FS: 2018 Tundra LED Headlights Plug N Play wire Harness for 2014-2017 models
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by iHacker, Oct 14, 2017.
Thread Status:
Not open for further replies.
  1. Feb 7, 2018 at 3:54 PM
    #421
    dsimonl
    dsimonl New Member
    2017 Tundra DC Limited MGM
    Amp Research Powersteps and Bedstep, 2018 LED headlights, LineX Platinum, Baja Designs fog lights, Driver side grab handle, SwingCase
    I don't know what you are asking, but if you use iHacker's harness and follow the installation instructions, the lights and DRL will function exactly as those on an '18 truck.
    geno0506 and iHacker[OP] like this.
  2. Feb 7, 2018 at 5:09 PM
    #422
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I guess my question is about the amber, on a 18 is it on when the LED DRLs are on? I know he offers two harnesses one with amber and no DRL dimming which comes on when ignition is on ACC, is the other harness the same configuration as factory 18?
  3. Feb 7, 2018 at 5:15 PM
    #423
    Azblue
    The Dirty T ( ^_^)_且
    No, I believe that on a stock 2018 the amber is not used as a DRL at all, only as a turn signal. With iHacker's harness and provided instructions your's will be identical.
    geno0506, iHacker[OP] and TxLock21 like this.
  4. Feb 7, 2018 at 5:46 PM
    #424
    Rngr188
    Chad
    Harrison AR
    Ok cool.
  5. Feb 7, 2018 at 6:39 PM
    #425
    iHacker
    iHacker [OP] SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Sorry for the delayed response Thank @dsimonl and @Azblue for your help I guess they have you covered with your question, the new 2018 Trucks don’t use the ambers in the center as DRL they are used only as turn signals
    Depending in your choice both of my harnesses for Non-LED trucks can replicate the 2018 trucks function with ambers only as turn signals or you can also have ambers and LED as DRL that’s up to you my thread includes the instructions for both scenarios
    The only difference is one uses a fuse tap so LED turn on with the key in ACC position and never dim with headlights
    And the other keeps factory style using the OEM DRL wiring and functionality
    Azblue likes this.
  6. Feb 8, 2018 at 4:48 PM
    #426
    Exile86
    Exile86 New Member
    Brandon
    2016 tundra trd pro
    D1EDAAB6-472D-4116-A788-0813696EBF46.jpg AC9E209D-ADEE-4C0A-AC2A-2357882762A8.jpg Got the headlights in and the harness and the motocontoll and all I have to say is wow! The new headlights look amazing and the harness was just built to be the easiest install. It wa built with high quality materials and everything being labeled made the install a breeze. The worst part of the install for me was getting the wire through the firewall. Didn’t have the correct tools so had to improvise. Other than that it went flawless. Thank you iHacker for making this harness!!!
  7. Feb 8, 2018 at 4:48 PM
    #427
    Exile86
    Exile86 New Member
    Brandon
    2016 tundra trd pro
  8. Feb 8, 2018 at 4:54 PM
    #428
    iHacker
    Mario
    Nice pictures :thumbsup::thumbsup:
  9. Feb 8, 2018 at 5:06 PM
    #429
    geno0506
    geno0506 New Member
    Michael
    Looks awesome, my main slow down was the depinning the gray wire :frusty:, thankfully The Master-iHacker :bowdown: saved the day! Glad yours went well!
  10. Feb 8, 2018 at 8:08 PM
    #430
    Exile86
    Exile86 New Member
    Brandon
    2016 tundra trd pro
    Probably would have slowed me down too if I didn’t decide to leave mine connected because I feel like the yellow running lights are a tundra signature.
    geno0506[QUOTED] likes this.
  11. Feb 8, 2018 at 8:23 PM
    #431
    geno0506
    geno0506 New Member
    Michael
    cool, so you have the white and amber DRL on at same time!
  12. Feb 8, 2018 at 8:43 PM
    #432
    geno0506
    geno0506 New Member
    Michael
    My drivers side seems a bit higher the the pax side, guess I'll have to check it out
    My drivers side light seems a bit higher then the passenger side, did you figure yours out!
  13. Feb 8, 2018 at 9:04 PM
    #433
    geno0506
    geno0506 New Member
    Michael
    Well after a week of night driving I notice that my drivers side headlight is higher then my passenger side. So I had to dial the motors down, when I do that an I come to a hill or at an incline I notice the pattern throws 2 box type patterns in front of the truck about 20 feet in front, I guess being I have them dialed down! So with that said, yes the drivers square is higher then the passenger!
    Any input how I can correct this, unfortunately my driveway is slanted and not level! I heard someone mention that I can check how they are dialed in on my take offs and copy those setting to my new one, setting them with a screw driver I assume, unless there is an easier way!
    Would I set the inside dials to 0, then set the lights manually!
    Any help thanks!
    Micheal
  14. Feb 9, 2018 at 8:17 PM
    #434
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Michael @geno0506 you are not alone. My driver's side was also higher than my passenger side...so here's what I did...
    First, since I read on the thread about other's driver side being higher than passenger, I marked the aim of my stock headlights on my garage door with painter's tape before removing them (including the distance in my driveway and position of my tires). I read a lot, so I found a video "how to" in thread #325 on this page:
    https://www.tundras.com/threads/201...-harness-sales-thread-eledobleu.17008/page-11
    After I removed the stock headlights, I noticed a white adjustment knob where the leveler motors are on the back of each headlight case that would be toward each fender when installed. There is also a guide that looks like a funnel going from the top of the adjustment knob to the top of the light fixture. When installed, you can used a Phillips head screwdriver passed through this "funnel" to reach the adjustment screw which will move the headlight up or down.
    So, after installing the '18 LED headlights, I backed out of the garage to the tire marks in the driveway and turned on the headlights and marked the position of the new lights. I wasn't sure whether the adjustment would fight the headlight adjustment motors, so before I made an adjustment I turned off the lights, adjusted and then turned them on again. It was pretty much trial and error at that point, but only took about 5 minutes to adjust - I turned it several turns to see if I could make it change and then if it was the wrong way, I just turned it the other way.
    I only had to adjust the driver side down a bit, so it was easy. Passenger side was spot on.
    I hope this helps. check out the video.
  15. Feb 9, 2018 at 8:23 PM
    #435
    geno0506
    geno0506 New Member
    Michael
    WOW Chuck, thanks for the heads up, about how long of Phillips would I need to get in there, may have to buy a longer one being I only have smaller in length! Since mine are already installed do you think I should lower them from inside the cab and then adjust!
    much appreciated brother :cheers:
    ChucklesToy[QUOTED] likes this.
  16. Feb 9, 2018 at 8:36 PM
    #436
    OceanSkyWolf
    OceanSkyWolf New Member
    2017 MGM CM
    So if I have switchback DRLs can I reuse them in the 18 headlights and have the same functionality?
  17. Feb 9, 2018 at 8:43 PM
    #437
    iHacker
    Mario
    I’m sorry for the delay in my response Michael, well if you didn’t mark your hotspots for old headlights before removing them a good idea to start is measuring the high from headlights to do that measure tape the distance from the floor to the mark dots in each headlight that’s the target measures to mark in your wall using painters tape, after getting that just level your headlights with the painters tape , your truck must be at at least 25FT distance from wall to get a perfect leveling. Passenger side must be 1-2” higher than driver side
    Here a good video I always share for this, really easy to do
    https://youtu.be/GWvSWBlAwnI
    Thanks
    ChucklesToy and geno0506[QUOTED] like this.
  18. Feb 9, 2018 at 8:45 PM
    #438
    geno0506
    geno0506 New Member
    Michael
    Thanks buddy! :thumbsup:
  19. Feb 9, 2018 at 8:46 PM
    #439
    iHacker
    Mario
    Something I forget is to mention that before start doing this place your leveling know in Zero then manually do the process mentioned before
  20. Feb 9, 2018 at 9:04 PM
    #440
    iHacker
    Mario
    Yes they should work without any problem just leave the gray wire in place to keep your Amber DRL
  21. Feb 9, 2018 at 9:09 PM
    #441
    geno0506
    geno0506 New Member
    Michael
    Ok so zero the dial in the cab then manually turn the headlight screw with driver
  22. Feb 9, 2018 at 9:19 PM
    #442
    iHacker
    Mario
    Yeah
  23. Feb 9, 2018 at 9:22 PM
    #443
    geno0506
    geno0506 New Member
    Michael
    :cheers:
  24. Feb 11, 2018 at 1:21 PM
    #444
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
  25. Feb 11, 2018 at 2:16 PM
    #445
    iHacker
    Mario
    TomC843[QUOTED] likes this.
  26. Feb 11, 2018 at 4:44 PM
    #446
    OceanSkyWolf
    2017 MGM CM
    What option harness did you get?
  27. Feb 11, 2018 at 7:09 PM
    #447
    TomC843
    Tom
    Charleston, SC
    SR5 with the easy fuse tap.
  28. Feb 25, 2018 at 4:13 PM
    #448
    iHacker
    Mario
    I have all this ready to ship if anyone is looking for a set (More sets coming in next days)
    (3) PRO/SR5/TSS/LTD (Dimming only)
    (3) Platinum/1794
    Now all include the adapters to rewire turn signals.
    PMe for any questions.
    Thank you.
    boostedtrdpro, TomC843 and geno0506 like this.
  29. Feb 26, 2018 at 6:09 AM
    #449
    Whitewhale
    Whitewhale New Member
    Kyle
    The Berkshires
    16' white limited
  30. Feb 28, 2018 at 5:18 PM
    #450
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    Hello fellow Tundra owners, new member to the forum.
    2017 1794 Silver Sky 4x4 (pics and build info to follow)
    First off I want to thank everyone that has contributed to the 18" LED headlight conversion with detailed info, diagrams etc. I completed my conversion and it was a piece of cake with all the info you guys have provided. I do have one odd question I did the re-pin on both turn signals and the passenger side is error-free flashes normal. On the driver side, I have the hyper-flash. I have replaced the bulb (standard bulb) and it still hyper-flashes.
    Is there any further trouble-shooting, I might look into?
    boostedtrdpro likes this.
Thread Status:
