Front Suspension SOS
Discussion in 'Suspension' started by EAK, Mar 9, 2020.
  1. Mar 24, 2020 at 10:19 AM
    #61
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    I would suggest to check condition of diff side axle seal. When I replaced my axle, forgot to check the seal and was leaking with a slow after installation.
  2. Mar 24, 2020 at 10:59 AM
    #62
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    I have to give you kudos for knowing when to call a pro...it isn't easy for a lot of guys to swallow their pride, admit their failure and call in the professionals. I've been in your shoes in the past, its humbling...
    It looks like he had to pull the axle assembly and reassemble the CV joint. I saw this video on YouTube where they show how to fix a slipped/disconnected CV joint.
    https://www.youtube.com/watch?v=hrPi0Cmh5Pc
    Good luck, hope you are back on the road soon! Hats off to you.
    :hattip:
  3. Mar 24, 2020 at 11:07 AM
    #63
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    BAMuffler 8” SS Bilstein 6112/5160 Icon UCAs
    This is exactly what happened. Hopefully the guy won't charge me an arm and a leg but he has done me solid by coming out to my house.
    Thanks for the support. It was a tough pill to swallow but I know my skill level is low and no need for further delays or expenses. My one concern is I hope I have the courage to pick up a wrench again. At least next time I will make sure I have someone with the knowledge and experience to help as I learn.
    chugs, glowblue[QUOTED] and JLS in WA like this.
  4. Jun 24, 2020 at 10:56 PM
    #64
    Kanobi13
    Kanobi13 New Member
    Was this resolved I'm in the same boat
  5. Jun 26, 2020 at 7:22 PM
    #65
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    I was able to get this fixed. Mechanic came out to my house and removed the CV joint. Took it to the shop, rebuilt it, installed it at my house, then finished putting on the UCAs and drivers side suspension. Cost me an additional $200 and a lot of frustration to learn a lesson.
  6. Jun 26, 2020 at 7:25 PM
    #66
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    How she stands now...
  7. Jun 26, 2020 at 7:35 PM
    #67
    Kanobi13
    Kanobi13 New Member
    Nice I have appt at dealer tomorrow I ended up putting everything back to stock but some play in it and spitting grease everywhere. So will see if they will warranty it if not I'll go from there
  8. Jun 27, 2020 at 4:35 AM
    #68
    glowblue
    VA
    That’s not bad... you lucked out.
  9. Jun 27, 2020 at 5:17 AM
    #69
    Kanobi13
    Kanobi13 New Member
    Yes we shall see what they say about fixing it though. Do you know where they got the rebuild kit?
  10. Jun 27, 2020 at 5:57 AM
    #70
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    I agree. There were other cost for install, but the $200 was just to fix my mistake. I thought the mechanic was reasonable, especially since I was in a tough spot without many options. I’ve since given him some more business on a few smaller things as another way to say thanks.
  11. Jun 27, 2020 at 5:58 AM
    #71
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    I believe he mentioned he ordered it from Toyota.
  12. Jul 10, 2020 at 3:04 PM
    #72
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    So can I ask is one lesson here to not remove the uca when putting in coil overs? I have considered doing this job myself as everything on YouTube looks easy. But now I am hesitant.
    Tundra2 likes this.
  13. Jul 10, 2020 at 3:12 PM
    #73
    Kanobi13
    Kanobi13 New Member
    Do not remove the UCA remove bottom bolts LCA. The Cam bolts for alignment to swing down. Front of them on front and back. Remove sway bar on ground before lifting truck. Best of luck
    robabeatle[QUOTED] likes this.
  14. Jul 10, 2020 at 5:24 PM
    #74
    glowblue
    VA
    ^This. You’ll will see videos on YouTube where they remove the UCA, it’s easier to remove the LCA and let it swing down by loosening the cam bolts.
