Front Suspension SOS
Discussion in 'Suspension' started by EAK, Mar 9, 2020.
  1. Mar 9, 2020 at 8:54 AM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    BAMuffler 8” SS Bilstein 6112/5160 Icon UCAs
    I attempted to replace my front suspension with 6112s this weekend. Got stuck and decided to put everything back on and have a pro install.
    I’m stuck getting the spindle to connect to the UCA. It’s like the spindle is locked, no articulation up or down.
    Any advice would be greatly appreciated.
    Rica25 likes this.
  2. Mar 9, 2020 at 8:55 AM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    You need to loosen the UCA and rotate it down to the spindle
    Bob_Wiley, chugs, Tundyfundy and 2 others like this.
  3. Mar 9, 2020 at 8:59 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    I forget exactly how it all pieces together, but a quick thought.
    Sway bar disconnected?
    Rica25 likes this.
  4. Mar 9, 2020 at 9:00 AM
    SC_TRD
    Colin
    Round Rock, Tx
    UCA does seem angled really high, I also think this is a good idea
    Rica25 likes this.
  5. Mar 9, 2020 at 9:01 AM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    @PLC721 thanks for such a quick response. It seems if I loosen the UCA it still won’t reach the spindle.
    In all the videos I’ve seen replacing UCAs the spindle just moves right in to place. Mine is locked.
    Rica25 likes this.
  6. Mar 9, 2020 at 9:02 AM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    I reconnected the sway bar. I’ll remove and try again.
    SC_TRD[QUOTED] likes this.
  7. Mar 9, 2020 at 9:04 AM
    SC_TRD
    Colin
    Round Rock, Tx
    if the other tire is in the ground and sway bar is connected, will definitely make things hard. I have also had to use a small bottle jack to lift up the LCA to get things into the right position, then really pull down on the UCA.. of course doing this solo is much more difficult, but the Jack should help if you don’t have a buddy to help
    14srAKH, Inquiringone and 831Tun like this.
  8. Mar 9, 2020 at 5:09 PM
    SC_TRD
    Colin
    Round Rock, Tx
    Any luck?
  9. Mar 9, 2020 at 5:32 PM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    Unfortunately not. Obviously my mechanical skills are limited. Someone that knew what they were doing could probably fix it in 20 minutes.
    I like to wrench but don’t have a lot of experience. YouTube gave me confidence to successfully replace my my rear shocks and shackles, which I was quite proud of. I ended up calling a mobile mechanic to come to my house to get the wheel on tomorrow and will drive to a professional shop.
    I really appreciate you and the other folks that stepped up to try to help in such a short period of time.
  10. Mar 9, 2020 at 5:36 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Did you accidentally pull the axle out?
    Flyinryank and focal like this.
  11. Mar 9, 2020 at 5:37 PM
    SouthWestGA
    SouthWestGA New Member
    Loosen upper control arm bolt
    Stick a bottle jack or floor jack under lower control arm/ball joint area and Jack it up
    One part moves down
    one moves up
    they meet in the middle
    Edited to add....if you’ve accidentally dislocated the axle nothing will help
  12. Mar 9, 2020 at 5:38 PM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    The axle boot looks to be extended. That could prevent it from aligning.
  13. Mar 9, 2020 at 5:55 PM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    Maybe? :notsure: I certainly wasn’t gentle getting the shock out of the bottom. Stood on the LCA to get clearance (like some of the YouTube videos showed).
    Hopefully this is not a difficult fix for a professional? Leave it to me to try and save a few bucks and create an expensive mess.
  14. Mar 9, 2020 at 5:57 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Its been a long time since i messed with cv axles, but maybe try moving it for and aft by the inner joint, maybe its “out of socket” for lack of better words?
    jeremyd likes this.
  15. Mar 9, 2020 at 5:58 PM
    vhstejskal
    Vic
    You’ll be fine to put the axle back and use a jack to lift the spindle up to the uca. Just take your time and don’t let the frustration get the better of you.
  16. Mar 9, 2020 at 6:08 PM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    I tried to use the jack under the LCA to bring the spindle to the UCA. It moved some, then seemed to start to lift the truck off the floor jacks, if that helps support the axle boot hypothesis. I don’t even know how to start to attempt that fix.
    I tried and found my limit. Sucks though sense i feel like I was pretty close to getting this done.
  17. Mar 9, 2020 at 6:13 PM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    The only reason I bailed and tried to get the old shock back in was because I couldn’t get the new 6112 seated at the bottom. Other than that o had this thing whipped. Minus the unforeseen issue with getting the UCA and spindle reconnected.
    Wrenching is fun, and I have a lot of respect for those that have the skills around a tool box. But this has been such a nightmare, I can’t see myself taking on any DIY for a while.
    Some one needs to come up with a “mechanic on demand” program. Similar to Dr. on demand.
  18. Mar 9, 2020 at 6:18 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Rookie mistake was disconnecting the UCA from the spindle. This helps prevent the assembly from dropping down so far and out that the axle slips out. Disconnect the spindle at the bottom and loosen the LCA bolts and the longer assembly would go in a lot easier.
    Tundyfundy, jeremyd and Hbjeff like this.
  19. Mar 9, 2020 at 6:19 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    This challenge is good for you. When you beat it you will be better for it.
    Personally i would leave the uca connected to install the new setup
    Darkness, Tundra2 and jeremyd like this.
  20. Mar 9, 2020 at 6:22 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    This is true true true.
    Maybe take the oe shock out and get it fixed without the tension
  21. Mar 9, 2020 at 6:25 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    Couldn’t help but notice that jack;)
  22. Mar 9, 2020 at 6:27 PM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    This I learned today.
    Danman34[QUOTED] and Jpneely like this.
  23. Mar 9, 2020 at 6:51 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Not sure if this makes sense, but I'm thinking maybe disconnect the spindle on the bottom, Then carefully make sure the cv is where it needs to be , then connect spindle to the UCA. Then attempt to use the jack and button everything back up. Dang ! if you were close I'd drive over and help you !
    Hbjeff likes this.
  24. Mar 9, 2020 at 7:14 PM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    This makes sense but at this point I needed my truck back to operation like yesterday (I took off work today because I thought I figured it out while laying in bed last night). Just going to fork over the money to have it done right and chalk it up as a life lesson.
    There’s a lot of knowledgeable folks on here that are generous with their time. Heck, a year ago prior to joining this forum it would never have crossed my mind to even attempt this project on my own. Maybe it’s the forum’s fault I’m in this predicament? /s
    TXTundra2722 likes this.
  25. Mar 9, 2020 at 7:18 PM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    A lot of reading on the forum and watching YouTube videos, I have learned that I like working on my truck. So far I have accomplished:
    - installing front grille and surround
    - replacing headlights w/ TRD Pros
    - installing 5160s in rear
    - installing CB shackles (didn’t know what a shackle did but had to get on the group buy)
    - installed Kenwood 9906xr (@00Tyler10 did most of the work)
    This one got the better of me but I’ve still learned a lot throughout this ordeal.
    Luckydog, Bob_Wiley, RangerBP and 3 others like this.
  26. Mar 9, 2020 at 7:19 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Dont give up. Im sure someone lives in KY that will help you.
    Just get her back together and restart
    SC_TRD and jeremyd like this.
  27. Mar 9, 2020 at 8:23 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    You’re taking the shock assembly out when you’re trying to reattach the UCA, right? If you’re still working on it I’d do that.
    jeremyd, TXTundra2722 and Hbjeff like this.
  28. Mar 9, 2020 at 9:38 PM
    Dirt Dawg
    Dirt Dawg "It'd be a lot cooler if you did"
    Connor
    Denver, CO
    2014 Toyota Tundra Limited CrewMax 4x4
    Sounds like you over extended your CV and now it’s not wanting to go back together. Feel around the inner joint and see if you can feel the “cage” in the boot. If you slipped the cage out of the inner tulip, it might take some work to get everything back together.
  29. Mar 10, 2020 at 5:58 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Update?:popcorn:
  30. Mar 10, 2020 at 7:36 PM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    Her feet still hurt.
    I drove around to a couple of auto shops to see if anyone wanted a small job after work. Rightfully so, not too many people want to do work at someone’s house (liability reasons). However, I might have a guy stopping by tomorrow to get her shoes back on.
    I think the extended cv hypothesis has legs. I bounced the LCA with my legs to try to get the 6112 to seat. It sounds like may have caused a secondary issue.
    Chalking this one up as a life lesson. I found my limitation (at least going solo).
