Front sway bar removal ?
Discussion in 'Suspension' started by TheBeast, Oct 8, 2017.
  1. Apr 30, 2019 at 1:49 PM
    #61
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I took mine off this past weekend, been driving around with it and haven't even noticed it's gone. I don't haul anything so I can't comment on that. I have the toytec boss coilovers set at 3.5" in the front with 700lb springs.
  2. May 17, 2019 at 6:32 AM
    #62
    Novajess1972
    Novajess1972 New Member
    Jesse
    2019 MGM TSS OFF ROAD
    Ready Lift 4in/20x10 Fuel Triton/35x12.50 BFG KM3
    I guess it makes sense that it would help, as the new Jeeps feature an electronic sway bar disconnect system to increase articulation during aggressive off-roading.
  3. Nov 16, 2019 at 10:10 AM
    #63
    runCMD
    runCMD BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    Buuuuump, I can’t seem to find a good quick disconnect system. That is what I’d be interested in.
  4. Nov 25, 2019 at 7:56 PM
    #64
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    What is everyone’s thoughts of removing the front sway bar with a spindle lift but stock coil over?? I had done it with my Tacoma with a spindle lift and it drove amazing but that’s a much smaller truck. What’s your guy’s thoughts? I have a much wider stance now with the spindles and the 12 offset rims that seems like it would perform better without it.
  5. Mar 16, 2021 at 6:11 AM
    #65
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    Sorry to open an old post back up but have a dilemma.
    Thinking of removing my front sway bar. Currently running Bilstein TRD PRO suspension with 285/75/18 tires. Tires will ever so slightly rub against the FSB when on a decline at full right or left. This is my daily driver and I don't tow anything. About 50 miles (there and back) highway is my daily commute. I am a weekend off-roader but don't rock crawl. My worry is when I add bumper that all of the weight will cause it to rub more. Thoughts on removing the front sway bar and keeping the rear on with my setup?
  6. Mar 16, 2021 at 8:12 AM
    #66
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Ran my truck without one for about a year and a half. Truck suspension definitely comes alive without. I did not run into any issues without it. Some people like it with and some like it without. I am told aftermarket suspension benefits the most without it.
    YotaBro[QUOTED] likes this.
  7. Mar 16, 2021 at 11:09 AM
    #67
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Should be pretty easy to remove and reinstall if you're not happy without it. I know a lot of guys that've removed it but none that have reinstalled it. Removing it makes the front IFS feel like.....IFS. The rear is usually removed for better ground clearance.
  8. Mar 16, 2021 at 12:19 PM
    #68
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    There's no chance in hell that I would drive around without my front and rear anti-roll bars installed & functional.
  9. Mar 16, 2021 at 12:35 PM
    #69
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    I would pull the sway bars off for a mild offroad vehicle so you can get the full articulation in the very limited travel these trucks have. I have done the same to all my trucks for the past 22 years including two F250s I towed with. Learn your trucks limits and don't push it past that.
    YotaBro likes this.
