2018 LED Headlight PNP Wire Harness Sales Thread (eledobleu)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Sep 29, 2017.
  1. Nov 13, 2017 at 10:37 AM
    #301
    Milkman
    Milkman New Member
    2017 Tundra TRD Off-Road Double Cap
    Line-X, OEM Off-road Steps
    Got my harness and headlights in and I have a problem. Everything works fine except for my driver side high beam. I’ve unhooked the battery and tried to reset. I’ve checked both plugs and wires all the way from headlight to morimoto for loose wires and still nothing, no flicker or anything.
    Anybody have any additional troubleshooting to try? I’m going to flip the headlight over to the other side to make sure the actual high beam works next.
  2. Nov 13, 2017 at 10:51 AM
    #302
    Milkman
    Milkman New Member
    Ok flipped headlights and the high beam works fine in the actual headlight and it’s off on the one that worked.
    Is there a fuse for high beam per side and if not I must have an harness issue I guess unless somehow the low beam high beam may have been switched when labeled? Would the headlight still function?
  3. Nov 13, 2017 at 11:00 AM
    #303
    Milkman
    Milkman New Member
    Ok found the fuses and both are good, even switched them out for the spare to make sure. Pointing to the harness now.
  4. Nov 13, 2017 at 12:12 PM
    #304
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    Swap harnesses and see if it’s a harness problem.
    Could also be a bad motocontrol
  5. Nov 13, 2017 at 12:52 PM
    #305
    Milkman
    Milkman New Member
    Thanks Inferno, swapped harnesses and no luck, must be the motocontrol. I’ll PM eledoblue and see if I can’t get another on the way. Hopefully it’s just that and I don’t have to undo all the wiring.
  6. Nov 13, 2017 at 1:33 PM
    #306
    ncmtnman
    ncmtnman New Member
    Robert
    2016 Tundra Limited....and then some
    Level kit, Pro mods, shell, lights, and then some
    Alright, got the headlights, harness and started the process, but have so far been very unsuccessful in being able to do the repining of the turn signal. I've followed the instructions, but cannot get the wire to come out.....ideas? Thoughts? Rational suggestions?
  7. Nov 13, 2017 at 1:36 PM
    #307
    Milkman
    Milkman New Member
    I just finished the install on mine. The trick is you have to use a tiny flat blade screwdriver like this. It fits in the groove of the little tab that holds the pin.
  8. Nov 13, 2017 at 1:37 PM
    #308
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Make sure the white lock tab is removed, watch this vid around. 2:28 different connector same principle.
    https://youtu.be/znP_uZCak7M
  9. Nov 13, 2017 at 1:37 PM
    #309
    BayRunner
    2017 Tundra Platinum
    I too was having difficulties with the re-pin due to misunderstanding how to press the little tab. Inferno sent me this video which did the trick and easily allowed me to get the wire out. Pay attention around the 2 minute 38 second area.
  10. Nov 13, 2017 at 1:38 PM
    #310
    BayRunner
    Ha..Ha, you beat me to the enter key.
  11. Nov 13, 2017 at 1:39 PM
    #311
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Haha just seen that
  12. Nov 13, 2017 at 1:43 PM
    #312
    BayRunner
    My small flat head screwdriver was still too big and ended up using a long push pin similar to the one in the video.[/QUOTE]
  13. Nov 13, 2017 at 4:14 PM
    #313
    Milkman
    Milkman New Member
    Just want to follow up and share my fix for my high beam issue in case anyone else runs into this issue. Thanks to eledoblue for the quick response and narrowing down the issue quickly.
    If the lights work correctly but your missing low, high, or the LED’s it may be an issue in the 9006 connector shown in the photo. Make sure when you connect these connectors on the harness to the Fuse Relay and Motocontrol you make sure the pins are properly aligned. My high beam was not and they can still push together even not seated correctly.
    Now I just have to chase down where the headlight adjustment screw is and I’m done!
  14. Nov 13, 2017 at 4:19 PM
    #314
    ncmtnman
    ncmtnman New Member
    Robert
    Thanks so much Inferno, Milkman and BayRunner! Watched the vid and saw what I was doing wrong and then easy peasy. Install complete and lights working like a charm and pics to follow!
  15. Nov 13, 2017 at 7:17 PM
    #315
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    There seemed to be a problem with one of the companies I order the 9006 connectors from which didnt allow the pins to seat correctly. I have since switched companies so now the harnesses wontr have that issue anymore.
    inferno_pro_satx, Buildn and Masshole like this.
  16. Nov 14, 2017 at 11:49 AM
    #316
    mikedroof
    mikedroof New Member
    Michael
    2017 Charcoal Tundra SR5
    Does anyone know how to unpin gray wire? The plastic connector seems impenetrable!!!
  17. Nov 14, 2017 at 12:43 PM
    #317
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Hi eledobleu ,
    I started a private conversation with you regarding a conversion kit for my 2015 Platinum. Please let me know how you would like payment for the kit.
  18. Nov 14, 2017 at 3:03 PM
    #318
    mikedroof
    Michael
    Received other headlight today and finished it all up. Turned out really well and looks great!
    aperezsh, geno0506, X09 and 3 others like this.
  19. Nov 15, 2017 at 4:26 AM
    #319
    Cbrunt
    Cbrunt 2017 SR5 CM
    Charles
    Sacramento
    2017 White SR5 Crewmax
    Bakflip g2 cover Trd pro grill/bulge Nerf bar steps
  20. Nov 17, 2017 at 5:05 PM
    #320
    BigTimber
    BigTimber New Member
    Ben
    Casper, WY
    2016 TRD Pro
    Just installed mine and I have the same problem. I thought I saw on one of these threads how to adjust, but can't find it now.
  21. Nov 17, 2017 at 5:27 PM
    #321
    BigTimber
    Ben
    Casper, WY
    2016 TRD Pro
    Found it!
    Post #578 in the thread
    2018 Tundra LED headlight wiring info with diagrams
  22. Nov 17, 2017 at 5:49 PM
    #322
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Here is a good video to aim your headlights correctly
    https://youtu.be/GWvSWBlAwnI
    Sent from my iPhone
    BamaMan44 likes this.
  23. Nov 18, 2017 at 5:58 PM
    #323
    Prerunnertundra15
    Prerunnertundra15 New Member
    Socal
    2015 Sr5 crew max
  24. Nov 18, 2017 at 6:23 PM
    #324
    Azblue
    The Dirty T ( ^_^)_且
    eledobleu Are you going to do a Black Friday thing, should I wait a week? Also, I currently have LED rear turns and switchback fronts so I run a single 3ohm V-led resistor per side. The new 2018 headlights come with a standard bulb (from what I can Tell) so would I need to swap that for a 6ohm or install LED 7444's in the front turns?
  25. Nov 20, 2017 at 2:38 AM
    #325
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    Sorry to beat a dead horse.
    So how are a 2018 sr5 and 2018 limited different under the hood?
    Is there a whole different sub harness and additional relays to drive the LED headlights on sr5 vs limited?
    In 2018, the harness and electronics to drive the LED DRL's are there in all trims. But the base trucks (SR/SR5) have H4 halogen headlamps.
    Thanks,
    Andy
  26. Nov 20, 2017 at 5:27 AM
    #326
    BigTimber
    Ben
    Casper, WY
    2016 TRD Pro
    I left my purple wire in the middle (without cutting the gray wire inside) and have no issues. Love having the amber on with the DRLs.
    Thanks to everyone!
    geno0506 likes this.
  27. Nov 20, 2017 at 6:35 AM
    #327
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    The 2018 SR5 and limited on up both have different harnesses since they are different LED’s
  28. Nov 21, 2017 at 7:10 AM
    #328
    Vector W8
    Hi Everyone,
    Last week I ordered the harnesses from eledobleu's sight. Other than a receipt I have not received a confirmation of shipment nor have I been able to get a hold of him through pm's.
    How long did it take for your to receive your harness's and controller once your order was placed?
    Thanks.
  29. Nov 21, 2017 at 7:16 AM
    #329
    Prerunnertundra15
    Socal
    2015 Sr5 crew max
    Vector W8 likes this.
  30. Nov 21, 2017 at 10:32 AM
    #330
    tinyt1553
    tinyt1553 New Member
    Tom
    Cypress, TX
    2017 1794 CM - Magnetic Gray
    Exterior: POP & Lock Power Tailgate lock BakFlip MX4 Tonneau Cover Rhino Bed Liner Swapped OEM Halogen Fogs with Formula-J87 LED 6000k bulbs Rough Country 60" Tailgate LED lightbar 6" rubber stub antenna Interior: Front Emblem Camera with anytime backup cam, Crux Vimty-05 for Vehicle in Motion Override Center console wireless charging Verizon Hotspot in center console Chromecast to OEM head-unit display ESP Rear Seat 3 Compartment Storage 5% Ceramic tint on rear window and rear doors 18% Ceramic tint on front doors Weathertech rear seat cover (try to take Hank (boxer/pointer mix) with me everywhere I can) In The Works: Upgrade to 2018 OEM LED Headlights VLEDs throughout the rear (turns, brakes, highmount 3rd brake and cargo) GRT Lighting LED's to replace all interior bulbs Future Wishlist: Swap OEM Head-unit with Kenwood DNX994S and use iDataLink Maestro RR to integrate OEM backup cam, OEM USBs, OEM Aux input, etc AMP-Research Power Sidesteps Train (air) horn
    Where's everyone ordering their 2018 oem housings from? Dealer? Website?
