asin_title_o03__o00_s00?ie=UTF8&psc=1
    And these:
    https://www.amazon.com/gp/product/B00LVFIVT0/ref=ppx_yo_dt_b_asin_title_o02__o00_s00?ie=UTF8&psc=1
  2. Feb 18, 2019 at 3:33 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    NEO-4 is what you're looking for.
  3. Feb 18, 2019 at 5:49 AM
    Professional Hand Model
    Hand Protectors
    I could be wrong here, but not so sure the LED bulbs will fit the P and D. The OEM bulb is shaped to fit in the cluster assy.
    In other words both bases (LED and/or Halogen) fit, but the ‘bulb’ portion of the LED is too big and the OEM halogen fits perfectly. Revisit post #6 of this thread to see the proper bulb. That is what I used for the P and D.
  4. Feb 18, 2019 at 9:25 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    The Neo4 LEDs will work because they're the whole assembly, I'm sure a single chip would work but you'd have to find one with the wires attached.
  5. Mar 6, 2019 at 7:21 AM
    Poli169
    Poli169 New Member
    Apolinar
    2001 red tundra sr5
    @Somemedic did you have any issues when replacing the brake light and the gas indicator one with led? I did mine and not sure if it's cheap bulbs or why they stay illuminated. All others seem to work fine.
  6. Mar 8, 2019 at 9:03 PM
    Somemedic
    Somemedic New Member
    Mark
    2000 SR5 AC Cab/ 2010 Dbbl Cab Long Bed
    Yak racks Awning LED dash LED headlights / fog lights Hellwig Helper springs KC HD springs Bed slide out Sony AX100 w/ cam SOS Big Brake front kit Rancho 9000 front / rear
    No issues. Some seem brighter tho
  7. Mar 9, 2019 at 8:26 PM
    CelticNomad
    CelticNomad New Member
    2000 SR5 Thunder Grey Tundra. Stock.
    Neo 4's are the way to go. Replaced the "P" and "D" and sorry I didn't replace them all. Do em all I say.
    matkes77 likes this.
  8. Mar 11, 2019 at 11:36 AM
    RayD
    RayD New Member
    I would love to do the blue conversion but my Tundra is a 2000 has a green lit radio unit. Can the radio head unit backlight be changed? Also, for the indicator lights like park, drive, airbag, seatbelt, etc, as well as the Climate Control, are these to be ordered in white? I guess I'm confused as to what lights need to be which color.
    matkes77 and Bad Jackson like this.
  9. Mar 11, 2019 at 1:04 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The light on the OEM radio cannot be changed to my knowledge. You're better off putting a new stereo in. It's extremely easy and inexpensive.
    No. The lights in there now are white with a green condom over them. You could just remove the condom and improve the color but if you're going to open up the dash you should just go ahead and throw new bulbs in.
    The Neo 4's mentioned above are apparently a good replacement for the indicator bulbs. If you look at the first page in this thread you'll have all the info you need to replace the bulbs.
  10. Mar 13, 2019 at 1:47 PM
    Somemedic
    Mark
    Red/orange would also be a nice look. I'd change the radio out to a a bluetooth touchscreen with navigation. They're just too damn handy not to
  11. Mar 16, 2019 at 12:26 AM
    Alath-Qul
    Alath-Qul New Member
    First gen tundra
    Those blues look great. I will definitely be looking into this as my Drive gear indicator light is out too.
  12. May 9, 2019 at 8:45 PM
    Coro
    Coro New Member
    2002 Tundra 3.4L V6
    Does anybody know if there is a bulb for the mileage area. I have a 2002 SR5. Also I changed the larger bulbs to LED but on the speedometer, it only brightens up to the 60mpg mark..everything else is light instead of blue
  13. May 10, 2019 at 12:00 AM
    NMTundra
    NMTundra New Member
    No bulb for the odometer. There is, however, a removable green film on the odometer between the light source and the LCD which when removed will make the odometer white. That being said, I wouldn't attempt it unless you're really, really good with electronics. There's a decent chance of really screwing it up just with the static electricity from your fingers if you aren't extremely careful. There's a write up over on Tundrasolutions on how to do it, think it's buried in the old gauges thread.
  14. May 10, 2019 at 9:10 AM
    Coro
    Coro New Member
    2002 Tundra 3.4L V6
    Thanks NMTundra...you may have saved me from a mistake
  15. May 10, 2019 at 10:21 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    Don't you guys find the LEDs a bit (okay, a lot) bright as an incan replacement? I used the Neo4 as a Homelink button bulb replacement in our Sienna and you could see it from orbit, it was so bright.
  16. May 10, 2019 at 10:57 AM
    Hand Protectors
    Yes, but....
    I replaced the control panel with new incandescents for your reason above with no rubbers. Cheaper in cost and the white color does well.
    I replaced the instrument panel with LED (blue indigo color) as its easy on the eyes for me anyways. Not bright but clear with a color I like. If they were white LED, then yes the orbit would probably light up.
  17. May 10, 2019 at 12:39 PM
    PKFan
    That makes sense. For some reason the blue and amber are wayyy dimmer than the green (and certainly the white) LEDs.
  18. May 12, 2019 at 2:17 AM
    DJI76
    DJI76 New Member
    2006 Tundra Double Cab
    Icon 3" Stage 2 lift. 33"x12.5" on 18" K&N Cold Intake Stereo with Infinity speakers n 12" JL sub and amp Trying to install keyless with remote start.
    I have a 2006 double cab. When I pulled my instrument panel out and separated it to get to the circuit board. There is no place to replace the lights. Do I have to remove where the needles attached to the board.
    I changed out all my climate control lights with LED red and love it. Please Help want my gages to mach
  19. May 12, 2019 at 2:20 AM
    #49
    NMTundra
    NMTundra New Member
    2005 and 2006 aren't user replaceable unfortunately. All you can do is carefully wet sand the green tint off the back of the speedometer face and then replace it with a red tint if you can find one.
  20. May 12, 2019 at 2:44 AM
    #50
    DJI76
    DJI76 New Member
    Thanks man that's what I thought I looks like the the lights are soldered on the board already.
  21. May 12, 2019 at 6:06 AM
    #51
    Hand Protectors
    Another thing, before swapping in the LEDs, I removed the green rubbers from the OEM incandescent bulbs to see how they’d look and was impressed. The 02’ instrument panel went from a dimly light green to a whiter reddish with orange look (and much brighter due to rubbers off with same exact bulbs). It was a nice look.
    In retrospect, I probably would have kept it this way but had already ordered and taken possession of the blue LEDs.
  22. May 12, 2019 at 2:06 PM
    #52
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    Talk about timing, my "D" went out three days ago and I had come to believe it not worth tackling with the instrument panel and all confronting me. Now, having read your posts, I believe it will be an easy enough project and I will undertake it soon with the help you guys have provided.:hattip:
  23. May 12, 2019 at 4:27 PM
    #53
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    My D light just went out as well! Ordering bulbs tomorrow:spending:
  24. May 12, 2019 at 4:59 PM
    #54
    Hand Protectors
    Do the ‘P’ lights as well!
  25. May 12, 2019 at 7:01 PM
    #55
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Yes I am just going to replace all of them. Just not sure what color to go with.
    Leaning towards blue just don't want it to look ridiculous.
  26. May 12, 2019 at 8:50 PM
    #56
    marbleville
    Yep, last name too.
    State of Confusion
    All my lights work except the D. Would like to replace them all with orange (?) if it is available.
  27. May 12, 2019 at 8:57 PM
    #57
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Can you post the link?
  28. May 13, 2019 at 2:20 AM
    #58
    Festerw
    Festerw New Member
    04 Tundra DC
    The color for those are on the cluster so if you use something besides white you'll get a weird visible color.
  29. May 13, 2019 at 3:19 AM
    #59
    marbleville
    Yep, last name too.
    State of Confusion
    Wow, that one is less than clear to me, so I must be missing something, besides not knowing who was being addressed. In any case, weird visible color is contrary to MY desire for a harmonious color display of my choosing. And disappointing, as well. Please elaborate, and settle what you mean by weird for this elderly control-freak in me.
    Bad Jackson likes this.
  30. May 13, 2019 at 4:05 AM
    #60
    Festerw
    Festerw New Member
    04 Tundra DC
    Pretty much you'll end up with a muddled most likely brownish color from the colors mixing. That whole mixing non primary colors, blue might be ok since you'd likely end up with different greenish color.
