Fumoto Valve Installation
Discussion in '1st Gen Tundras (2000-2006)' started by carpenter356, Dec 9, 2020.
  1. Dec 11, 2020 at 9:19 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Can one be fitted the the trans pan? With my job switch, I lost my shop access so I’m back to doing oil changes on the street. If I could do it without making a mess, that would be ideal.
  2. Dec 12, 2020 at 4:03 AM
    Zero One Actual
    Whoa whoah whoa. Public forum bro!
  3. Dec 12, 2020 at 8:00 AM
    Garand
    Garand New Member
    2024 TRD OR Limited DC
    285/65R20
    Yeah, I have a 2015
  4. Dec 12, 2020 at 9:17 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    No. I've even emailed fumoto, they said they don't keep trans specs, their smallest is 12mm, my trans is 10, uggh.
  5. Dec 12, 2020 at 10:13 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    This might be a better option for the transmission since they're a little lower profile.
    http://www.stahlbus.com/products/en/oil-drain-valve/index.php
  6. Dec 12, 2020 at 11:14 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    I don't mind crawling under the truck, pulling the engine shield thingie off and turning the drain bolt. It gives me a chance to inspect the underside components for damage or wear that might go unnoticed otherwise.
    tvpierce, tunyota, deptrai and 3 others like this.
  7. Dec 15, 2020 at 7:06 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    I just ordered one for the first oil change on my 2020 which I will do may self. No thanks 2 free Toyota services I want all the fasteners to be put back for the skid plate and the drain plug not put on with an impact.
    I've have one my my Honda Fit for years and love how easy and mess free it is to change the oil. It does take a little longer but then you don't have to collect the wench, rags, cardboard, etc. Any 3/8 hose will work for a directed flow and you can change the oil as hot as you want.
    YardBird, Pucks18 and Glock 40 like this.
  8. Dec 15, 2020 at 7:25 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Dude, must be an amazing feeling having a brand new truck, with brand new shiny bolts! Keep her good n clean so 20 years from now on this forum the next owner is like "damn this guy took care of this thing!"
    Tundra2 and YardBird like this.
  9. Dec 15, 2020 at 7:34 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    That's how I felt about my Shiny new 2017 Subaru Forester, ordered special from Japan so I could get the premium (sunroof, power seats, etc) with a 6 speed manual. When the "free" services were done I ordered a fumoto valve and discovered that the little access panel (built into the skid plate) for the drain plug was only held on with one screw and I had to use a 2ft breaker and impact socket to get the drain bolt off. No more dealer oil changes for me. Then Atlanta traffic totaled it, now I have the Tundra and love it however I do miss having a manual.
  10. Dec 15, 2020 at 8:01 AM
    Pucks18
    Yea that sounds like a great car. By no means am I a highly knowledgeable car/mechanics guy, but I am just not a fan of those boxer engines at all
  11. Dec 15, 2020 at 8:09 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I had an old 2004-ish Subaru forester with the 5 speed manual and that car was an absolute blast to drive.
    Pucks18[QUOTED] and Drainbung like this.
  12. Dec 15, 2020 at 9:00 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    Just to clarify, for my tundra I ordered the Fumoto f103sx which is the low profile side discharge. Not because the tundra needs the clearance just because it was the one that would get to me before the start of my Christmas break.
    I like the idea of the check ball type drains (stahlbus and others) because there is a screw on cover but I just don't want to have to keep track of the drain adapter to change the oil.
    The sx type fumoto might work as a transmission drain if you new what size the plug was, I think the plug part number is 9034110021 but I didn't find a thread size anywhere.
  13. Dec 15, 2020 at 9:07 AM
    TXTundra2722
    2015 Black Tundra
    Thanks for posting this. I'm a veteran and I've been trying to support veteran owned companies... especially during most recent times when everything has turned super political! Yes, you will pay a little more for things made in the U.S., versus anywhere else (china), but I think the money should be in our hands anyways..... not theirs. I digress before I really turn this political and get put in time out. Last thing and then I'll shut up, I remind my kids daily that it's OK to love your country.... the schools and news like to say otherwise.
    :oldglory:
    Drainbung likes this.
  14. Dec 15, 2020 at 10:34 AM
    Johnsonman
    Austin
    Sequoia
    The Only thing I wonder about is, does it matter we're removing the magnetic plug that catches tiny pieces of metal?
    Once these are in, no more strong magnet, hmmm.....Thoughts?
  15. Dec 15, 2020 at 11:01 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    The oil filter should take care of any particles metal or otherwise. If you still want a magnet, put an appropriately sized strong magnet through the drain hole and into the pan before installing the valve. Sitting inside the pan and not being removed will be fine.
  16. Dec 15, 2020 at 3:32 PM
    Johnsonman
    Austin
    Sequoia
    Agreed Trogdog, the high quality filters we use should trap that. I like the idea of slipping in a magnet, best of both worlds. Thanks.
    Tundra2 likes this.
  17. Dec 15, 2020 at 6:59 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    https://youtu.be/Q65KZIqay4E
  18. Dec 15, 2020 at 7:02 PM
    glowblue
    VA
    Almost forgot - thanks for serving. Some of my very best employees are veterans. Hard workers, smart, and great team players.
  19. Dec 16, 2020 at 9:50 PM
    #49
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    Thanks for sharing @carpenter356.
    My wife and I have installed Fumoto valves on all (3) of our vehicles. I personally prefer the ones without the extended nipples as I feel they can more easily make contact with debris and get caught up on something resulting in a failure causing the engine to potentially run dry if not paying attention to the pressure gauge etc. Granted it is approximately one additional inch or less depending on the version but the thought already of having something larger than the factory drain plug protruding from the oil panel ever so slightly concerns me. However, in our case, the risk is seemingly worth the reward. It is never much trouble to remove the drain plug but now this saves us from needing to regularly replace the washers which I am a fan. I should mention I am currently not running the engine under cover assembly as I still need to modify it by cutting approximately 1'' off the front corners to fit in between the 2-Inch Front Receiver Hitch we installed.
    https://www.amazon.com/gp/product/B00076RLG8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1.
    I was thinking with these Fumoto valves installed there may be the chance of a couple of millimeters of residual oil remaining in the bottom of the pan due to the design but with the front of the vehicle raised it should be negligible if any. I wonder if anyone removed one later after installing and noticed how much residual oil there may be...
  20. Dec 17, 2020 at 6:14 AM
    #50
    tvpierce
    tvpierce Formerly New Member
    Maine
    How would you clean it?
  21. Dec 17, 2020 at 6:22 AM
    #51
    tvpierce
    Maine
  22. Dec 17, 2020 at 6:45 AM
    #52
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    You wouldn't, just leave it. Los of transmission pans have a magnet inside that you can't clean without dropping the pan.
    I don't bother with a magnet in engines that have a real oil filer. Magnets are much more useful in engines that don't have filters, small lawn movers, generators, etc. and other oil bath devices that don't have filters, transmissions (it's a screen not a filter), transfer case, etc.
  23. Apr 9, 2021 at 7:20 AM
    #53
    pm07
    pm07 New Member
    Shane
    2006 Black Tundra
  24. Apr 9, 2021 at 7:24 AM
    #54
    Festerw
    Festerw New Member
    04 Tundra DC
  25. Apr 9, 2021 at 7:25 AM
    #55
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    No. Don't try to force it or you'll ruin the threads on your oil pan which would greatly suck. The one that I purchased back in 2019 is the F103N. Check to make sure that works on your 06.
    pm07[QUOTED] likes this.
  26. Apr 9, 2021 at 7:43 AM
    #56
    Professional Hand Model
    Hand Protectors
    I’m feeling a slippery slope coming up.
    pm07 likes this.
  27. Apr 9, 2021 at 7:48 AM
    #57
    pm07
    pm07 New Member
    Shane
    2006 Black Tundra
  28. Apr 9, 2021 at 7:52 AM
    #58
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
  29. Apr 9, 2021 at 8:12 AM
    #59
    pm07
    pm07 New Member
    Shane
    2006 Black Tundra
  30. Apr 9, 2021 at 8:35 AM
    #60
    Drainbung
    Bob
    Oasis of NV
    TRD Fleshlight
