Fuse
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Hinos, Sep 16, 2019.
  1. Sep 19, 2019 at 5:58 PM
    #61
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
  2. Sep 19, 2019 at 5:59 PM
    #62
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    That will give you an idea how to check a fuse I couldn’t show you on a Tundra cause mine is at home but it’s all the samething that’s a semi truck I’m fixing
    Hinos[OP] likes this.
  3. Sep 19, 2019 at 6:15 PM
    #63
    Hinos
    Hinos [OP] New Member
    Hinos
    Toyota tundra
    V8
    Ok thank u. Jst came frm oreilys auto parts. Bought more testers jst in case.
  4. Sep 19, 2019 at 8:20 PM
    #64
    Twinky
    07 double cab work horse
    Have you checked to make sure your brake lights are coming on when you press the pedal?
    If not, that is the first thing you should check. If your brake lights aren't working your shifter won't unlock.
    Very common issue that you can confirm or rule out very easily. Fuse is located in the interior fuse box.
  5. Sep 19, 2019 at 8:22 PM
    #65
    Hinos
    Hinos
    Toyota tundra
    V8
    Ok I'm dis far..
  6. Sep 19, 2019 at 9:34 PM
    #66
    Hinos
    Hinos
    Toyota tundra
    V8
    Ok I'm here so far.
  7. Sep 19, 2019 at 9:36 PM
    #67
    Hinos
    Hinos
    Toyota tundra
    V8
    All fuse inside under driver's side not giving me power wen I use da 12v. Idk..
    I believe its da alternator fuse bc I look on YouTube & seen some one has da same probs. Almost done breaking dwn da fuse alternator tho..
  8. Sep 20, 2019 at 12:09 PM
    #68
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Your battery is removed, correct? Everything will be at 0V. You need to be doing resistance checks instead (should be 0 ohms on a good fuse).
  9. Sep 20, 2019 at 3:26 PM
    #69
    Hinos
    Hinos
    Toyota tundra
    V8
    Found da solution
    Main power fuse. Alternator fuse 180 amp.
    NewImprovedRon likes this.
  10. Sep 20, 2019 at 4:08 PM
    #70
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    Good job
  11. Sep 20, 2019 at 9:53 PM
    #71
    Hinos
    Hinos
    Toyota tundra
    V8
    Yeah. Bruh. Mahaloz.
    How I was so happy dat i actually found it.
    Called all da auto shops near me bt none have it. Called da dealership dey have it dat was my last stop. Nxt week Tues I should have the part. 50$ estimated for da part. I'm so very relieve @ dis moment.
  12. Sep 20, 2019 at 9:57 PM
    #72
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    That’s awesome man good feeling wen u find the problem I still get the same feeling wen I find the problem too and I been doing it for close to 30 years now and I work on all type of different machines.
    NewImprovedRon and Hinos[OP] like this.
  13. Sep 20, 2019 at 10:32 PM
    #73
    Hinos
    Hinos
    Toyota tundra
    V8
    Thank u again boss.. really appreciated wat uve put aside to help me on dis. This is ma baby.. & I will update u on Tues garanz.
  14. Sep 24, 2019 at 3:38 PM
    #74
    Hinos
    Hinos
    Toyota tundra
    V8
    Ma man... got da truck running..cheeeeeho..
    Send me ur mailing address pls
  15. Sep 24, 2019 at 3:49 PM
    #75
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    Lol that’s awesome no prob
  16. Sep 25, 2019 at 7:28 PM
    #76
    Hinos
    Hinos
    Toyota tundra
    V8
    Pls brother send me ur mailing. u dont no how much dis meant 4me.
