FS: 3 switch panel insert plate
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by CorpsTundra, Aug 24, 2021.
Thread Status:
Not open for further replies.
  1. Mar 27, 2022 at 12:32 PM
    #451
    InfernoBoyz
    InfernoBoyz YoutubeTech
    Reno, NV
    2016 Inferno Tundra Double Cab OR
    where did you find the lower led bar switch? I’ve been looking for one
  2. Mar 27, 2022 at 4:51 PM
    #452
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  3. Mar 27, 2022 at 9:53 PM
    #453
    WillTunBlack20
    WillTunBlack20 New Member
    William
    Houston, Tx.
    2020 Tundra TRD PRO Midnight Black
    Grille Lights, Bumper Lights, Front Facing Camera, Interior Upgrade, Leer Topper
    Yes sir, accordion boot, X-Wide, it’s wide enough, but you have to manipulate it, to follow the curves of the TRD PRO, rear window.
    bulldog93, jhardy1979 and abomb60 like this.
  4. Apr 16, 2022 at 5:56 PM
    #454
    Unstable_Trip
    Unstable_Trip New Member
    Tom
    North MS
    '14 Blue Ribbon SR5 DC 4x4
    Got tired of looking at my panel sitting on my work bench so decided to install. Still trying to decide what switches I need for what, so this is how it'll sit for the time being. I messed it up a bit doing some work on it, but I only notice it if I stare at it too hard. Awesome product @abomb60
  5. Apr 24, 2022 at 11:52 AM
    #455
    Bradyboyy88
    Bradyboyy88 New Member
    Shaun
    hey so how did you manage to get a switch plate without the bolts in the four corners?
  6. Apr 24, 2022 at 3:34 PM
    #456
    Unstable_Trip
    Tom
    North MS
    It was a bondo experiment for me. I was wondering if I could do it, so I tried it. Honestly took me 3 tries to get it to a "that'll work" spot. It's far from perfect, you can see the imperfections. The bolts are in there, just under a nice layer of Bondo :rofl:
    RainMan_PNW likes this.
  7. Apr 26, 2022 at 6:13 PM
    #457
    Bradyboyy88
    Shaun
    Will the switches just click in front the top since you can’t take the plate off.
  8. Apr 26, 2022 at 6:48 PM
    #458
    Unstable_Trip
    Tom
    North MS
    I can remove the plate. It's still attached using the nut and bolt technique. I used extra strength super glue on the head of the bolts and tightened them down with the nuts to try to get it to stay. Then I just layered it with Bondo. Let it set, then sanded, and painted. Still not perfect. The first attempt, I didn't secure the bolts, so when I tightened it down on the console piece the bolts pulled down a bit and you could see circle indentions on the corners.
  9. Apr 26, 2022 at 8:19 PM
    #459
    Looks good to me. I have Bunny Burner, Raptor lights, and an Air horn switches in mine. Now if someone would design a setup for the lower part of the console area just below the USB area on the 2020. I need a couple more switch spots. :D
    Unstable_Trip[QUOTED] likes this.
  10. Apr 27, 2022 at 3:56 AM
    #460
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I was actually thinking the same thing not that long ago, I don't use that area for anything anyways. I might start working on a design for that area when I get a chance.
  11. May 3, 2022 at 4:07 PM
    #461
    odin1701
    odin1701 New Member
    2021 Tundra LTD TRD OR MGM
    So I just got mine installed. There's some cutting you have to do under the panel that comes out to get switches to fit.
    For those installing CH4X4 double switches, just know that they have a slightly different latching piece and it doesn't take much for them to come out. I don't know why they changed that from the normal ones.
  12. May 3, 2022 at 6:41 PM
    #462
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    I still need to get one of these for my truck
  13. Aug 10, 2022 at 10:07 AM
    #463
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
    Does anyone know if @abomb60 is still printing those 3-switch panel inserts?
    I haven’t been able to get in contact with him.
  14. Aug 10, 2022 at 10:18 AM
    #464
    He hasn't been on since mid July. Send him a PM?
  15. Aug 10, 2022 at 10:23 AM
    #465
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Sorry been away for a bit and just getting back. I have 10 switch panels ready to go so I will reply later today to those who sent me PM's. Once these 10 are gone those may be the last of them until Fall at the earliest as I am tied up with other projects.
    colenation, biebs96 and TRDFerguson like this.
  16. Aug 10, 2022 at 12:11 PM
    #466
    Bradyboyy88
    Shaun
    do you have any that don’t have the screws on the top ?
  17. Aug 10, 2022 at 12:23 PM
    #467
    abomb60
    Massachusetts
    I do just none printed at this time.
  18. Aug 10, 2022 at 12:33 PM
    #468
    Bradyboyy88
    Shaun
  19. Aug 11, 2022 at 4:11 AM
    #469
    Gaston
    Gaston New Member
    Gary
    SE MI
    The Ender3 is a cheap but capable printer. But I'm not sure they will want to share the STL file if they are selling the product. I'd start with some calibration prints to get the settings for your filament dialed in :thumbsup:
  20. Aug 11, 2022 at 4:47 AM
    #470
    Bradyboyy88
    Shaun
    I remember the file being somewhere on this forum but I’d be happy to buy if there were some made up without the screws on top.
  21. Aug 11, 2022 at 5:01 AM
    #471
    Gaston
    Gaston New Member
    Gary
    SE MI
    Someone else posted that file if I'm not mistaken
  22. Aug 11, 2022 at 7:37 AM
    #472
    abomb60
    Massachusetts
    Yeah that should work just fine. The original file is around here somewhere but I can share it as well as the version I created without the top holes. I was just printing these to help out others on the forum and not as a source of income :)
    bulldog93 likes this.
  23. Aug 11, 2022 at 7:44 AM
    #473
    abomb60
    Massachusetts
    Replied to you that PM'd me with interest. I will have 6 left after these so let me know if you want one.
  24. Aug 11, 2022 at 8:46 PM
    #474
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The original one that Adam started with is posted in my build thread (check my signature, then it's linked in the first post). I may have to ask him for the non-screw one in return...
    jhardy1979 likes this.
  25. Aug 12, 2022 at 9:14 AM
    #475
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
  26. Aug 12, 2022 at 5:55 PM
    #476
    RainMan_PNW
    Casey
    Clark County, WA
    TRDFerguson likes this.
  27. Aug 12, 2022 at 6:19 PM
    #477
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    Copy. Thanks!
  28. Aug 13, 2022 at 8:41 PM
    #478
    abomb60
    Massachusetts
    Not a problem just give me a place to post it with yours if you can.
    For those with orders in already I'm just running a bit behind. Having a printer issue for those that wanted no top holes so still working through that and it's my birthday tomorrow so my plans are out the window this weekend in favor of what the wife has planned for me (which at least for today was finally, after 5 years of painstaking research, buying a travel trailer!). If anyone has any tow mirror suggestions please let me know ... https://www.tundras.com/threads/tow-mirrors.111458/#post-2877119
    For those who ordered the normal with hole version they are printed and will ship to you Monday.
  29. Aug 13, 2022 at 10:14 PM
    #479
    RainMan_PNW
    Casey
    Clark County, WA
    If you put the STL in a zip file and PM it to me, I’d be happy to put it up in my build thread with the other one.
    Pillslinger likes this.
  30. Aug 19, 2022 at 1:53 PM
    #480
    colenation
    Cole
    Alabama
    I received my switch panel from @abomb60 today and can’t wait to install it. For those that have the panel w/o screws showing, are there any recommendations for which screws to secure it with? Thanks.
Thread Status:
