Gas filling problem
Discussion in '2.5 Gen Tundras (2014-2021)' started by KiltedWolf1, Jan 21, 2019.
  1. Dec 18, 2021 at 8:20 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Completely true but the newer 38 gal tanks have had a rash of stuck roll over valves.
    GodlessPro likes this.
  2. Dec 19, 2021 at 7:19 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Interesting
  3. Dec 19, 2021 at 7:32 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Overfilling can cause this too, the charcoal gets wet and needs to dry out before all works as it should again.
    Ask me how I know....
    GODZILLA likes this.
  4. Dec 21, 2021 at 11:11 AM
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    My new to me 2016 w/ 38 gal tank did this upon my first time getting gas. Nozzle kept clicking off immediately. Couldn't get it to fill. I moved the nozzle around to different positions. No dice. Finally I pushed the nozzle into the fill neck as far as it would go and tried again. Bingo. Truck fueled up normally then. Maybe it was just a fluke, but hopefully that continues to work as I have NO warranty.
    TundraTed likes this.
  5. May 24, 2022 at 5:12 AM
    BettyWhite20
    BettyWhite20 New Member
    2020 DC SR5 4X4
    2020 SR5 Double Cab 4x4 with the 38 gallon tank and mine just started having this problem around 24,900 miles. I can't seem to get more than about $1.00 worth in at a time before the nozzle clicks and I have to pull the handle again. This has happened the last 4 - 5 gas stations I've went to. Is there supposed to be a flap in the filler neck? I was starting to wonder if it's broke off and down in the filler neck tube causing the blockage? Going to try to get it to the stealership soon for the 25k service and hope they can figure it out and that it's under warranty.
  6. May 24, 2022 at 5:25 AM
    18" TRD Off Road Wheels
    No flap in the filler neck. As stated previously in the thread, topping off can cause this issue, and the usual culprit is a stuck rollover valve. Some have been able to fix it themselves, and others have had new tanks installed because of it. Either way, once it's fixed, make sure you aren't topping off your tank to reduce the chances of it happening again.
  7. May 24, 2022 at 7:01 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Given the low mileage on your truck I'd guess the roll over valve is stuck. Best to see if the dealer will take care of it under warranty. If not, you can remove the fill tube and poke it open with a long screwdriver, don't even have to drop the tank. It's not easy but it's possible.
  8. May 30, 2022 at 11:25 AM
    Theo143
    Theo143 New Member
    2016 tundra crew cab
    None
    After reading all these threads on filling your tank because it keeps clicking the gas pump … my question is … is it most likely the roll over valve or the charcoal canister and evac valve ? I’m have same issue
    831Tun likes this.
  9. May 30, 2022 at 11:53 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    With the 38 gal. tank it's 99% more likely to be the roll over valve. You'd have to consistently be "topping" off your tank to create an issue with the charcoal cannister. Then too, I've heard of the cannister drying out after having been a problem.
    TTund16 and Theo143[QUOTED] like this.
  10. May 30, 2022 at 1:07 PM
    Theo143
    Theo143 New Member
    None
    Could it be the same prob with the 26 gal tank? Not sure what size tank it is?
    831Tun likes this.
  11. May 30, 2022 at 2:07 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    2016+ has the 38, I'm not sure it's in all trim levels though. Pre 2016, unless retrofitted, is the smaller tank.
    The sticky valve issue, as far as I know and have read, is very uncommon in the smaller tank and I'd be much more suspicious of the e-vap cannister.
  12. May 30, 2022 at 3:17 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    How do you know ????
  13. Jun 8, 2022 at 3:49 PM
    BettyWhite20
    2020 DC SR5 4X4
    I got a text from the Stealership that my truck was ready to pick up and parts were on order. When I stopped by to pick it up and ask what parts they ordered he said they're replacing the tank.
    831Tun likes this.
  14. Jun 8, 2022 at 4:36 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    As they should :thumbsup:
  15. Oct 10, 2022 at 8:09 AM
    Tundra-RAV4Prime
    Tundra-RAV4Prime New Member
    2020 Tundra Limited and 2021 RAV4 Prime SE
    I got a 2020 Toyota Tundra Limited, 38 gallon tank and I just started having this same issue. Dealer says the valve is stuck and requires the complete gas tank to be replaced at a cost of ~$3,000:-(
  16. Oct 10, 2022 at 8:11 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    same issue here. I'll be dropping the tank this week to fix the issue. Unfortunately a new tank doesn't address the problem as it can happen again.
  17. Oct 10, 2022 at 8:29 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    My 2016 came with a 26 gallon tank. I swapped for a 38 and had been reading about the rash of stuck rollover valves, so before installing the 38 gallon tank I removed the flapper so it can't ever happen. I just have to make sure I don't roll the truck!
    clarkritchie and reywcms like this.
  18. Oct 10, 2022 at 8:31 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    How'd you remove it?
  19. Oct 10, 2022 at 8:48 AM
    #49
    Northbound Train
    Glenn
    Western MA
    Before putting the fuel pump in, I reached in the fuel pump opening with my arm and grabbed the flapper and yanked it off. I happen to have kind of long arms and I'm not a body builder so I could get in there and reach it that way. Not everyone may be able to.
  20. Oct 10, 2022 at 8:48 AM
    #50
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Copy that! Appreciate it
  21. Nov 6, 2022 at 6:39 AM
    #51
    BrownTRD
    BrownTRD New Member
    Willie
    2020 Mesquite smoke limited
    2.5 Kings, Camburg Billet UCAs
    Having the same issue on my 2020 limited with 24k miles. First time dealing with the dealership for a service issue. Hoping for a good experience ​
  22. Feb 2, 2023 at 10:43 AM
    #52
    king.cong.1119
    king.cong.1119 New Member
    2020 Tundra with 35229 miles on the clock and this just happened to me today, scheduled into the dealer tomorrow to have them figure out.
    Is this a very common issue?
  23. Feb 2, 2023 at 10:56 AM
    #53
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    yes if you offroad it seems to be common place. The problem is the dealer will just put a new tank in and the issue can occur again. I lowered the rear of the tank and stuck a pry bar/ long screw driver to dislodge the flapper. No issues ever since. But I do need to pay attention when filling the truck as it could spill some fuel if topping off.
  24. Feb 2, 2023 at 11:01 AM
    #54
    king.cong.1119
    It was so strange, I have no idea what would I do differently to prevent that, since I always stop when the fuel pump clicks off. Hopefully the dealer./toyota covers that within warranty.
  25. Feb 2, 2023 at 11:14 AM
    #55
    king.cong.1119
    now that I think of what you concluded, more offroad tundras have this happen to them, do you think when vehicle is on an incline with full tank of gas, the gas would be filled at the rear/lower end of the truck and would trigger the stupid rollover valve then?
  26. Feb 2, 2023 at 11:21 AM
    #56
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    That’s possible or I would also say sloshing around of fuel hitting the valve closed and making it stuck. It happened to me right after hitting a whoop section a few times. But like I said the sloshing of fuel wedging it closed I suspect makes it happen
  27. Feb 2, 2023 at 11:23 AM
    #57
    king.cong.1119
    I would not mind to learn how you dislodge the flapper in detail and which/where is the flapper. If dislodged, is there chance the fuel can be leaked out of the gas tank?
  28. Feb 2, 2023 at 11:59 AM
    #58
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Nope only time it would leak is on fill up as mentioned or a rollover but the cap shouldn't leak I believe. Basically you need to lower the tank enough to undo the filler neck on the tank side and use a mirror to see into the tank and take a pry bar to the flapper valve. Im sure an in-depth write up might exist.
  29. Feb 2, 2023 at 1:11 PM
    #59
    Northbound Train
    Glenn
    Western MA
    Fortunately I read about this problem before replacing the 26 gallon tank with a 38 in mine and I removed the flapper before installing it.
    reywcms likes this.
  30. Feb 2, 2023 at 3:21 PM
    #60
    Ct. Rich
    Ct. Rich New Member
    Maine
    2016 Limited TRD
    Flapper located where this hose enters the tank.
