Front hitch receiver mount
Discussion in 'Towing & Hauling' started by camphuntfishid, Oct 14, 2020.
  1. Oct 14, 2020 at 10:28 AM
    camphuntfishid
    camphuntfishid [OP] New Member
    2010 Crewmax 4X4
    I searched the blogs but could not find anything on buying/installing a 2" front receiver mount so that I can use a 12k lb. winch on the front and back of my 2010 Tundra. I am putting on RCI skid plates as well so need something that won't impede on the skid plate.
    Any suggestions on brands/models? Most mounts I've looked at are only rated at 9k lbs.
    chugs likes this.
  2. Oct 14, 2020 at 10:51 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    NewImprovedRon likes this.
  3. Oct 14, 2020 at 12:22 PM
    Welcome from NY.
    There was one on NY Craigslist for $50, but it's not there.
    Keep searching. Kurt or Hidden Hitch are good brands and Draw-Tite.
  4. Oct 14, 2020 at 12:24 PM
  5. Oct 15, 2020 at 10:04 AM
    camphuntfishid
    2010 Crewmax 4X4
    Thanks everyone for the feedback. I am going with the Curt receiver mount.
  6. Oct 15, 2020 at 10:39 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Do you have pix of this installed?
  7. Oct 15, 2020 at 11:07 AM
    Cidertom
    Cidertom Chionophile
    Tom
    2017 longbed
    this is the side view of mine in use. Curt hitch with home built extension. Works well. Installed fast. I'm going to remove it for oil changes instead of cutting the skid pan.
    chugs likes this.
  8. Oct 15, 2020 at 3:05 PM
    Cidertom
    Tom
    2017 longbed
    a better pix of the curt hitch install. It looks low, but is not below the bottom of the skid pan
    chugs and Trooper2 like this.
  9. Oct 15, 2020 at 4:33 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    You put so much effort into finding a 12k# rated hitch then added a home built extension? Unless you REALLY know your welding (and you may), you just de-rated your system, probably under the 9k# ratings that were not enough for you.
  10. Oct 15, 2020 at 4:38 PM
    Cidertom
    Tom
    2017 longbed
    Uh, I'm not the original poster, I was just giving the pix of what my install looked like. Mine is used just for maneuvering trailers into tight spaces-frequently.
    chugs, dittothat and Bakershack like this.
  11. Oct 15, 2020 at 7:59 PM
    Cidertom
    Tom
    2017 longbed
    I would also comment that I replaced the mounting bolts. Since I kept the OEM tow rings, the OEM bolts were, in my opinion, just marginal. They worked, but measurements showed they would just be flush with the weld nuts in the frame. I elected to replace them. I used M12-1.25 x 45 JIS head Flange Bolts 10.9 grade.
