Gauges app on Kenwood stereo
Discussion in 'Towing & Hauling' started by AZBoatHauler, Jan 28, 2020.
  1. Jan 28, 2020 at 8:04 AM
    AZBoatHauler
    AZBoatHauler [OP] SSEM#140 / 2.5 gen plebe
    So.Arizona
    Just wanted to give a heads up for everyone that tows or hauls heavy loads with their Tundra - I replaced the Entune head unit with a Kenwood in order to get wireless CarPlay and as a bonus I learned Kenwood has a gauges app that lets you tap into the OBD system and get instantaneous read outs for items like transmission fluid temperature, coolant temp, engine load, etc. See pic below. It also has programming to give you 0-60 and 1/4 mile times.
    :burnrubber:
    avssuc, AGia15, plumber802 and 9 others like this.
  2. Jan 28, 2020 at 8:10 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    So you simply had to tap a wire from new stereo to your obd or did you add maestro?
  3. Jan 28, 2020 at 8:17 AM
    AZBoatHauler
    So.Arizona
    avssuc and Jrharvey02 like this.
  4. Jan 28, 2020 at 8:37 AM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Are you able to program any of the gauges? For instane, adding both the transmission pan amd torque converter temps.
  5. Jan 28, 2020 at 8:48 AM
    AZBoatHauler
    So.Arizona
    Only one choice for transmission temp. Here is the full list of options for the gauges. The ones with an “x” in front are not available.7A6C326B-0432-48F8-A8ED-C1707D9C4408.jpg D36AF130-9914-4DE4-9FE1-E278324A2607.jpg 324E3EDB-E217-4E64-9744-404C03911710.jpg 7477F17F-F1EC-4321-923E-E1318F3A9FFE.jpg F5F8C3B7-572F-486D-A7C2-0974EF42DC28.jpg 132536BA-8B98-40A2-9F27-F5FCF2DDB781.jpg
    plumber802 and Toyotoholic like this.
  6. Jan 28, 2020 at 9:19 AM
    Tuham817
    Tuham817 New Member
    2014 SR5 Crewmax
    I got my kenwood(dmx9706s) installed by a local a shop and has steering wheel control as well. However, I do not see any gauges available? I’ve got a ‘14 SRT
  7. Jan 28, 2020 at 9:29 AM
    Jrharvey02
    me too! I want to add this, but not if involves removing and rewiring my sound system...
  8. Jan 28, 2020 at 9:32 AM
    AZBoatHauler
    So.Arizona
    Maybe they didn’t run the OBD wire to the wiring harness? Do you have a Gauges app show up in your head unit? Everything you need comes with the TO2 wiring harness from Maestro. You can see the OBD connector in the picture from Maestro linked above.
  9. Jan 28, 2020 at 9:37 AM
    Jrharvey02
    I think on mine, they must have used something other than maestro. I have the gauges app on my pioneer, but can’t “select” it.
  10. Jan 28, 2020 at 10:00 AM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    There is an OBD connector that allows you to have gauges displayed on the kenwood. It only has one wire connected to it (brown color) I believe but it’s part of the meistro wiring.
    AZBoatHauler[OP] and 14CRWMX like this.
  11. Jan 28, 2020 at 11:33 AM
    Tuham817
    Tuham817 New Member
    2014 SR5 Crewmax
    I’ve got the same issue as jrharvey. The gauges icon can’t be selected. May have to take the truck back in and let them check it out. Thanks!
  12. Jan 28, 2020 at 1:40 PM
    TheBeast The Beach
    they have 2 options usually at stereo shop for the steering wheel controls: either the nicer Maestro with OBD II or just the steering wheel controls with an AXXESS module (the one I have). Maybe you guys got the cheaper version.
  13. Jan 28, 2020 at 1:47 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    If you guys are running Android phones, I did a writeup on using Torque Pro, OBD2 for AA, and an ELM-bluetooth adapter to get gauges in your dash via Android Auto. https://www.tundras.com/threads/torque-pro-on-android-auto.56661/
    I was going to bite the bullet and get an iDatalink MRR and rewire everything until I figured this out.
  14. Jan 28, 2020 at 2:38 PM
    Tuham817
    Tuham817 New Member
    2014 SR5 Crewmax
    Yep, that’s what I was told. Wished they had explained this to me earlier before the install was completed.
    I assumed steering wheel controls meant maestro with OBD. Would’ve been nice to have those extra features. Oh well, the kenwood has been awesome. Thanks for the clarification!
    Jrharvey02 likes this.
  15. Jan 28, 2020 at 2:55 PM
    Jrharvey02
    Sunuvabitch, that’s what a “free” install must get you. I’m pretty sure I’ve came across the AXXESS module when running wire behind my dash. To replace with maestro would be a shit ton of work?
  16. Jan 28, 2020 at 2:58 PM
    Jrharvey02
    It would take a whole rewire to get the gauge controls if you’re already wired in with the AXXESS module?
  17. Jan 28, 2020 at 3:09 PM
    TheBeast The Beach
    not necessarily. the Axxess is cheap and requires pressing couple buttons to select HU manufacturer but it's very easy to install. It only controls basic commands for the music. You can always have it removed and install maestro after.
    here is the device on Amazon:
    https://www.amazon.com/Axxess-ASWC-1-Universal-Steering-Interface/dp/B00B4PJC9K/
    Jrharvey02[QUOTED] likes this.
  18. Jan 28, 2020 at 3:18 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Like @TheBeast said, not necessarily. I used the Crux SWC module recommended by Crutchfield for my install, and I'd have to go back and look at the install guide to see if I'd need to rewire anything. I think the more anxiety inducing part of it for me would be sorting out the clusterfuck of wires I zip-tied together when I shoved everything back into the dash.
  19. Jan 28, 2020 at 3:20 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Question for you guys with the Maestro - do you get compass and music info in the dash/heads up screen or is that still blank when you flip to those panels?
  20. Jan 28, 2020 at 3:26 PM
    AZBoatHauler
    So.Arizona
    I can't help you on that. Mine is a 2017 so I have a different screen on the cluster.
  21. Jan 28, 2020 at 3:33 PM
    Cfincke
    San Antonio
    I have the Edge CTS2 unit and it reads 2 trans temps, one of them is the torque converter temp. I like having all the fluid temps displayed, especially when towing.
    AZBoatHauler[OP] likes this.
  22. Jan 28, 2020 at 3:58 PM
    Triton19X2
    Triton19X2 New Member
    2021 Silver 1794 Crewmax 4X4
    Thanks for posting!...So it looks like you need to get the Maestro AND the Maestro - TO2 to get all the gauge features
  23. Jan 28, 2020 at 4:27 PM
    AZBoatHauler
    So.Arizona
    That seems right. Amazon has the Maestro RR for $109 and the TO2 harness for $33. Not sure if those are good prices as James bundled everything with the head unit.
    Also worth mentioning, you can activate the rear camera at anytime by pressing the Cam button on the head unit.
  24. Jan 28, 2020 at 4:29 PM
    Jrharvey02
    Those are good prices, I just called car toys about swapping out and they quoted me $150 for Maestro Install, $169 for the maestro, $30 for something else. $350ish, ugh.
  25. Jan 28, 2020 at 4:33 PM
    AZBoatHauler
    So.Arizona
    If they didn’t chop up your stock harness it wouldn’t be difficult to install yourself. Took me about an hour after reading the instructions several times and going slow.
  26. Aug 25, 2021 at 2:48 PM
    avssuc
    avssuc Efilnikufesin
    Gulf Coast
    2021 Tundra TRD Pro LR
    This is to you and the others with knowledge of Kenwood HU's...
    This is what I see when my Scangauge is hooked up to the OBD2 port:
    When I unplug the Scangauge, it reads OBD:
    But I can't select the transmission temperature gauge:
    Could it be they (the shop I had install it today) didn't download the firmware update? Is there such a thing for the Maestro?
  27. Aug 25, 2021 at 2:58 PM
    AZBoatHauler
    So.Arizona
    Try this-
    Go to the settings menu on your HU and select AV then OEM/Maestro Settings then Maestro Settings then Validate PIDs.
    Give it a minute then see if you can add the ATF temp to your gauges page.
  28. Aug 25, 2021 at 3:19 PM
    stlfan
    stlfan New Member
    DFW
    2017 Tundra SR5 4x4
    2018 OEM LED HEADLIGHTS, BAJA DESIGN FOGS, PRO GRILL & SURROUND, 3M CRYSTALLINE TINT40%, 8" SS BAM EXHAUST.
    I have a keenwood as well and after validating pids the transmission temp will be selectable around 24hrs later. Weird yes, but it shows up eventually.
  29. Aug 25, 2021 at 3:36 PM
    avssuc
    Gulf Coast
    So this is what I got, no ability to update PID. Does this look right?
  30. Aug 25, 2021 at 3:41 PM
    AZBoatHauler
    So.Arizona
    Is your scangauge plugged in? It looks like it is disabling the HU connection…
    Mine says “Supported PIDs Detected” or something to that effect once you select validate.
