FS: 3 switch panel insert plate
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by CorpsTundra, Aug 24, 2021.
Thread Status:
Not open for further replies.
  1. Jul 27, 2023 at 6:57 PM
    #541
    brigand80
    brigand80 New Member
    Roman
    2017 Limited CM MGM 2WD
    Its Always A Work In Progress...Because Its A Labor of Love!! - aFe Pro Dry Filter + TRD Intake Flow Accelerator + Carbon Filter Delete - nFab Podium Steps - TRD Rear Sway Bar - TRD Pro Grill - Color Matched Hood Bulge, Front Bumper End Caps, Mirror Caps, Door Handles - Nightshade "Limited' Badges & Others De-badged - NSV LED Lightbar - Desert Eagle Offroad Catalytic Skid Plate - Craven Speed Untenna - Diaz Fabrication TEQ Trailer Hitch Cover - Klearz 3rd Brake Light Smoked Lens - Winjet Renegades Smoked Tail Lights - Headlight Revolution GTR Lighting LED Bulbs - Morimoto 4 Banger HXB LED Fog Lights (White) - XD 847 Outbreak 18x9 +12 5x150 - Gorilla Black Spline ET Lugs - AJT TRD Key Fob + Interior Chrome Delete Kit - TRD Shift Knob (Black) - JimmyRigged ToYoda Steering Wheel Emblem Overlay - JRT Tech 12 Front Dash JL Audio Speakers - K&N Cabin Filter - Chalk Bag Mod - Weather Tech Mats - Ceramic Window Tint
    UCF, Go Knights!
  2. Jul 31, 2023 at 4:29 PM
    #542
    Devdog86
    Devdog86 New Member
    Brad
    Pennsylvania
    2021 Lunar Rock Trd Pro CM
    Has anyone used this harness on a 20 or 21.
    I reached out to 12Volt and they stated that it wouldn’t, I guess I answered my own question but I’m just curious if anyone has used it since it’s 57” vs 44” for the Accessorides version that cuts it very close.
  3. Aug 2, 2023 at 12:17 PM
    #543
    Taco-Spike
    Two Trucks
    First page says it works up to 21
    Devdog86[QUOTED] likes this.
  4. Nov 11, 2023 at 11:32 PM
    #544
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    I’ve acquire all the parts I need to effect a 1st rate job installing the FARC, wiring, and camera, but still need the switch plate from @abomb60. It seems he’s been off-site for a while. I’ve tried to PM him, but no luck. Does anyone have an idea how to get on the list to source this awesome product? I’d really prefer to have the finished job look like a factory installation. Many thanks.
  5. Nov 12, 2023 at 1:28 AM
    #545
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    He had 2 different styles, which one are you trying to source???
    One had exposed screw holes such as this...
    The other style had hidden screws (attached from underneath) like this one...
  6. Nov 12, 2023 at 7:01 AM
    #546
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    Thanks for the reply Tripleconpana. If both are available, I have a preference for the clean look, w/ no visible screws. Thanks again.
    Tripleconpanna likes this.
  7. Nov 12, 2023 at 7:11 AM
    #547
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I might have an extra one if you don’t hear back from @abomb60. I’ll check my stash.
    Tripleconpanna and RainMan_PNW like this.
  8. Nov 12, 2023 at 7:20 AM
    #548
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    When I get back from this work trip, I’ve been meaning to fire up my printer and run one on the textured bed (face down). If it comes out how I want it to, I might run a few extras.
    DoublePro and TRDFerguson like this.
  9. Nov 12, 2023 at 7:30 AM
    #549
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  10. Nov 12, 2023 at 7:53 AM
    #550
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    TRDFerguson, that looks great.
    Please take my money!
    PM inbound.
  11. Nov 12, 2023 at 11:57 AM
    #551
    Tripleconpanna
    I have an extra one w/screw holes visible, but it sounds like someone may have a concealed one for you (or be able to print one)...
    I agree w/you though the concealed look is much cleaner, so if we can round one of those up for you I think you'd be happier!!!!
    edit: :facepalm: this is what I get for not scrolling down further, before I post....
    so, disregard the above, looks like you're taken care of :thumbsup:
    bulldog93 likes this.
  12. Nov 12, 2023 at 9:25 PM
    #552
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    Yes, already secured a plate from TRDFerguson.
    Thanks just the same.
  13. Nov 13, 2023 at 8:27 AM
    #553
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    The textured bed matches the interior quite well. Helps hide the layer lines as well. I don't think any post print work is required when using the textured bed.
  14. Nov 16, 2023 at 9:23 AM
    #554
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    This switch is for the seat heater control/modulation….correct? Has anyone installed this switch in the switchplate? I’m really liking the simplification of switch positioning of the idea, but would like to hear from someone who has actually done the installation.
  15. Nov 16, 2023 at 11:49 AM
    #555
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I have! I just used a file and made the opening larger to accommodate. I then did some gloss black Rustoleum coats on it, and it looks nice.
    It really does work excellently for the heated seats arrangement. The only catch is this: The switch itself is pretty long, and because of where things sit underneath the switch panel, you need to trim away some hidden plastic that sits unseen around the shifter column. It wasn't difficult to do, I just grabbed some pliers and pulled the plastic away and used tin snips to remove it; easy, but you do have to do it, or the switch won't slide down all the way.
  16. Nov 16, 2023 at 12:45 PM
    #556
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    When you get a minute, can you post a photo of what the finished product looks like? Installed in here truck? Much appreciated.
  17. Nov 16, 2023 at 12:46 PM
    #557
    MedCityMoto
    Certainly can, will do later this evening
  18. Nov 16, 2023 at 3:25 PM
    #558
    MedCityMoto
    Terrible photo attached! Gets dark too early and flash doesn't help much. Pardon the dirty truck.
    RainMan_PNW and TRDFerguson like this.
  19. Nov 16, 2023 at 9:19 PM
    #559
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    Congrats.
    Very well thought out switch positioning.
    Thanks for the pic.
  20. Nov 16, 2023 at 10:08 PM
    #560
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    From whence may I procure this majic switch?
  21. Nov 17, 2023 at 5:46 AM
    #561
    MedCityMoto
    It's part of the kit from Metra I picked up from Metra over a year ago, let me see if I can dig up a link for you. It was $80 for everything not including the fuse tap I already had on hand, and took me a Saturday to remove the two front seats one at a time, remove the seat covers, snip off the hog rings, stick on the heating pads, reinstall the upholstery covers, run the wiring around center console, and bolt the seats back in. I didn't bother with new hog rings, no different can be felt in the seat anyway. But I have cloth - leather might be different and may need them. I've heard zipties can be used if you don't feel like buying hog ring pliers for one job, I didn't!
    Metra InstallBay IBHS3 was the model - I see them on Ebay here for around $80 right now, or you can throw extra money at CarID here but honestly I wouldn't because CarID's no better than your average Ebay store.
  22. Nov 17, 2023 at 1:30 PM
    #562
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    I may have missed it if anyone has already asked this, but do the Katzkin seat heater switches fit in this?
  23. Nov 17, 2023 at 1:43 PM
    #563
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
    Yes they do. I Had two blanks in mine and that’s what they installed in.
    nhw544[QUOTED] likes this.
  24. Nov 17, 2023 at 2:06 PM
    #564
    nhw544
    nhw544 Food fight!
    RVA
    Perfect, thanks!
  25. Nov 27, 2023 at 12:00 PM
    #565
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    I went to the eBay link you enclosed. They also sell the switch only with wire harness for $25. I ordered the switch, and it should be here in a couple weeks. Thanks for the link!
  26. Nov 28, 2023 at 4:57 AM
    #566
    DirtyMike5
    DirtyMike5 New Member
    Baton Rouge
    Hi, do you have any more available? I'd like to buy one.
  27. Nov 28, 2023 at 5:31 AM
    #567
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    This is really clean! I need one like this!
  28. Nov 28, 2023 at 7:42 AM
    #568
    Tripleconpanna
    I don't think he's been on here for a while.
    If you have a 3D printer or know someone that has access to one (personal or commercial) here is RainManPNW's print file to do one yourself that he shared on his build thread...
    STL file here
  29. Nov 28, 2023 at 4:51 PM
    #569
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    Try this guy. I messaged him yesterday, and he may (emphasis MAY) have one or two left. He is a little slow to respond, as (like most of us) he has a busy life. https://www.tundras.com/members/27904/
    FISHN43[QUOTED] likes this.
  30. Nov 28, 2023 at 5:31 PM
    #570
    FISHN43
    FISHN43 New Member
    Ohio
    I’ll try him. Thanks!
Thread Status:
