FS: 3 switch panel insert plate
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by CorpsTundra, Aug 24, 2021.
Thread Status:
Not open for further replies.
  1. Sep 5, 2022 at 8:20 AM
    #481
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    Has anyone moved their tow/haul button to this switch panel? I’ve looked and didn’t see a plug and play extension harness for it. Didn’t know if it was possible or not.
    MedCityMoto and biebs96 like this.
  2. Sep 5, 2022 at 9:04 AM
    #482
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Getting ready to do this soon - making my own harness
  3. Sep 5, 2022 at 9:19 AM
    #483
    Nice. I'm getting Vled bulbs ordered to do the 3rd brake light conversion.
  4. Sep 5, 2022 at 11:18 AM
    #484
    biebs96
    PA
    Yes, make your own harness. It is easy. I used some old Ethernet cable.
    Similar gauge, already in a housing and plenty of color paired wires.
  5. Sep 5, 2022 at 12:38 PM
    #485
    nhw544
    nhw544 Food fight!
    RVA
    Wiring isn’t my thing, so if either of you could share how you did it, it would be greatly appreciated!
  6. Sep 5, 2022 at 8:37 PM
    #486
    RainMan_PNW
    Casey
    Clark County, WA
  7. Sep 6, 2022 at 1:11 PM
    #487
    nhw544
    nhw544 Food fight!
    RVA
  8. Sep 7, 2022 at 7:37 PM
    #488
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Hey man, sorry I missed this. Parking sensor is basically the exact same as rear window. To do parking sensor you will need a second rear window harness and a sharp knife/utility blade. What you will do is trim the “ears” (the little strip of plastic that sticks out on either side of the connector) off the male connectors (both the male connector on the truck and on the harness). The male connectors should fit now into the female connectors. Voila.. no more annoying beeping going through drive thru’s or whenever else they come on unwontedly.
    bulldog93 and TRDFerguson like this.
  9. Sep 22, 2022 at 8:15 AM
    #489
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Finally done after multiple coats and recoats I finally settled with the finish for what it is. Other than the epoxy filled screw holes slightly visible it came out okay.
  10. Sep 30, 2022 at 8:49 AM
    #490
    Predator Tundra
    Predator Tundra New Member
    Fallon, NV
    2020 Platinum
    did you cut the leather yourself or order the SDHQ one? if you cut it, any tips?
    Pillslinger likes this.
  11. Oct 14, 2022 at 8:29 AM
    #491
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    One console insert left. As of now there will be no more due to time constraints, other projects and a dead 3d printer. Post here if you want it and PM me.
  12. Oct 14, 2022 at 11:49 AM
    #492
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    PM incoming.
  13. Oct 14, 2022 at 3:45 PM
    #493
    abomb60
    Massachusetts
    Replied back to you.
  14. Oct 17, 2022 at 10:51 AM
    #494
    abomb60
    Massachusetts
    All gone!
    Edit: New printer showed up today so will do some testing this week and maybe offer these again depending on interest.
    RainMan_PNW and TRDFerguson like this.
  15. Nov 14, 2022 at 7:22 PM
    #495
    jchice2
    jchice2 New Member
    Jammie
    South Jersey
    2020 Toyota Tundra TRD Off Road
    4" Rough Country Lift / Fuel Rims / 33" Tires
    @abomb60 If you are still printing these, I would like to buy one
  16. Nov 15, 2022 at 6:55 AM
    #496
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
    @abomb60 id be in for 1 also, or who ever else is making these
  17. Nov 18, 2022 at 2:50 PM
    #497
    713Tundra
    HTX
  18. Dec 1, 2022 at 9:02 AM
    #498
    abomb60
    Massachusetts
    Working on a test batch today so there will hopefully be some available soon. Getting the new printer dialed in has been a bit of a challenge.
  19. Dec 2, 2022 at 9:55 AM
    #499
    abomb60
    Massachusetts
    Still tweaking and tuning but looks like I'm just about there after printing almost a dozen of these and tweaking as I go. Still have a few issues to iron out as I'm not 100% happy yet with how these are coming out but that's just me being picky as none of the issues I'm having would affect this part or it's use. Hopefully will have this ironed out today or this weekend. Thanks all for the support and I'll update you again soon.
    Pillslinger and RainMan_PNW like this.
  20. Dec 5, 2022 at 1:25 PM
    #500
    abomb60
    Massachusetts
    Testing continues ... still a few cosmetic issues with the prints but I think it may be filament related. New filament will be here tomorrow so more to come!
    Pillslinger and MedCityMoto like this.
  21. Dec 5, 2022 at 2:07 PM
    #501
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I'm interested, but currently I have my aftermarket (and way better than OEM) heated seats switch installed in that spot. It's the taller variation of dash switches and I believe longer than the OEM window up-down switch. How hard would it be to make that middle switch spot a touch taller, add a few mm top and bottom?
  22. Dec 5, 2022 at 2:22 PM
    #502
    abomb60
    Massachusetts
    Can you PM me a picture? There is plenty of room for a longer switch but is there a gap where it sits on the top?
  23. Dec 6, 2022 at 11:24 AM
    #503
    MedCityMoto
    Here's some pictures of the switch itself, if that helps!
    bulldog93 likes this.
  24. Dec 8, 2022 at 4:34 PM
    #504
    abomb60
    Massachusetts
    Ok these are now available again for ordering. Currently just the version with the 4 open screw holes at the top (I will make the version with no top holes available after testing if people would like those as well).
    Details:
    - Black PETG filament same as before so these won't melt or warp in the summer (PLA would warp and deform in the heat of a hot truck)
    - If you want more than one for some reason (shipped together) contact me first before sending payment so you don't pay extra shipping.
    - Mounting hardware is NOT included.
    - These are raw 3d printed parts. They are pretty darn good and I clean them up a bit but they will require some finishing/painting. You will see layer lines and this is completely normal for FDM printed parts. I do check these for any obvious defects, but if you find something let me know so I can have a chance to correct.
    - If you expect these to be a 100% perfect surface as delivered and require zero effort on your part then DO NOT ORDER (sorry been burned by this before but not on this forum).
    - For painting I recommend hand sanding then spraying with a filler primer before painting to smooth the surface (not normal primer ... filler primer). Make sure the primer says it will stick to PETG plastic! When you are sanding don't go nuts with a belt sander. The top layers are ~1.5mm thick so you should have plenty of material to make it smooth with normal sandpaper by hand with minimal effort.
    - If you have questions about finishing or anything else ask here. From my records, there are 99 people that can assist you with your questions.
    US Ordering:
    - $35USD each including shipping the the US via USPS with tracking (inflation, materials are a bit more and USPS shipping is higher now).
    - Payment via PayPal only. DO NOT USE PAYPAL FRIENDS AND FAMILY. I appreciate you trying to keep my PayPal fees down but if I get hit by a bus before I ship this out you at least get your $35 back
    - PM me here to order ... I need the following info: #1. Your USPS shipping address with full name, #2. Your screenname here but I will get that automatically from the PM (so I can figure out the email from PayPal to a screenname here), #3. Your email address that you will use with PayPal ... see #2 for why and #4. Payment ... see below.
    Canada Ordering:
    - I WILL SHIP to Canada. You guys are great so not going to leave you hanging.
    - PM me before sending any money as I will get your shipping info and figure out how much shipping will be to your province.
    - I use stamps.com to ship and for an additional fee they will pay any import taxes for you so that's an option if you want.
    - I will need the same info as for US ordering via PM but I will also need your phone number. Canada requires this for imports from the US for some reason. I won't call or text you weird meme's at 3am but if you really don't want to give it to me just give me the phone number of your nearest Tim Hortons or government run weed dispensary. I just need it to fill out the form and print the shipping label without getting yelled at by USPS.
    - Yes USPS knows that +1 555-555-5555 is not valid. Been there and not doing it again!
    Payment:
    - As said up above the total for the US is $35 each via PayPal (again NOT FRIENDS AND FAMILY).
    - All orders to Canada contact me first via PM here. Do not proceed to the next bullet in this list until you hear back from me.
    - PayPal address is adam.carpenter@gmail.com
    - If for some reason you need me to send you a PayPal invoice let me know via PM when you give me all the other needed info.
    - Did I mention NOT TO USE PAYPAL FRIENDS AND FAMILY yet?
    Any other questions, comments or concerns please let me know here in this post or via PM/email. Also I still have patches left and one will be included with each order until I run out for those of you that are wondering :)
    Thanks! - Adam
  25. Dec 8, 2022 at 5:07 PM
    #505
    abomb60
    Massachusetts
    Also I will be away the week after next and won't be home until the middle of the first week of January so no orders will be shipped after next weekend (December 17th). If you want/need one before Christmas get your order in soon.
  26. Dec 9, 2022 at 9:21 AM
    #506
    RainMan_PNW
    Casey
    Clark County, WA
    I had to like this, then click it off to like it again. Love the details for canadians. :rofl:
  27. Dec 9, 2022 at 9:42 AM
    #507
    abomb60
    Massachusetts
    Haha thanks ... I may have been enjoying a beer while writing that part :)
    RainMan_PNW[QUOTED] likes this.
  28. Apr 2, 2023 at 5:14 AM
    #508
    prozac
    prozac New Member
    Zach
    Southern California
    2015 Inferno Orange Tundra TRD Pro
    see my build thread - https://www.tundras.com/threads/prozacs-2015-inferno-orange-trd-pro-build.122370/
    @abomb60 still selling these? I actually have a 3D printer at home but I don’t think I have the right filament and it gets so little use it would probably take forever to dial it for this piece
    I’m planning on putting heated seat potentiometer switches on the outside and relocating the read window button in the middle, this looks like the perfect plate for that?
  29. Apr 2, 2023 at 5:21 AM
    #509
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
    It sure is. I did the same thing:1D575AD8-D835-4BC3-8CC9-38B2A80BCF6F.jpg
    Taco-Spike likes this.
  30. Apr 2, 2023 at 5:41 AM
    #510
    Taco-Spike
    Two Trucks
    Same
Thread Status:
