Front facing cameras
Discussion in '2.5 Gen Tundras (2014-2021)' started by Boatmoney, Aug 7, 2019.
  1. Aug 7, 2019 at 9:41 PM
    Boatmoney
    Boatmoney [OP] New Member
    Mark
    2019 black platnum tundra
    So I’m looking to add a front camera to my truck, I found this one but wanted to see what everyone is running I’m looking for a camera with a fisheye or wide angle lens. 2019 cm platinum
    https://www.anytimebackupcamera.com/
    619Tundra and lawrenceb like this.
  2. Aug 7, 2019 at 9:45 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    If you plan to keep the stock head unit, search for "FRAC harness" and there's a ton of information available.
    bulldog93 and Boatmoney[OP] like this.
  3. Aug 7, 2019 at 9:48 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
  4. Aug 8, 2019 at 4:52 AM
    ou77kg
    ou77kg New Member
    Erik
    2016 Tundra CM Platinum 4x4
    +1 for the FRAC harness, I have one and its a great piece of gear.
    TundraTex likes this.
  5. Aug 8, 2019 at 7:14 AM
    hooter
    hooter New Member
    2019 SR5 TRD Off Road Crewmax
  6. Aug 8, 2019 at 5:00 PM
    RDRunner
    RDRunner New Member
    2016 SR5 Crewmax 4x4 TSS Edition
    This is probably a dumb question, but why do you need a front camera? Is it to pull close to things in front or is it to record idiots in accident situations, or maybe both? I have seen youtube videos of people, especially in foreign countries, who run a front camera recorder at all times to have evidence of any wreaks, etc.
  7. Aug 8, 2019 at 10:21 PM
    Boatmoney
    Mark
    No it’s for distance gauging and parking, the tundra has such a short hood its hard to gauge how close you are to things while parking. Also I just curb rashed my right from rim from not seeing a curb. .
    RDRunner[QUOTED] likes this.
  8. Aug 8, 2019 at 10:23 PM
    Boatmoney
    Mark
    Any pics of the install location and the way it’s mounted?
  9. Aug 8, 2019 at 10:29 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I used an L bracket and some 3M tape to mount mine under the TSS. Seems to give a decent viewing angle. I'll try to remember to grab a pic of the camera view tomorrow.
  10. Aug 9, 2019 at 5:31 AM
    RDRunner
    RDRunner New Member
    I agree it could be useful. I would like to mount one too. I get out of my truck sometimes in a parking lot and see that I have not pulled up to the front line correctly.
  11. Aug 9, 2019 at 5:34 AM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Yes this looks good. How’s the clarity and night vision on it? Any way you could snap a pic of how you mounted it with the L bracket? If it’s too much work don’t sweat it at all I know these grilles can be a b!tch to work around some times. I have a ‘19 pro grille so I may need to fabricate another method anyway, we’ll see!
    Boatmoney[OP] likes this.
  12. Aug 9, 2019 at 6:58 AM
    Boatmoney
    Mark
    Damn man that looks super clean! Great job, you can hardly tell it’s there I have the exact same grill. Makes me really want to do this now.
  13. Aug 9, 2019 at 7:02 AM
    buffaluphagus
    buffaluphagus —————————————
  14. Aug 9, 2019 at 7:36 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I sometimes park on the street in a 2 vehicle spot between driveways so I can gauge how close I can get to the other car, the other person can just drive forward to leave. I need to be a certain distance from the driveway behind me per bylaw, or ahead of the signage if there's a post. I also gauge how forward I can be in shopping lots, so I find it useful.
    The cam is wired in a way if it ever breaks down, it's easy to switch out the first 2 feet to the connector behind the grille, can't beat $13, bought this exact one last Dec:
    https://www.amazon.com/NOAUKA-Waterproof-Reversing-Reverse-Universal/dp/B06XNM7GNS
    I'm using it with an android head unit but a FRAC will work well with stock.
    336FBE49-3EF0-447A-A4B4-ACED0D44E67F.jpg 21D38395-02C1-44B7-BB97-BEF8518C7B2B.jpg
    TNDRA6!9, bulldog93, panicman and 4 others like this.
  15. Aug 9, 2019 at 7:52 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I'm using this same camera - does it fit where you have it easily, or is there some flex on the grille surround and bumper because of it? I'm going to check my viewing angle compared to yours and maybe move mine there.
  16. Aug 9, 2019 at 8:30 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I found that to be the optimal spot without drilling anywhere. It's wedged with 3M double sided automotive tape, no flex and has stayed on all year. The screw comes up behind the plastic.
    You can see my bumper at the bottom of the screen in the 2nd pic, when it reaches that I have 5" left before it hits, I used a tall bucket to test, I literally spent an hour temporarily taping it to other spots, and I didn't want to drill into that pricey TSS cover. On a non 2019+ Pro grille, there's probably better spots.
  17. Aug 9, 2019 at 8:39 AM
    RDRunner
    RDRunner New Member
    How do you turn the front camera on when you need it? I know the back one comes on when you put it in reverse, but what triggers the front one?
  18. Aug 9, 2019 at 8:46 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    For stock HU, watch end of vid:
    bulldog93 and microbusbrewery like this.
  19. Aug 9, 2019 at 8:49 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Gotcha. I just checked mine and I think I'm happy with the viewing angle. I think it's probably at the ideal spot for the 18+ honeycomb
    bulldog93 and JoshuaA[QUOTED] like this.
  20. Aug 9, 2019 at 8:51 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Ya that looks good on screen, I also went up and noticed your pic, that's a great place cosmetically on your grille too. I wouldn't move it.
    TRDFerguson likes this.
  21. Aug 9, 2019 at 8:58 AM
    RDRunner
    RDRunner New Member
    So there is an extra switch installed in the dash where the factory left panels to put switches. Thanks
    bulldog93 likes this.
  22. Aug 9, 2019 at 10:00 AM
    hooter
    hooter New Member
    I mounted mine in the same spot with an L bracket and 3M tape too. I also reinforced it with an extra strap bolted from the L bracket to one of the TSS mounting bolts.
  23. Aug 9, 2019 at 10:39 AM
    Tun-D
    Tun-D New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
    Do you have any pics of the mounting? I couldn't figure out a good way to mount mine so I went below the license plate holder for now. It does the job but I think it's a little too low.
  24. Aug 9, 2019 at 10:55 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    It's hard to admit this, I've been driving a Tundra since 2015 and I still have no damn idea where the thing sits in space and time.
    I think I have it nailed then I get out and realize Stevie Wonder probably parks better than me.
    Yesterday I actually had to get back in and move it because more of the truck was in the lane than my parking spot.
    Boatmoney[QUOTED][OP] likes this.
  25. Aug 9, 2019 at 11:00 AM
    hooter
    hooter New Member
    Sorry, I don't have any right now. I'll see if I can take the grill off and get this weekend.
  26. Aug 9, 2019 at 11:02 AM
    lawrenceb
    lawrenceb New Member
    2019 Tundra TRD Pro
    The one OP posted works with Tundras, switch is cool looking.. and the kit looks well made. Just wonder about the quality of the front camera..
  27. Aug 9, 2019 at 11:21 AM
    RDRunner
    RDRunner New Member
  28. Aug 9, 2019 at 11:23 AM
    lawrenceb
    2019 Tundra TRD Pro
    :rofl: Front and side cameras on a Tundra? Come on man.. that option is slated for 2025.. will be cutting edge
  29. Aug 9, 2019 at 11:25 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Here's the ghetto bracket I made. It does the trick and has (so far) held up to the 115 degree Phoenix summer heat:
    I ran the cable inside wire loom along the TSS cable and mounted the connector at the top with the one for the TSS so that I can easily disconnect and remove the grille when needed:
  30. Aug 9, 2019 at 11:42 AM
    Tun-D
    Tun-D New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
    Nice.
    That's OK - it looks like @TRDFerguson has a similar setup. Thanks for the offer to take the pics though. I'm guess that is the optimal install location. I might have to move mine now as it's a bit low and ugly:
