FS: 2018 Tundra LED Headlights Plug N Play wire Harness for 2014-2017 models
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Oct 14, 2017.
Thread Status:
Not open for further replies.
  1. Mar 31, 2018 at 1:35 PM
    #541
    iHacker
    iHacker [OP] SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Mine have a wire going into the cab for dimming module install under dash
  2. Mar 31, 2018 at 1:57 PM
    #542
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    Love those pictures of my truck at driveway while I was working on it to install retrofit heads
    iHacker[QUOTED][OP] likes this.
  3. Mar 31, 2018 at 5:23 PM
    #543
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    That’s what the wire is for? How do I dim them once in the cab? I don’t think my 2015 stock headlights have a dimming feature?
  4. Mar 31, 2018 at 5:48 PM
    #544
    iHacker
    Mario
    That is possible with the relay installed under dash, this feature not present in SR5 trucks but the relay does the trick ;)
    LKSR5-14 likes this.
  5. Mar 31, 2018 at 7:58 PM
    #545
    OceanSkyWolf
    OceanSkyWolf New Member
    2017 MGM CM
    If I do the gray wire cut to remove the amber DRL, is there anyway I can get it back after cutting?
  6. Mar 31, 2018 at 8:01 PM
    #546
    iHacker
    Mario
    Not necessarily have to cut that wire you can depin it just for a moment if not like it just insert the pin back to its original place
    Check this video
    https://youtu.be/5Vp4wjDK19I
  7. Apr 1, 2018 at 11:30 AM
    #547
    Boosted4runner
    WA
    Shit! I’m at the Depin gray wire part - so you pop the white cap up, then what? Just stick a screwdriver in there and it pops out?
    I don’t know if my hands are big or what but this is a serious pain in the ass!!
  8. Apr 1, 2018 at 11:49 AM
    #548
    Boosted4runner
    WA
    I’m actually bending the thumbtack?
    Wtf am I doing wrong! LOL
    This stupid gray wire will not pop out!
  9. Apr 1, 2018 at 12:01 PM
    #549
    Boosted4runner
    WA
    I am now Fing up the plug! Wtf!?!??
  10. Apr 1, 2018 at 12:05 PM
    #550
    iHacker
    Mario
    As you can see there are two hole types one square and other kind of T, the thumbtack must be inserted in the T type holes
  11. Apr 1, 2018 at 12:10 PM
    #551
    iHacker
    Mario
    This white plastic clip is kind of spring action locking the terminal in place
  12. Apr 1, 2018 at 12:15 PM
    #552
    Boosted4runner
    WA
    What white clip? The one on top that I popped open on top?
    I am inserting the pin-tack into the T part.
  13. Apr 1, 2018 at 12:17 PM
    #553
    Boosted4runner
    WA
    What’s the worse case scenario here - just cut the gray wire and electrical tape to your relay black wire?
  14. Apr 1, 2018 at 12:20 PM
    #554
    iHacker
    Mario
    Look the big lock you release with a screw driver lock them all together in the connector, but also each terminal have its own locking clip see in pictures
  15. Apr 1, 2018 at 12:20 PM
    #555
    Boosted4runner
    WA
    Ohhhhh - the white clip inside the plug where I’m inserting the tack?
    Oh I think I must’ve broke that.
    I didn’t understand there was a white clip in there. I thought it was like my old RC car battery plugs where the wire had a metal clip that you press down on.
    Shit.
  16. Apr 1, 2018 at 12:21 PM
    #556
    Boosted4runner
    WA
    I was putting pressure on the tack in the wrong direction.
    Lovely.
  17. Apr 1, 2018 at 12:22 PM
    #557
    iHacker
    Mario
    I think you can still make it
  18. Apr 1, 2018 at 12:23 PM
    #558
    Boosted4runner
    WA
    Can I clip the gray wire?
  19. Apr 1, 2018 at 12:23 PM
    #559
    iHacker
    Mario
    I see the cavity a little busted but still can see the white clip
  20. Apr 1, 2018 at 12:23 PM
    #560
    Boosted4runner
    WA
    I can’t get it.
  21. Apr 1, 2018 at 12:25 PM
    #561
    iHacker
    Mario
    Try pushing the wire towards to you to loose the plastic clip and then insert the thumbtack all the way in and try pushing thumbtack down and pull wire out
  22. Apr 1, 2018 at 12:26 PM
    #562
    iHacker
    Mario
    Thumbtack between plastic clip and metal terminal
  23. Apr 1, 2018 at 12:28 PM
    #563
    iHacker
    Mario
    The last option is clipping the wire but don’t cut the wire too close to the connector, leave a little bit of wire for the future if you ever need to splice or solder that wire if going back to stock headlights
  24. Apr 1, 2018 at 12:29 PM
    #564
    Boosted4runner
    WA
    I can’t get the damn thing.
  25. Apr 1, 2018 at 12:30 PM
    #565
    Boosted4runner
    WA
    I pushed gray wire back in with pliers even.
  26. Apr 1, 2018 at 12:33 PM
    #566
    iHacker
    Mario
  27. Apr 1, 2018 at 12:38 PM
    #567
    iHacker
    Mario
    That wire is a PITA for some guys, maybe the worst part of the install depinning is intended for a good reason to avoid permanently damaging that wire (clipping wire is the easiest way but for a price)
  28. Apr 1, 2018 at 12:40 PM
    #568
    Boosted4runner
    WA
    I have the soldering iron warming up
  29. Apr 1, 2018 at 12:40 PM
    #569
    iHacker
    Mario
    Perfect that make a solid connection :thumbsup::thumbsup:
  30. Apr 1, 2018 at 12:43 PM
    #570
    Hermel
    Hermel New Member
    Mark
    Virginia Beach
    ‘15 White DC TRD Pro
    I had the same issue with that gray wire. I know that frustration all too well haha
    iHacker[OP] likes this.
Thread Status:
