Front facing cameras
Discussion in '2.5 Gen Tundras (2014-2021)' started by Boatmoney, Aug 7, 2019.
  1. Aug 9, 2019 at 11:48 AM
    RDRunner
    RDRunner New Member
    2016 SR5 Crewmax 4x4 TSS Edition
    It looks like it does not come on the 2020 Tundra. It is super cool for offroad.
  2. Aug 9, 2019 at 1:07 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I bought a $10 camera from eBay and so far so good. Night quality is a bit too noisy but still gets the job done.
    bulldog93 likes this.
  3. Nov 14, 2019 at 4:01 PM
    TxStateBoi
    TxStateBoi New Member
    R
    16 SR5 Blazing Blue Crewmax
  4. Nov 14, 2019 at 4:07 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  5. Dec 25, 2019 at 9:13 PM
    VietGuy
    VietGuy New Member
    Houston
    2019 Tundra CrewMax Cement
    Could you tell me where you got your bracket from and what you had to trim to make it work?
  6. Dec 25, 2019 at 10:22 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
  7. Dec 27, 2019 at 6:14 AM
    buffaluphagus
    buffaluphagus —————————————
    Dasaita
  8. Dec 27, 2019 at 6:29 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I just used a slotted corner bracket that I had laying around from another project. I had to widen the slotted part slightly to fit the camera shaft, then cut the side attaching to the back of the grille down to about 3/4 of an inch. I'm not entirely sure what the dimensions were. I basically just eyeballed it to fit.
  9. Dec 27, 2019 at 9:36 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    put a beat sonic on my 2019 works great!! someone on here sells one that gets rave reviews
  10. Dec 27, 2019 at 11:13 AM
    ptat
    ptat New Member
    The Beat-Sonic kit looks great! Does anyone know if it works for the 2020?
  11. Dec 27, 2019 at 12:23 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    give them a call! or email they are easy to work with
  12. Jan 5, 2020 at 11:17 PM
    BoerboelTundra
    BoerboelTundra New Member
    2020 Tundra Super White SR5
    Any chance parts could be bought from Toyota and used in the tundra for the same type of set up?
    jtwags likes this.
  13. Mar 19, 2022 at 3:13 PM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    I used an ikea bracket that I had left over and just had to make one small drill hole and it worked out great.
  14. Mar 19, 2022 at 3:15 PM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    Has anyone wired up using the OEM switch? Im not sure what wire goes to what?
  15. Mar 19, 2022 at 3:33 PM
    Badge618
    Badge618 New Member
    Lassen County, Ca
    2019 TRD Pro Voodoo Blue
    This should help. Or might help.
    bulldog93 and BlueRibbon4x4 like this.
  16. Mar 20, 2022 at 6:05 AM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    I bought mine from:
    https://www.anytimebackupcamera.com/collections/kits/products/anytime-backup-and-front-camera-full-kit
    Bought it
    Last fall, still haven’t installed it as I have to find a way to install it on my Limited grill… I don’t want to butcher it. The TundrasTex kit is probably a nicer camera install, but I do like the single OEM switch in the one I bought.
    the other thing I had to solve was that I didn’t have a place to put the switch… there were no blanks left in the dash. I had to buy a 3 blank panel from another member that 3D prints them that fits in the credit card sized depression in the console.
    it’s been a journey… need to finish this though… soonish. The camera my kit supplied doesn’t fit in the logo, any least without me fabricating something.
    BlueRibbon4x4 likes this.
  17. Mar 20, 2022 at 7:38 AM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    Thanks for me being novice installer it was not that easy of an install as anticipated with the OEM switch. I thought everything was going to be plug and play, I wasn’t expecting to solder wires. All the videos I find only show with the aftermarket switches, now I could have done better research on my part and if I had to do it again I wouldn’t have gone the OEM way. The two aftermarket switches are a better option in my opinion. I would do what others have done and mount it on the top part hidden away from eyes.
    Having a Platinum made it difficult with the mounting of the camera too but like I said in the previous posting I used an IKEA wall bracket I had sitting around and with some minor trimming it worked out great, nice and snug with the hot glue. I’ll replace the hot glue with some JB weld when completed. Hopefully I finish everything today
  18. Mar 20, 2022 at 7:52 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I wanted to install the platinum grille and didn’t get one because I couldn’t figure out a nice place to put my camera. Interested in what you come up with.
    GELCW likes this.
  19. Mar 20, 2022 at 12:45 PM
    #49
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    I attached the photos of the bracket and how it looks on the outside. I will spray paint it black when I put the JB weld on it but it’s all done for now.
    Unfortunately I never figured out where the gray and light blue cables go for the illumination of the OEM switch. I metered everything single option it could be, so in the end it’s not hooked up.
  20. Mar 20, 2022 at 12:55 PM
    #50
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    Oh one more thing DONT try and tap into the sensor on the grill for power and ground. Everything goes a little crazy with the airbag and LDA. In the end we ran it back to the battery and hook it up there.
  21. Feb 24, 2023 at 8:16 AM
    #51
    TuTun
    TuTun New Member
    Colby
    South east
    16 MGM Limited Crew 4×4
    Under frame puddle lights 18+ black led headlights i hacker headlight harness w/dimmer Honeycomb grill 2" Supreme Suspensions front leveling kit
  22. Feb 24, 2023 at 8:22 AM
    #52
    TuTun
    TuTun New Member
    Colby
    South east
    Drill a 5/16 hole beneath the emblem and using the Natika IP69K (39.99 Amazon) camera or equivalent, insert shaft horizontal and bolt from behind. Has to be a camera like this that works vertically or horizontally. Some must be mounted with the threaded shaft vertical for the view to be correct. This mount moves the camera farther out to give a better view of distance to object while parking.
    Sleeper16plat likes this.
