Fumoto Valves
Discussion in '2.5 Gen Tundras (2014-2021)' started by Part_time, Jan 27, 2019.
  1. Feb 24, 2019 at 6:46 AM
    #91
    Part_time
    Part_time [OP] Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Thanks
  2. Feb 24, 2019 at 5:33 PM
    #92
    Part_time
    Oregon
    Ok one last question how many quarts of oil? Going for it tomorrow have not had a day off this year and for the 4 months of last year except for XMAS and new year so I have not looked it up, and don't really feel like it
  3. Feb 24, 2019 at 5:43 PM
    #93
    Part_time
    Oregon
    I could probably look at the cap for the weight, work too much losing my mind
  4. Feb 24, 2019 at 5:46 PM
    #94
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    0W20 (zero dubyu twenty).
    bulldog93 and (deleted member) like this.
  5. Feb 24, 2019 at 6:29 PM
    #95
    Mine always takes 8.5 quart's.
  6. Feb 24, 2019 at 7:38 PM
    #96
    Watt maker likes this.
  7. Feb 24, 2019 at 8:09 PM
    #97
    @ARamirez73 do they sell them at your second job?
  8. Feb 25, 2019 at 3:43 PM
    #98
    Part_time
    Oregon
    Ok did the install today. Just a little back ground used to do all my maintenance on my own until I moved to Oregon and moved out to the sticks hard a gravel driveway which made getting under vehicles a real pain. Now I live back in town with cement drive way, so back at it and my warranty is up. So Fumoto valve, I would say worth it especially if you have something like the RCI Skid plate. When you drain the oil pan with a skid like that towards the end the oil will go on top of the plate plus just letting drain down in tub is a mess also. Also changed out the plastic oil filter cap and went with the aluminum from Amazon. 20190225_143322.jpg 20190225_143231.jpgThe set up money was not super expensive but I bought 4 ton jack a set of jack stands the valves oil filter cap, the wrench that's needed for taking it off and rags. The only down side is that I thought that I would save more money, still the satisfaction of doing it yourself is worth the price. Also reset my maintenance miles on the dash. Also replaced my air filter inside the cab it was really dirty had leaves and all kinds of crap in there miles 29944 any that is my initial impression. Will repost at 40,000.
  9. Feb 25, 2019 at 3:48 PM
    #99
    Part_time
    Oregon
    Also bought the nipple and lock for the valve.
  10. Feb 25, 2019 at 4:10 PM
    #100
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    You can also get the Rhino brand plastic-injected-molded ramps. 40 bucks at Wally World for a set of two ramps. Good for 12,000 pounds and stupid easy. I then put jack stands under the frame for safety. And the ramps on just the front angle the oil pan to the back right-to-the-drain-plug!!!
    Pudge likes this.
  11. Feb 26, 2019 at 7:04 AM
    #101
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
  12. Feb 26, 2019 at 7:07 AM
    #102
    Trooper2
    JR
    Houston, TX (Suburban South)
    We only sell Wiper Blades :(
    @ARamirez73
    Prostar 190 likes this.
  13. Feb 26, 2019 at 10:31 AM
    #103
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
  14. Feb 26, 2019 at 10:37 AM
    #104
    Trooper2
    JR
    I guess $10 isn't too much for a funnel.
    I saw this hack a while back on here somewhere. Washer Fluid bottle hack, screws right in. Worked great and practically free!
  15. Feb 26, 2019 at 11:18 AM
    #105
    15whtrd
    15whtrd Mr. Blonde
    I’ve been using an old Prestone radiator funnel for years. It works pretty good because it has a wide mouth. But I think I like this better!
    Prostar 190 and Trooper2[QUOTED] like this.
  16. Feb 26, 2019 at 11:19 AM
    #106
    Part_time
    Oregon
  17. Feb 26, 2019 at 11:24 AM
    #107
    Trooper2
    JR
    My plug from plastic housing transrerred right over, no issues.
    bulldog93 and 15whtrd like this.
  18. Feb 26, 2019 at 1:20 PM
    #108
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    I ended up canceling my order and ordered the one with the plug.
  19. Feb 26, 2019 at 1:40 PM
    #109
    They have Adam's @ARamirez73 in stock....
  20. Feb 26, 2019 at 1:43 PM
    #110
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Same here put it on because of RCI Skids. works ok so far. No leaks, drips...etc.
    Part_time[OP] likes this.
  21. Feb 26, 2019 at 1:59 PM
    #111
    Part_time
    Oregon
    Smart man I work at a ship yard one thing I have learned is make sure you have every thing you need before you tear it up
    VTYOTA[QUOTED] likes this.
  22. Feb 26, 2019 at 2:19 PM
    #112
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    Yes sir! Thanks for starting this thread. I didn’t even realize Fumotos existed. All these years of changing oil the messy way...
    Also, who is @ARamirez73 ? Should I know who @ARamirez73 is? @ARamirez73
  23. Feb 26, 2019 at 2:22 PM
    #113
    I uz
    I use the same one.
    15whtrd[QUOTED] and Trooper2 like this.
  24. Feb 26, 2019 at 2:23 PM
    #114
    Trooper2 and 15whtrd like this.
  25. Feb 27, 2019 at 7:32 PM
    #115
    Tundra_Dawg
    Tundra_Dawg Boss Moss
    Arizona
    2017 MGM Platinum
    PPE headers, TRD exhaust, ICON 3" lift, Raceline wheels, Powertrax Tonneau cover; 2019 TRD Pro headlights and fogs; TRD pro grille; Victory 4x4 sliders.
    I think he used to play 3rd base for the Cubs.
  26. Feb 28, 2019 at 7:37 PM
    #116
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    I know its just a filter wrench, but this tool just exudes quality. Forged perfectly and has a great weight to it. Feels like it should last a lifetime, but only time will tell.
  27. Mar 15, 2019 at 2:06 PM
    #117
    Tundra_Dawg
    Arizona
    2017 MGM Platinum
    The Jowett works beautifully with the RCI skid plate. Plenty of room!
    bulldog93 likes this.
  28. Mar 15, 2019 at 2:19 PM
    #118
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Wish I didn't wait on that Jowett filter cap. They're out & seems he's not doing any more. I emailed Brian last month and haven't heard back. Anyone know what the deal is - if he's going to have them again?
  29. Mar 15, 2019 at 3:37 PM
    #119
    Tundra_Dawg
    Arizona
    2017 MGM Platinum
  30. Mar 15, 2019 at 3:59 PM
    #120
    Uhhhh....
    Dave
    7” BDS, 37s
    Yeah I have one of those - works great! Jowett would’ve been cool, but don’t need it.
