gear indicator lamp
Discussion in '1st Gen Tundras (2000-2006)' started by chunk, Mar 31, 2017.
  1. Mar 31, 2017 at 5:45 AM
    chunk
    chunk [OP] New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
  2. Apr 11, 2017 at 7:51 AM
    AZ59apacheguy
    AZ59apacheguy New Member
    Pete
    2003 SR5 TRD Tan
    Good timing,I'm doing that exact process today. Here is the number I used and I got it off eBay:
    9001111032 - BULB, INTEGRATION CONTROL & PANEL - Toyota
    I think the number you have is the wrong one. I saw a video on YouTube on how to do this procedure and the proper part number. It does not look hard to do and I will post if I get chance swap it out today.
    TX-TRD1stGEN likes this.
  3. Apr 11, 2017 at 11:19 AM
    chunk
    Thanks, for the part #. Yeah, post how it all goes if you can. I'll check that number. Chunk.
    Edited to add: i just checked that part number here :
    https://www.toyotapartsdeal.com/oem...ta&Model=Tundra&Year=2001&Submodel=&Filter=()
    and it said it doesn't fit my 2001 Tundra. Hmmm? I'm trying to avoid tearing it apart until i have the replacement lamp. If it comes apart without much difficulty i guess i could go to Napa and try to match it up, the dealer is 60 miles away and may have to order the correct lamp, leaving the truck apart. Don't want to do that. Chunk.
  4. Apr 11, 2017 at 1:39 PM
    AZ59apacheguy
    Pete
    2003 SR5 TRD Tan
    Got done a little while ago and it was a breeze. Here is the video I used on how to do it
    https://youtu.be/6v1QfmGjTxw
    I think the bulb number you listed was for the general lighting of the cluster. The number I gave you is specifially for the " D " bulb.
    Dad01, tacoguybill and Somemedic like this.
  5. Apr 11, 2017 at 2:08 PM
    chunk
    Thanks for the info. I think you're correct on the part # i had, i did more research and i think i need the part # you have. Chunk.
  6. Apr 15, 2017 at 4:07 PM
    chunk
    So, i received my "D" bulb from Toyota today and got it installed. The new one had a green condom over the bulb, the one that came out, the old one was naked. I removed the green sleeve. Not sure why it was there unless some years require it, and some don't. Just curious, any comments on the bulbs that anyone has installed? Condom or naked? Chunk.
  7. Aug 8, 2017 at 3:46 PM
    Truper
    Truper New Member
    2002 Green Tundra TRD
    New headlamps.
    Thanks chunk and AZ59apacheguy. I've been searching for this part for the better part of a week. Found that part number on Amazon, but didn't need it colored and didn't know that the coloring was just a sleeve. Finally stumbled across this forum. I had to replace two different bulbs in my cluster: The 'D' indicator & the cruise control indicator. I didn't have bulbs for either, so I switched them with others I never use or didn't need (the 'L' indicator and the ABS indicator (since I don't have ABS)). The cruise control indicator has a removable bulb (TSD74), which should be easy to find, so I don't have to order the entire part.
  8. Aug 9, 2017 at 11:01 AM
    Somemedic
    Somemedic New Member
    Mark
    2000 SR5 AC Cab/ 2010 Dbbl Cab Long Bed
    Yak racks Awning LED dash LED headlights / fog lights Hellwig Helper springs KC HD springs Bed slide out Sony AX100 w/ cam SOS Big Brake front kit Rancho 9000 front / rear
    Do yourself a favor....
    Count what bulbs you need. Go to superbrightleds.com and do it up right. Never worry about them again. It may take a few days but you'll dig the results.
    matkes77, edison, Poli169 and 5 others like this.
  9. Jan 22, 2018 at 6:43 PM
    Griller
    Griller New Member
    Rodney
    2002 Black Tundra Limited
    Do you remember the part numbers from superbrightleds.com on the gear indicator leds?
  10. Jan 22, 2018 at 7:31 PM
    Somemedic
    Mark
    PC74 -20qty
    NEO4-xHP - 14qty
    194 - 10qty
    I don't recall which is what. They're all on the dash, either in the instrument cluster or over in the climate comtrol/radio area. The blue is nice to look at and easy on the eyes at night. They're also dimmable. I had several out, thought the green looked dated and wanted to go something that poped. Red would have been my next choice. The background on the don't head unit used a lot of blue so.... I think it's much nicer than before.
    On a side note I did just order the 9006 LED fog bulb (which is ridiculously brighter than the silverstars) and the head light LED as well. It's a direct fit and you can hide the ballast in the frame hole. 10min install on those. The headlights are $39 right now and come in bright white with filters so you can blue them up (about 6500k) or yellow like fog lights.
    edison and Bob Bash like this.
  11. Jan 23, 2018 at 6:28 AM
    Griller
    Griller New Member
    Rodney
    Thanks for the info. I took a shot in the dark and ordered
    7 -NEO4-NWHP: 4mm NEO4-xHP Natural White I was just hoping this was the right size. From your post it looks like I got the correct size.
    Bad Jackson likes this.
  12. Feb 11, 2018 at 5:18 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Easy job, and yea I replaced all with new ones since I was there....................and they don't last, get the LED's, that's what I'm going with next. Has anyone noticed that light bulbs don't last very long like they used to back in they day, but yet we are more technically smart. Someone is laughing their way to the bank.
  13. Feb 18, 2018 at 9:20 AM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Ordered for my Gen1, will see how's it fit.
  14. Feb 18, 2018 at 1:20 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    Man, that looks really good!! Might just have to put this on my to-do list.
  15. Dec 11, 2018 at 1:20 PM
    BigStu
    BigStu New Member
    2002 Tundra Limited
    I am about to do this on my truck. I'm using superbrightleds.com as well. I'll do I follow up once I get them.
    15whtrd likes this.
  16. Dec 11, 2018 at 4:55 PM
    Professional Hand Model
    Hand Protectors
    Just did the blue conversion too. Used Sylvanias (size 168) from auto store as they are lifetime warranty. Noticed you have a ‘white spot’ at your 80 mph where there is the T-5. Same thing happened here, but I ordered blue T-5’s to fix this as auto stores do not sell that size.
    Somemedic[QUOTED] and Jerry311SD like this.
  17. Dec 17, 2018 at 11:05 AM
    BigStu
    BigStu New Member
    2002 Tundra Limited
    I've attached a pic of the back of the instrument cluster. Also, here is a break down if all the interior lights if you want to do a full LED conversion like I did.
    • 2x 36mm festoon for map lights
    • 1x 30mm festoon for dome light
    • 2x 194/168/T10 for door lights
    • 1x 74 LED for glove box
    • 1x 3mm for fog light button
    • 3x 194/168/T10 for climate control
    • 2x T5 for climate control
    • 7x 4mm for instrument cluster
    • 4x 194/168/T10 for instrument cluster
    • 20x T5 for instrument cluster
    Feel free to mix up the colors as you like. Pro tip - make sure the LEDs come on before securing everything back down completely. If they don't come on take them out, turn them halfway, then reinstall. LEDs won't function if polarity is reversed. I'll post a pic with my finished product.
    Bad Jackson, edison, mtntop and 3 others like this.
  18. Dec 17, 2018 at 11:45 AM
    Hand Protectors
    Map Light LED for the 02’.
  19. Dec 17, 2018 at 11:48 AM
    Hand Protectors
    Climate Control for 02’
    Bad Jackson, Y2KTundra guy and edison like this.
  20. Dec 17, 2018 at 11:52 AM
    Hand Protectors
  21. Jan 4, 2019 at 1:22 PM
    20limited04
    20limited04 New Member
    2004 DC Limited 4x4
    To those that have done the instrument cluster replacement with leds, is there a length maximum for the new bulbs? The 168s come in too many sizes and lengths. Do you need only forward projecting leds or side projection also?
    Thanks in advance!
  22. Jan 4, 2019 at 2:10 PM
    Hand Protectors
    Depends on your application on forward vs. side projection.
    LED 168 Sylvanias should fit just right for you as they did for me.
  23. Jan 4, 2019 at 2:45 PM
    BigStu
    BigStu New Member
    2002 Tundra Limited
    I ordered ice blue T10 bulbs from Amazon. Since they are for the backlighting of the cluster I got the 360 bulbs. You will also need 1 T5 bulb for the backlighting, which I also got on Amazon.
  24. Jan 6, 2019 at 4:31 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I ordered a 10 pack of T10 bulbs for the initial purprose of lighting the glove box and driver foot well.
    Finally arrived today and they either sent me the wrong thing or I ordered incorrectly. These are about 10x bigger than what I need.
    Left is old glove box bulb, right is what I received.
    https://www.ebay.com/ulk/itm/251620379636
    Can you just tell me what I should buy?
  25. Jan 6, 2019 at 4:35 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    #74 is what you need.
    I used these
    https://www.superbrightleds.com/mor...md-led-miniature-wedge-retrofit-car/228/1068/
  26. Jan 6, 2019 at 4:38 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  27. Jan 6, 2019 at 4:42 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    They'll work for most of the cluster, hvac, and door lights. There's 1 74 in the cluster also.
  28. Jan 6, 2019 at 5:01 AM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from Northeast Connecticut New members. Good luck on your light bulb changes.
    NUDRAT likes this.
  29. Feb 17, 2019 at 4:04 PM
    ahenning33
    ahenning33 New Member
    Andy
    Payson, AZ
    2014 Super White Tundra SR5 TRD
    Working on doing a full led replacement for 03 Tundra. I've heard that you can't just replace the bulb for the gear indicators and that you have to buy the housing as well. Trying to do this at superbrightleds.com and can't seem to find the right part. Any help would be greatly appreciated. Thanks!
    Aerindel likes this.
  30. Feb 17, 2019 at 6:23 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    This needs to be a sticky!
    MNtundra likes this.
